Question about Biostar K8M800 Micro AM2 Motherboard
I have to press f1 to go to main screen what should i do
    Sergeant:
  • 268 Answers
You may have to replace your cmos battery. It sounds like your motherboard's bios lost some settings.
Posted on Jun 18, 2009
Press f1 start windows
It may be asking you to press the "F1" key because it is having a hardware problem which should be checked, or you may need to adjust the settings in BIOS. It can also be an indication that you need to replace the CMOS battery. Try this: Go to your BIOS and load default settings.2 Mar 2012
Press F1 key to start Windows - Ccm.net
ccm.net/faq/9372-press-f1-key-to-start-windows.
also go to this link might help you out. Press f1 start windows Google Search
Oct 13, 2017 | ASUS Computers & Internet
How to put a calculator fx-9750GII in degrees
  1. Turn calculator ON.
  2. If you see no icons, press Menu then 1 to go to main calculator screen Run>Mat.
  3. In Run>Mat screen press SHIFT MODE to enter SetUp.
  4. Move the highlight to the line ANGLE. Press the F1 tab at the lower left of screen to select Degree.
  5. Press EXE to exit the SetUp screen.
Jun 17, 2012 | Casio FX9750GII Graphic Calculator
How do I convert to binary with the Casio fx-CG10?
Press the Menu key. Press 1 to select the Run/Mat icon. In main screen, press SHIFT MENU to enter (SetUp). On the 2nd line Mode: Select DEC(imal) numeration. (Do not select the usual COMP mode). Press EXIT to return to the main calculator screen. Enter the base-N identifier (d, h,b, or o) followed by the number expressed with the correct digits. Press EXIT to return to the screen with the tabs d tilda o, LOGIC, DISPLAY. Press F3 for DISPLAY , use F1 (>Dec), or F2>Hex etc. to display the number in the base you want.
Feb 23, 2012 | Casio Office Equipment & Supplies
As i turned on the monitor the screen shows CMOS WRONG PRESS F1 TO SETUP PRESS F2 TO LAOD DEFAULT VALUE
hi,
first of all check the main battery back of ur machine by unplugging from the mains power supply. if machine shuts off, then u have to replace the battery.and then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
if the main back up battery is ok, then another possibility is the CMOS backup battery of ur machine have some problem. that's why it loosed all the seted parameters. then u have to replace the CMOS battery of ur machine. normally 3V battery. then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
ok
Jan 13, 2011 | Dmm UT4000F Multi-Parameter Patient...
My Toshiba portege R 500 wont turn on until I remove the cmos battery, main battery and mains power. If I power it on again It gives the rtc battery error and prompts me to press f1, Pressing F1 gives me a...
According to Toshiba Support the remedy is to connect the laptop to the ac adaptor and plug in to wall outlet. Then turn it on and leave it on for 24 hours while the rtc battery charges.
Oct 11, 2010 | Toshiba Portege S100-S1133 Notebook
How to rest the calculator fx 9860 g before the board exams
Soft reset: From the Main Menu, enter the SYSTEM menu. Press F5 (RSET). Press F1 (STUP) and then F1 (Yes). Press EXIT MENU to return to the main menu.
Hard reset: Press the P button on the back of the calculator.
May 04, 2010 | Casio FX-9860G Graphic Calculator
Graphing Problems
In home folder (main calculator screen) press [Diamond][F2:Window]] to access Window configuration screen.
Press [F1] ( not mecessary now because the F1 page is open by default). In the F1 page of configuration screen set Xmin=-10,
Xmax=10
Ymin=-10
Ymax=10
Xscale=1.
Yscale=1.
OR
Press [Diamond][F2:Window][F2][6:ZoomStd] (Zoom Standard) to set all values as above.
If a graph is active (axes displayed, or part of a curve is showing) press [F2:Zoom][6:ZoomStd]
Feb 15, 2010 | Texas Instruments TI-89 Calculator
Can't get into the bios for a presario 4716
This is what the Compaq site had to say about the BIOS utility for your system (Source: Compaq): • • • •You may have difficulty accessing the BIOS Setup utility screen, because you must press a specific key(usually F1) very quickly before the Windows screen appears. If you do not enter the BIOS Setup screen on your first try, repeat the following steps until you are successful.
To open the BIOS Setup screen:
1. Turn off the PC and wait about 5 seconds.
2. Turn on the PC.
3. When the first screen appears, press the F1 key on the keyboard. (You can press the key more than once.) The BIOS Setup Utility Main menu appears.
NOTE: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
4. Use the keyboard to navigate through the menus.
You may need to remove the battery and then back in.
Jul 21, 2009 | Computers & Internet
My laptop freezes on the main start screen
enter to bios set up then disable the f1 and f2
May 01, 2009 | Computers & Internet
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Nov 15, 2007 | Compaq Presario M2000 Notebook
Biostar K8M800 Micro AM2 Motherboard Logo
60 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
