Kenwood KDC-MP335 CD Player Logo
A
Anonymous Posted on Apr 03, 2014
How do i get it to register the code without the remote
How do I change the radio stations on my 505 5.1 media lab without a remote??
Visit Manuals and Warranties ' Genesis Resources ' MyGenesis Register your product and login then download the required user manual and follow instructions given in user manual.
tip
Pairing a BlueRay remote to your PS3
Register Bluetooth® Device Register a Bluetooth®-compatible device with the system.
Registering a BD remote control
1. Prepare the BD remote control.
2. Select "Accessory Settings" under "Settings" in the home menu.
3. Select [Register Bluetooth® Device].
4. Select [Register BD Remote Control].
Only one BD remote control can be registered at any given time. If you register another BD remote control, information on the currently registered device will be overwritten.
5. Follow the on-screen instructions to register the BD remote control.
When the registration (pairing) is complete, a controller number is assigned.
2013 Toyota Highlander. Key fob remote doesn't work after installing new battery. It is not a smart key remote.
PROCEDURE. Make SURE the battery you installed is good.
  • Driver's door open, key removed from ignition switch
  • Within 5 seconds: Insert and remove the key from the ignition switch twice
  • Within 40 seconds: Close and open driver's door twice
  • Insert and remove the key from the ignition switch. Close and open driver's door twice
  • Insert the key into the ignition switch and close the driver's door
  • Within 40 seconds: Switch ignition ON and OFF once to program a remote transmitter code whilst retaining the original codes or twice to program and remote transmitter code whilst erasing the original codes. Three times to check how many remote transmitter are currently registered or five times to erase all registered codes
  • Remove key from ignition switch. System should now lock and unlock vehicle once, twice or five times depending which mode has been selected. One to four times, slowly, to indicate number of remote transmitters registered
  • Within 40 seconds: Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds
  • Within 3 seconds: Press LOCK button
  • SYstem should now lock and unlock vehicle once to confirm registration, twice to indicate registration has failed
  • Within 40 seconds: Repeat button procedure to program remaining remote transmitters.
  • NOTE: To exit programming mode: Open driver's dorr
  • NOTE: A maximum of 4 remote transmitters can be programmed
If the above programming procedures do not work, then you should contact your locksmith.
Goood Luck!
Clearing items
I am not sure what your question is but however I assume you want take away some products from you machine without having to enter the bar-code. Unfortunately the bar-code I.D the identity of the product. you cannot. If your barcode scanner is not working, you have to enter the barcode number manually then press the PLU button
1helpful
How do you program a replacement key for a lexus es 330 2004
Here are the instructions from the factory manual. They must be followed exactly.
2004 ES330
1. Driver's door open, all other doors closed, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
2. Within 40 seconds:
Close and open driver's door twice.
3. Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
4. Switch ignition ON and OFF:
A. Once to program a key remote transmitter code whilst retaining the original codes.
B. Twice to program a key remote transmitter code whilst erasing the original codes.
C. Three times to check how many key remote transmitters are currently registered.
D. Five times to erase all registered codes.
5. Remove key from ignition switch. System should now lock and unlock vehicle
times, slowly, to indicate number of key remote transmitters registered.
6. Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds.
Within 3 seconds: Press any key remote transmitter button.
System should now lock and unlock vehicle once to confirm registration or twice
to indicate registration has failed.
7. Within 40 seconds:
To program additional remotes repeat step 60 now on each additional
remote you want programmed.
8. To exit programming mode open driver's door or insert key into ignition.
9. Step out of car with remote(s) in hand and test remote(s).
2answers
How do i program the Sony BD remote without the actual PS3 controller
Use a game controller to look under System Settings - > Accessories. Choose Register BD Remote.
Not receiving signal from remote control
I have a new remote from a C1300NTVD Lightning McQueen car TV for sale. It's probably the same remote for a C1320PTVD.
Chris
email me: chris_goulet [at] yahoo [dot] ca
4helpful
Programming a 1995 toyota avalon key fob
To program a remote... note that you must not delay more than 10 seconds between any of the operations.
Driver's door open, all other doors closed, key removed from the ignition switch.
Insert key into ignitions switch, then remove it.
Press LOCK then UNLOCK on the vehicle door lock control switch at 1 second intervals 5 times.
close and re-open drivers door.
Press LOCK and UNLOCK on the vehicle door lock control switch at 1 second intervals 5 times
Insert Key into ignition switch.
Switch ignition ON and OFF once to program a remote transmitter code while retaining the original codes or twice to program a remote transmitter code while erasing the original codes. three times to check how many remote transmitters are currently registered, or 5 times to erase all registered codes.
Remove Key from ignition switch.
System should now lock and unlock vehicle. Once, twice or five times depending which mode has been selected. It will lock and unlock one to four times slowly, to indicate the number of remote transmitters registered if you chose option 3.
Press and hold remote transmitter LOCK and UNLOCK buttons at the same time.
Press LOCK remote button for 1 second: System should now lock and unlock vehicle once to confirm, twice to indicate registration has failed.
NOTE: to exit programming mode, close drivers door or insert key in the ignition.
NOTE: a maximum of 4 remote transmitters can be programmed
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
