Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
0 characters
1 Points
How do i change the fax confirmations to come out of the side tray?
There should be a setting menu in "system settings" : Common settings , Paper tray settings.
Aug 14, 2014 | Kyocera Taskalfa 250ci Color Copier...
How do you program the panasonic kx-fl511 to print fax confirmations sent.
How can i remove call service6 problem on my
Problem with the Panasonic KX-FL511 Plain Paper Laser Fax
Jul 07, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
Our Panafax UF-550 will not give us confirmations that our faxes were sent. Also, the Date, Time, and percentage is flashing and it never did that before. Can you Please help me?
function 74
Date & Time:
Fuction 71
key in date and military time
The flashing date and time is because you a dead non-replaceable back-up battery
Jul 08, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
How do i change the fax name on the confirmations
go into the menu and look for fax set up go to the tel number section and it will ask for tel number first and then for address or header here you use the key pad to enter the name of your company GOOD LUCK A
Jun 25, 2009 | Brother IntelliFAX 4100 Laser Fax
Panafax uf 755e
Function 74 set 12 set 2 set stop
Aug 12, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Confirmation sheets
Yes,press usermode go to reports and in RX report switch it to on.
Jul 11, 2008 | Canon FAXPHONE L80 Laser
Fax Confirmations
1) Menu/set
2) 2
3) 4
4) 1
5) Press + or - "ON" or "ON+ IMAGE" to have confirmation with a preview image of the first oage you sent
6) Menu/Set
May 01, 2008 | Brother IntelliFAX 2800 Laser Fax
Fax confirmation
check the settings in the paper tray. Do you have a manual? Should be info in it to change paper specs.
Aug 23, 2007 | Ricoh FAX5000L Plain Paper Laser
How do you program the machine to only print out falied fax confirmations?
Yes. SmartDeviceMonitor for Admin and Web Image Monitor let you remotely view a device's transmission history as well as its saved destination data. You can install SmartDeviceMonitor for Admin from the CD-ROM that was included with your device, or download it from the device's website. However, SmartDeviceMonitor for Admin can only be used on a computer which has the TCP/IP protocol correctly installed. Once you have confirmed that SmartDeviceMonitor is installed, to confirm that your fax was transmitted properly, follow these steps: 1.Open SmartDeviceMonitor for Admin by clicking [Start] on the taskbar, pointing to [All Programs] and then [SmartDeviceMonitor for Admin], and then clicking [SmartDeviceMonitor for Admin]. 2.Click the device whose information you wish to display. 3.On the [Tools] menu, click [Load Fax Journal]. 4.When Web Image Monitor opens in your web browser, click [Job], click [Fax History], and then click [Transmission].
Jul 09, 2007 | Ricoh FAX5510NF Plain Paper Laser
Fax Machines Logo
Top Canon Fax Machines Experts
old marine
old marine
john archer
Are you a Canon Fax Machine Expert? Answer questions, earn points and help others
