Question about HP DeskJet F4280 All In One Printer InkJet
Unable to install cartridge
I cannot see any 'carriage' as it is shown in setup guide
  • 555 Answers
Hello my friend, regarding on your problem in installing your cartridge you can see it inside in your printer. Open the printer cover then wait for the cartridge holder to stop swinging and stay in the middle then pull out the two platic attach to the cartridge holder. The plastic u pull out are the ink cartridge and then insert new ink cartridge then insert it again in the cartridge holder the close the printer cover and then you can print and used the printer. Don't forget to turn on first your printer before removing the cartridge.
Posted on Jun 16, 2009
Epson expression xp 600 error code 0xEA when setting up
I had the same problem today. I opened the printer below the scan bed, where you install the ink cartridges and there was a piece of packaging material that got left in that while I unpacked. I removed that and the 0XEA error was gone. I was sure the problem was nothing to do with the cartridge installation as it was the initial setup of the printer and cartridge installation was the next step based on the user guide. I was getting this error on initialization after setting the region, date and time.
Jul 24, 2013 | Epson Expression Premium XP-600...
I am looking for a color access door for a print carriage on an hp psc2210 all in one printer. (C8654A)
  1. If you are putting in a new cartridge, make sure to remove the tape.
  2. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  3. Fit the cartridge into the proper carriage.
    • The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
    • The carriage with the blue latch is for the tri-color cartridge (HP 57).
    Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
  4. Hold the hinged flap of the latch out while lowering the latch.
  5. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
  6. Close the cartridge access door.
  7. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Aug 23, 2011 | HP PSC 2210 All-In-One InkJet Printer
Keep getting paper jam fault 3618
Hi!
If the error comes up during the initial setup of the printer:
  • Select All-in-One Printers.
  • Double-click the Setup Guide for your printer.
  1. Open the printer access door.
  2. Remove all:
    • orange shipping tape
    • foam pieces
  3. Follow the steps in the Setup Guide to insure that you have properly installed the printhead and ink cartridges.
  4. Close the printer access door.
  5. Press OK to clear the error.
  6. Make a print.
OR
Check the printhead carriage area:
Debris and Obstructions:
  1. Remove any paper, tape or other obstructions from the printhead carriage area.
  2. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
Ink Cartridges:
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
    NOTE: If the printhead does not move to the center position, press Home, then Maintenance on your printer. Check if the Install Ink Cartridge option is available. If so, select Install Ink Cartridges, press OK, and follow the instructions. Otherwise do the following:
    1. If an error is displayed on your printer control panel or the status monitor on your computer, press Cancel to clear the error.
    2. Go to KODAK All-in-One Printer Downloads and Drivers, select your printer from the All-in-One Printers pull-down list, and download and install the latest firmware version for your printer. Follow the on-screen instructions.
    3. After you upgrade the firmware, press Home on the printer control panel.
    4. Select Maintenance, then press OK.
    5. Select Install Ink Cartridges, then press OK.
    6. Follow the instructions on the control panel LCD.
    7. Go to the next step.
  2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
  5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  6. Close the printer access door.
  7. Press OK to clear the error.
  8. Make a print.
Hope this helps.
Apr 19, 2011 | Kodak ESP5250 All-In-One InkJet Printer
My canon MP480 keeps poping up a 5100 error
That error is a Carriage error, which means that the printer carriage (the bit that holds the cartridges) is unable to move or similar.
Make sure you've installed the cartridges correctly and that the grey lever that holds down the printhead is in the down and locked position.
You may find that you've installed the printhead incorrectly so worth pulling out the cartridges, removing the printhead and then reseating it so the lever goes down to a horizontal position. Then reinsert the cartridges.
Mar 10, 2011 | Canon Pixma MP480 All-In-One InkJet...
Printer software will not install
Hello Sir,
Plz follow this step
  • Step 1 Power up the printer. Plug the power cord into the back of the printer and press the power button one time to turn the printer on. If the printer does not respond, make sure that the power cord is completely plugged into the printer and the power outlet.
  • Step 2 Insert inkjet print cartridges. If you have an inkjet printermag-glass_10x10.gif, unwrap the print cartridges that came with your printer and securely fasten them in the printer cartridge carriage inside the printer. How to insert the inkjet cartridges will vary depending on the model of your Lexmark printer. Regardless of the model, you should not manually drag the print cartridge carriage over to install the cartridges. All inkjet models have a carriage that automatically moves to allow you easy access for installing cartridges. Be sure that the ink cartridges are firmly secured in the carriage before using the printer.
  • Step 3 Plug the USB cable into the printer. Plug the type B connector end (the smaller square-shaped end) of the USB cable into the designated port on the printer. Do not plug the USB into the computer until prompted to do so by the installation CD.
  • Step 4 Insert and run the installation CD. Most computers will run the setup program automatically after you insert the CD. If your computer does not automatically do this, select your CD drive and explore the contents of the CD. Double-click the "setup.exe" file. Follow the instructions the installation program provides.
