Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Getting error code 12 on mitsu wd 62525 dlp tv. any help would be great.
  • Mitsubishi Master
  • 8,617 Answers
12 means no error detected. What are the symptoms of the set? If its the blinking led thats the DM caps which have failed.
Posted on Jun 16, 2009
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Wd-62525 dlp: I get the following message: TV
how long does the set run before you get the message?
Dec 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
How do I check error codes on a Mitsu WD 62525. The set has been flashing green for 2 days. I tried to push and hold the menu and device buttons, but am not getting 2 different short codes. It seems to...
Don't need error codes for this one if the green light is flashing all of the time then you have a bunch of capacitors that have gone bad on the power board, dm and fmt boards.
Nov 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsu wd 62525.no picture only jumping horizontal lines.red blinking light came on.i replaced lamp now red blinking stopped but still no picture. error code 12
I would suspect the powersupply. Check 2 electrolitic capasitors on the powersupply board, I believe they are 25v at 1500mf.
They will be noticable bad by the bulging tops. This unit is a nightmare to work on so if you have any doubt of your abilities, play it safe and call a Mit. Service repair facility.
Hope this helps,
Skyassoc
Jun 16, 2009 | Televison & Video
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 DLP has no picture
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 03, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
741 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
