Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Kenore Elite Freezer is hot on the sides
Warner light and buzzer were activated, then when off when I hit the "quick frezze" button. Still very hot on the dies though.
  • Frigidaire Master
  • 4,655 Answers
Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) I will need that number to help you solve the sound alert coming from your refrigerator. Find that number and we can go from there, Thanks, Sea Breeze
Posted on Jun 16, 2009
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
STOPPED RUNNING
Hello Warner, thank you for your post!
Typically when a freezer displays "OFF" it means that the temperature control is in the off position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try re-activating your freezer by pressing the UP arrow until display shows "4" or desired setting. If the issue persists, then the freezer could possibly be experiencing a communication issue with the control board, temperature control or a potential wiring failure. At this point, I suggest reaching out to an appliance expert who is best equipped to pinpoint the exact problem.
Best of luck!
Feb 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Mar 13, 2013 | Kenmore Freezers
Freezer started defrosting and the sides where burning hot. I emptied it and unplugged it. The next day i plugged it in again and it froze a water bottle rather quickly but the sides where still burning...
Your defrost timer has stuck to on position, replace timer and all good or locate timer and spray lubricant into the dial and turn it several times with unit off, then try it after several hours, quick fix only but may last several years...good luck...Russ
Aug 22, 2011 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Alarm buzzer went off and the yellow and redlights are "on."
The on/off switch is only for the alarm. Some people do not want the buzzer to sound for them. If your buzzer is going off then the temperature in the freezer is too warm. It usually means the door was not closed all the way or there is a malfunction in the cooling system. Check the door and seal, make sure it is closing all the way around. If it is and the alarm does not stop on it's own then you will need service done on the unit.
May 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer is running constantly and sides and top are hot.
first whirlpool makes a good product as far as the sides being hot good sign the condensing coils are in the sides are supposed to be hot worry if its running and they are cold then not working right ok as far as running modern units useing 134a do have long run times but are not using but same enegry as 100watt light bulb otay
Dec 30, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
204 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
