Question about Rosewill R900J 19" Flat Panel LCD Monitor
I have a AOC flat screen monitor and it got wet and it will turn on for a few seconds but the screen is blurry and looks wet itself , is there anyway to fix this ?
  • 555 Answers
Hello my friend, try to blower your monitor. Open it and see if inside of the monitor is not wet cause if it is wet then it could cause some short circuit problem so the best thing to do is to let the monitor check if it is wet and dry it up before turning on
Posted on Jun 16, 2009
I can't unlock my osd screen, tried everything
While holding it, turn the monitor on. Once the monitor is on for a few seconds, let go of the "left" button. Your OSD should be unlocked. This is how it works to lock press and hold the MENU button while the monitor is off and then press power button to turn themonitor on.
How to unlock the OSD of an AOC monitor - Quora
https://www.quora.com/How-do-you-unlock-the-OSD-of-an-AOC-monitor Feedback
About this result
How to unlock OSD my HPx20 LED wide screen monitor?.. - HP Support ...
https://h30434.www3.hp.com/...Lockup/...unlock-OSD-my...screen-monitor/.../74766... Jul 4, 2011 - Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD. "Power button is locked" message - HP Monitor 27es
Aug. 31, 2017
OSD Lockout on HP Pavilion 27xi - how to unlock?
Apr. 5, 2017
HP monitor Main Menu / OSD Lockout cycle continuously
Jul. 9, 2009
More results from h30434.www3.hp.com
HP LCD and LED Monitors - OSD Lockout Message Appears on the ...
https://support.hp.com/ca-en/document/c01932183 What to do when an OSD Lock out message opens. ... OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
display - How do I lock and unlock the OSD of a "AOC monitor 21 ...
https://superuser.com/.../how-do-i-lock-and-unlock-the-osd-of-a-aoc-monitor-21 Aug 29, 2009 - OSD Lock Function: To lock the OSD-First make the Monitor off by pressing power button and then hold the Left button for 5 seconds and simultaneously hit the power button with the left button and the osd is Locked. If your AOC e2343F is locked then just power off your screen and hold power and menu buttons together.
can unlock my osd screen Google Search
Jun 12, 2018 | Cars & Trucks
Blurry pixel display of AOC monitors.
Hi, In my experience, it looks that the screen pixels are damaged in some areas. It could be due to mishandling, may be fallen or it could be a manufacturing defect. If the device is new, ask for the replacement as it may enlarge due to heat. Rest is your luck :)
Sep 28, 2017 | AOC Monitor
If I turn on my computer the monitor works well but after a few minutes it turns off itself (it goes to the standby mode orange led lights). Then if I turn on the monitor again it works only a few seconds....
Just in case the monitor is not te problem, why don't you try this.
For (xp)
-Go to desktop
-right click and click properties.
-screen saver
-power
-then set all the drop down list box to never
-click apply.
You can try it on other operating system.
-go to controls
-look for display and follow 2nd step on xp.
Hope this help. Thank you for using Fixya!
Apr 19, 2011 | AOC LM729 17" LCD Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Monitor flashes the "AOC Eyes Value" logo without evr turning on
Man that really hurts.
Flashing logo of company on monitor screen means your monitor has power but not receiving data. Have to find a way to fix data, may be data cable ( vga cable ) of booting of computer itself
Try few things not sure solve your problem or not but really doesnt hurt to try
First, It looks you have loose VGA cabling. Try removing VGA cable completely and connect again
Link how VGA cable looks like
http://files.sandberg.it/products/images/lg/501-93_lg.jpg
Second, if above doesnt solve the problem, may be your VGA card has problem or your CPU is not booting up. Feel the breeze of fan on SMPS to see if it is working or not.
Hope this helps
May 20, 2010 | AOC 193FW LCD Monitor
AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Sep 20, 2009 | AOC LM729 17" LCD Monitor
19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
Apr 17, 2009 | AOC 917Sw 19" LCD Monitor
AOC LM725 Monitor Problem
Change the monitor and check if the PC works. If it works then the problem is with the monitor, you will have to send it to repair. If not then, the problem should be with the power supply, check whether all the cables is kept intact.
Mar 21, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
AOC LM725 LCD Monitor
try looking for bloated caps, check all diodes... see if its not shorted/leaking and finally check the power regulator ic if its not shorted! note: some capacitors and diodes are very tiny, you should use a lens with good amount of light...
if it does not help..... well, what the hell? try pouring some gas, then light it up! that should solve the problem, at least it turned on right? hehehehe!
Mar 21, 2009 | AOC LM729 17" LCD Monitor
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
Rosewill R900J 19" Flat Panel LCD Monitor Logo
200 people viewed this question
Top Rosewill Computers & Internet Experts
Ian Ballard
Level 1 Expert
Jim Thurston
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
