Question about Samsung HL-S5086W 50" HDTV
My Samsung television has white dots all over the screen. It first started with just a few then more showed up. My husband tried wiping off the mirror inside the tv and even using canned air. This made the problem worse. It seems that the dots are dust particles that we cannot seem to remove. Thank you for your assistance!!
    Genius:
  • 1,139 Answers
Hello auntthumps, I have posted this eariler, it applies here so here goes: As the commercial goes, "It's the mirrors" and that is exactly what it is. The DMD (digital micromirror device) DLP chip that is the problem. The areas that are white are due to stuck or malfunctioning mirrors. This will only get more pronounced as time goes on. The fix is to replace the DLP chip and or module. I would advise that you get a qualified TV technician to do this. I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 16, 2009
  • Henry McKelvey
    Henry McKelvey Jun 16, 2009
    What you husband did was add dust particles to the screen, the original problem is the DMD chip. This is a common problem in this set.
Have Samsung D L P42 in ---problem white dots on screen
A DLP type set (any brand or model) uses a optical light engine= dots means a problem with the optical engine usually caused by the heat from the lamp affecting the lens unit or the engine itself---seen some with as many as 100 dots--engine would have to be replaced and they start at about 600+ or more.
Apr 14, 2012 | Televison & Video
White dots are showing up on the screen. They are multiplying quickly. I was told to clean the filter but that did not help. The lamp is less than a year old. Nearest dealer is 2 states away. How can this...
This problems is the tv Projection Light Engine design flaw with it IC chip.These problems happen to many models of it DLP tvs Big Screen 60 and up.Mitsubishi,Samsung,Sony,Toshiba all used the same IC chip on their 60 and up on their DLP tvs Big Screen.Tries make deal with Mitsubishi help u split the cost of repair the tv Projection Light Engine by replacing the IC chip or replaced the entire Projection Light Engine system.This problems is not new,been going on for a few years.Many people when on Youtube **** about this problems with white dots showing up on their tvs screens and multiplying rapidly.
Nov 20, 2010 | Mitsubishi WD-73734 73" Television
White dots all over the screen
White dots are due to bad DMD chip and qualified tv tech can replace required DMD chip in this tv to fix the picture issue.
Please contact nearest Samsung service center or local tv repair shop for repair estimate.
Thanks.
May 16, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
White dots
Samsung DLPs, means Bad Light Engine
Call Encompass Parts 1-800-638-3328
or UED 1-800-648-6657
Apr 15, 2010 | Samsung SP 56 K 3 HV 56" Projection...
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
Aug 20, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Have white dots on screen. model HL-S4266W
it seems like you might have an issue with your dmd board. Go to the tv menu and if the dots also show there, the issue is with the dmd board, but if they don't, it's with the video board
Aug 02, 2009 | Samsung Televison & Video
White dots all over screen
this seems to be an issue either with your DMD board or with your Digital Video board... turn on the tv and go to the menu if the white dots appear on the menu the issue is with your DMD board but if they don't show on the menu, the issue would most probbaly be with your Digital Video board
Jun 26, 2009 | Samsung HLS4266 TV
My screen has white dots all over the screen..they started out with just a few but over time they seem to have spread. Any idea if this is fixable? The television is only 3 yrs old.
Usually, the white dots (they should look more like small squares) indicates that the DLP chip is failing and needs to be replaced. It's located on the DMD board and is very expensive to replace. If you have an extended warranty, call and get them out to check.
Jun 05, 2009 | Samsung HLP5674W 56" Rear Projection...
Open Questions:
Samsung HL-S5086W 50" HDTV Logo
277 people viewed this question
Jerry Greenberg
Jerry Greenberg
