Question about Kohler Electrical Supplies
Kohler Genset Backfires and stalls out
I have a Kohler 5E gas Genset which runs smoothly of about 1 to 2 minutes, then begins to run rough, backfires and stalls out. While running smoothly, if a load is put on it, it immedialty begins to stall.
Last year I changed all the inline filters as well a cleaning the carb itself. I ran well at that time.
I suspect it is an issue with sediment build up again.
Also, I would like to know if i can install an in line fuel shut off valve on the unit.
thanks, John
  • 63 Answers
SOURCE: generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Posted on Mar 16, 2009
  • 120 Answers
SOURCE: kohler command 18 backfires when warmed up
Try changing the spark plug.
Posted on Jun 03, 2009
  • 905 Answers
SOURCE: ginne stalls under load
Likely that your governor has creeped out of tolerance. Very common with Emerald line of generators. Try to borrow, if not already have one, a multimeter that is able to read frequency and voltage. At no load, frequency should be 62 or 63 hertz. At full load, frequency is going to be around 57-58 hertz. Voltage at no load should be 127 or so, full load should drop down to around 115 give or take. Adjust governor for faster engine operation for low voltage / frequency, slow down for too fast frequency or high voltage (though that is likely not the case here).
Problem with Emeralds is that the governor spring rubs on bracket, and also has a tendency to stretch. If this is the case, adjusting governor will be near impossible between full and no load.
Posted on Aug 25, 2009
  • 7 Answers
SOURCE: EU3000is running rough and idle hunting.
I'VE SEEN THIS BEFORE ON 1 I REPAIRED IT IS THE INVERTER THAT IS BAD!!! THEY COST ABOUT $600.00 JUST FOR THE INVERTER!!!!
Posted on Sep 10, 2009
  • 211 Answers
SOURCE: kohler propane genset won't stay running
hi
try a new plug with the same heat range
bye
Posted on Sep 25, 2009
Dodge dakota backfire
It sounds like you need a good tune-up, such as spark plugs and/or wires. They will act up when cold and when warmed by engine temperature will let the engine run smoothly again. And possibly a distributor cap/rotor.
Apr 17, 2014 | 1992 Dodge Dakota
Kohler backfires
This is a timing issue. Check the flywheel to make sure that it is not loose and that the woodruff key is still present.
May 25, 2013 | Toro ENGINE - 20HP KOHLER Part 93-1169
1999 dodge ram van 1500 backfires when let off the gas
NEADS A TUNE UP,ALSO PUT SOME INJECTOR CLEANER IN YOUR GAS TANK FIRST
Feb 12, 2013 | 1999 Dodge Ram
92 NISSAN WITH BOGGING AT 2800 3500 RPM AND AT LEVEL SPEED 4CYL AND 5 SPEED
For this types of problem,there are few help inks to troubleshoot the problem.Click the link below to go through the troubleshooting procedure to resolve the issues :----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
--------------runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
-----------Car still runs Rough after tune up? http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
------------Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
----------High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
------------Engine Backfires? http://technoanswers.blogspot.in/2012/02/jeep-backfires.html----------- Nissan stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Nissan Pathfinder Backfires? http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
---------How to adjust rpm? http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
------------Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
----------This will help.Thanks.
Feb 17, 2012 | 1992 Nissan Pickup
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Mar 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
1988 318 ramcharger idles very rough stalls alott
EGR valve stuck or not working clean or replace
Feb 05, 2009 | 1988 Dodge D-Series Pickups
95 jeep grand cherokee, hard starting, backfires, when cold
get a couple bottles of gas line antifreeze .. if you don't already use it and add it to the gas.
Robert
P.S. in minus 40 i don't even get out of bed... minus 23 here last nite... isn't winter grand
Jan 21, 2009 | 1995 Jeep Grand Cherokee
1999 JGL low fuel pressure backfires when the gas is applied
Did you replace the fuel pressure regulator.
Sep 11, 2008 | 1999 Jeep Cherokee
Electrical Supplies Logo
121 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