  • Step 5 Print a test page. After you have completed installing the software for your printer, you will have the option to print a test page. This will confirm whether your installation and setup was successful. Be sure that you have loaded paper into the appropriate tray before printing a test page
  • Read more: How to Install a Lexmark Printer | eHow.com http://www.ehow.com/how_4699546_install-lexmark-printer.html#ixzz0tFYWphq9
    Jul 09, 2010 | Lexmark X5470 All-In-One InkJet Printer
    4110 officejet series all-in-one error message saying i installed incorrect ink cartridge? what do i do? it is the correct one
    Supported HP Inkjet cartridge part numbers The HP Officejet 4100 all-in-one series products use the ink cartridges listed in the table below. HP Inkjet cartridges HP 56 black cartridge (19 ml) HP 57 tri-color cartridge (17 ml) HP 28 tri-color cartridge (8 ml) Replacing the ink cartridgesThe power must be turned ON to the all-in-one or the print carriage will not move to the right.
    1. Locate and open the print cartridge access door on the right side of the all-in-one. The print cartridge carriage will move to the right for access. Figure 1: Opening the HP Officejet 4100 seriesc00121089.jpg
    2. Press down gently on the top of the old ink cartridge to release it from the print carriage. Figure 2: Removing an ink cartridgec00121090.jpg
    3. Remove the new print cartridge from its packaging and remove the protective tape from the cartridge as shown in Figure 3. Do not touch the gold-colored contacts. Figure 3: Removing the cartridge tapec00121091.jpg
    4. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage and press them into position as shown in Figure 4. If the cartridge does not snap easily into position, it is not aligned correctly. Remove the cartridge and reposition it. Do not try to force the cartridge into position. The black ink cartridge (HP #56) goes on the right side and the color cartridge (HP #57 or HP #28) goes on the left side. Close the ink cartridge access door when the ink cartridge has been installed. Figure 4: Installing the ink cartridgesc00121092.jpg
    5. A message will appear on the front panel requesting that the ink cartridges be aligned. Follow the steps below to align the ink cartridges:
      1. Press Enter on the all-in-one front panel to start the ink cartridge alignment process.
      2. After the Alignment page prints, place the page into the ADF upside down and with the printed side down as is shown in Figure 5.
      3. Press Enter. The all-in-one will scan the alignment page and finish aligning the cartridges.
      Figure 5: Aligning the ink cartridgesc00121093.jpg
    Correcting error messages that appear after changing a cartridgeAfter inserting the cartridge, the Check Print Cartridge light flashes or one of the following messages appears on the computer monitor:
    • Check the black (or color) cartridge
    • Replace the black (or color) cartridge
    • The wrong black (or color) cartridge is installed
    These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
    1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
    2. Remove the ink cartridge and inspect it.
    3. Verify that it is the correct part number and if it is, reinsert it.
    4. Close the lid to see if the problem is corrected.
    5. If the message is still displayed after a few seconds, remove the ink cartridge again.
    6. Unplug the power cord from the back of the unit.
    7. Clean the electrical contacts on the ink cartridge with a soft clean cloth slightly dampened (not wet) with clean water. (See Figure 6) Each contact is very small and shaped like a rounded square. Figure 6: Cleaning the cartridge contactsc00121094.jpg
    8. Allow the ink cartridge to dry for a few minutes before reinserting the cartridge(s) and turning on the printer.
    9. If the problem remains, replace the ink cartridge.
    10. If the problem still exists after trying all of the steps above, the unit may need to be serviced. Contact HP for further troubleshooting or to arrange to have the unit serviced.
    Make sure what ur using isn't a refilled cartridge and if it is check the expiration date, if nothing is wrong then you need to get urself a new printer or an upgrade so call up hp at 1800-474-6836 and get help of them,they'll guide you to a new /upgrade printer.
    it's not a nice way of saying it but someone has to give you the bad news
    Feb 01, 2010 | HP Office Equipment & Supplies
    How do you replace ink in EPSON TX110? Paul
    The procedure is shown on the panel you can see if you open the cartridge compartment of your TX110. However, it can take some effort to decipher the icons. It is known to work if the ink low light is on, untested otherwise.
    1. Turn on the printer.
    2. Press and hold the STOP button until the cartridge tray moves out of its bay. It will stop at the ink low notch pointing to the first cartridge out.
    3. Press STOP again. The cartridge tray will move to show you the next cartridge low on ink.
    4. Repeat until you know all cartridges out. After the last cartridge pointed to, the tray will move again and stop in the area where all cartridges can be accessed by hand.
    That's it folks!
    Nov 12, 2009 | Epson Stylus NX400 InkJet Printer
    Remove empty print cartridge
    Turn the printer on, when time is displayed press the setup button. Press the up/down arrow buttons to get to "5. replace Cartridge" and then press OK. Open the scanner unit and lift the lid off the ink carriage unit. Remove the empty cartridge and fit the new one. Make sure the cartridge and carriage cover click down into place, close scanner unit and press OK. The user guide with pictures can be downloaded fro Epson here:
    http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=58607&prodoid=58654753
    Please take a moment to rate this solution, thanks.
    Apr 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
    How to change a cartridge on c4345
    Installing new cartridge:
    Remove cartridges:
    Nov 26, 2008 | HP Office Equipment & Supplies
    The printer simply says, "Unable to print. See troubleshooting and Routine Maintenance guide chapter in User's manuel." Thanks.
    Hi Bang, give this a shot,
    Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
    anaanymous
    Oct 14, 2008 | Brother MFC 420CN All-In-One InkJet...
    HP DeskJet F4280 All In One Printer InkJet Logo
    123 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
