Question about Maytag Neptune FAV6800AW Top Load Washer
My maytag fav68000 is displaying 2 cycles at once; it won't change or shut off
  • 335 Answers
This could be an issue with the control board. I assume you have recycled he machine 120VAC power to turn off machine. If that did not help I would check to see if the control board will let you get into Service Mode.
Try this close the lid and try to enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00” Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on do you hear it run? Stop the test with the off button or hit the Presoak key. If you can get into Service Mode report back and we can try getting into the machine diagnostics mode.
If your FAV6800AWW will not let you get into Service Mode I would next replace the Control Board. The Control Board is under warranty for 5 years. Call Maytag at 1-888-462-9824 to see what your next step may be, I got them to send me the control board.
Do you have surge protection on the outlet powering the machine? Have you had any storm activity in your area recently?
Posted on Jun 16, 2009
Maytag Epic Z Washing Machine shuts down during spin, can I fix it myself?
Hello Brain;
My name is Peter. I am a retired field service appliance technician.
Error codes are generalized. Both of your codes are drain relative. They will tell you to clean your drain, but there is more to it than that.
You may have a bad drain water level switch, a plugged drain line....
Please send me your model number, So I can see what your have.
Peter Goodwin
Glen Burnie, MD
Jan 13, 2015 | Maytag Epic Z and Performance Series 2000...
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
My gas dryer keeps shutting down the heat cycle and I have changed the hot surface ignitor
The gas valve assembly consists of the ignitor, the flame sensor, and the solenoids.
In order for the gas valve assembly to operate, the ignitor must come on, the flame sensor must then shut the ignitor down in order for them solenoids to activates. Them selonoids won't activate untill the ignitor is glowing. Once the ignitor is glowing, it then acts as a thermocouple though the secondary winding on the primary solenoid. As long as you have igniton the ignitor keeps the power to them solenoids on. If fer some reason the gas did not ignite, then after the ignitor cools back down the gas would be shut down and that is your built in safety. So what goes wrong? With a bit of age them solenoids work a little then overheat and quit, making it a very difficult diagnosis. But now you know the secret right?
Swap out them lame solenoids and rock on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 27, 2011 | Maytag Dryers
When trying to use either upper or lower oven, panel flashing "Control Locked." Won't work.
Try this:
ToChangeFactorySetDefaultOptions:
1, Controloptionsmay be changedby se-
LectingtheSetupOptions(0)padandthe
desiredoptionpad.(SeeOptionsbelow.)
2. Currentoptionwillappearin thedisplay.
3. PresstheAUTOSETpadtochangethe
option.
4. PressCANCELpadtosetthe displayed
optionandexittheprogram
The LOCK is option 4 change the OPTION from 4 to 9.
9 is the factory default settings.
This should work. However.... there is the possibility that the unit had performed a self clean function. If you just completed a self clean cycle it can but up to 1 hour AFTER the cycle before you can open the door or use the oven as the range must cool down and cycle a thermostat before it wil work again.
There is also the possibility that the door lock has not completely retracted. If you can get it to start a self clean cycle.... after 1 minute press cancel and the lock should retract. (I know you said won't do anything) I am hoping that after you reset the options from 4 to 9 that you might be able to do this.
Thanks for choosing FixYa,
Kelly
Sep 06, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Model MDE9700AYW: I set the timer for a certain amount of time (say 30 minutes). I come back 45 minutes later and the dryer is still running. There is also a "racetrack" in the display. No error...
Instructions
1. Break your load down into smaller groups. Large, saturated blankets, duvets, blankets and other upholstery can be too heavy for the MDE9700AYW to safely dry. Dry large large items one at a time with some smaller items such socks and underwear to better balance the load. One washer load should equal one dryer load.
2. Confirm that the cycle selector has been pushed down and the dryer door is latched shut. When the dryer door is opened, the cycle is temporarily paused to protect you from injury. Press the cycle selector down to resume the drying cycle once the door has clicked closed.
3. Examine the circuit breakers or fuses in the dryer's electrical circuit. The Maytag MDE9700AYW needs two active fuses or breakers, depending on your home, to operate its electronics and spin the drum. The dryer may not spin if either one of the fuses or breakers is inactive.
Feb 24, 2011 | Maytag Dryers
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Maytag Neptune FAV6800AW Top Load Washer Logo
94 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
