Question about Sony BRAVIA KLV-32U100M 32 in. LCD Television
When I turn sony kdl32m4000 on, green power light comes on but
Nothing else happens. Tried factory reset, however it does not power off in 10 seconds while holding up arrow and power button simutainiously.
    Scholar:
  • 89 Answers
I understand that your TV is turning ON but you're not bale to view the videos on the TV screen. If the TV is connected to a wall outlet through a Surge protector please disconnect the connection through the Surge protector and try connecting the TV to a working wall outlet and check if that helps. Please check the connection between the TV and the connected device. Please try using a different device and check if that helps. This is to check whether the issue is with the TV or the connected device. Please try to explain the issue as much as you can next time. What are the video sources connected to the TV? Does this issue occur with the TV when connected to other devices? How did you connect the videos sources to the TV? Which connection are you using to connect the devices to the TV? You TV doesn't support 1080p resolution, so please check whether the connected device is giving output in 1080p resolution. If the issue still persists service of the TV is recommended.
Posted on Jun 16, 2009
How do a reset a SOny Xperia SGPT1211 tablet
To do a hard reset on the xperia tablet, first power it down. Then, press and hold "Volume +" for roughly 3 seconds. While still holding "Volume +", then press and hold Power for an additional second. Use "volume -" to arrow down to the factory reset option.
Jan 25, 2018 | Sony Cell Phones
Sceern locked up, battery life full. cannot shut off as well.
try holding down JUST the power button for 120 seconds may soft reset then
Jan 01, 2015 | Tablets & eReaders
Tablet wont boot into anything but screen with horizontal lines..just got it today and charged battery and now i get nothing?
Holding the power button down for 10-15 seconds is considered a hard reset on most tablets. If it still won't load you can try doing a factory restore.
  • Make sure the tablet is powered off
  • Briefly tap the power button once, then hold the power button and volume down until you get the boot menu
  • There should be an option to factory reset or something to that affect
Dec 08, 2012 | Tablets & eReaders
The router was working fine yesterday. I checked it today, and it isnt working anymore. I unpluged it, and plugged it back in, and no indication lights are illuminating. I have tried this several times and...
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 16, 2010 | Belkin F5D8236-4 Router
The screen has frozen in e mail and i cannot switch off or move to another function or do anything
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything
Dec 07, 2010 | Samsung Galaxy Tab Tablet PC
Reset to factory default
The router's admin page is http://192.168.1.1 or http://192.168.0.1 and the default password should be either "admin" or "password" without quotes. There should be a choice under "Setup" called "Factory Reset". That will erase the settings and reset it like new.
Alternatively, you can follow the procedure as given below on all the brands I've tried (Belkin, D-Link, Linksys)
1. hold the reset button for 30 seconds (don't release)
2. unplug the power (still holding reset) for 10 seconds
3. plug power back in (still holding reset)
4. hold reset for another 30 seconds - the lights will usually begin flashing in some odd pattern
5. release the reset button
6. wait 1 full minute or until the lights stop flashing
7. unplug the power for 10 seconds, just to do a reboot
8. verify the settings (e.g. SSID) are back to the defaults
Get instant online Linksys router/wireless router support at http://www.vtechsquad.com/linksys-router-support/ to fix Linksys router/wireless router problems.
Oct 25, 2008 | Linksys Wireless-G WRT54G Router
Factory Default Reset Procedure
Hold the reset button in for 10-15 seconds... Now its defaulted back to factory and the user name and pass will both be admin
May 07, 2008 | Linksys Wireless-G Broadband Router
Factory default
The following reset procedure will completely restore the default settings on the VDI-604 and VDI-624. Note: If you do not remember your password, you will have to reset the router to factory defaults. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Note: After resetting the router to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
Factory default
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Sony BRAVIA KLV-32U100M 32 in. LCD Television Logo
2,712 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
