Question about Whirlpool WFW9400S
I have a maytag 3000 series washer just got the error code F71 wont power on at all what to do
  • 26 Answers
SOURCE: ERROR CODE F71
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Posted on Dec 19, 2008
VtToolMan
  • 704 Answers
SOURCE: Planning to purchase a pair of 3000 Series Maytag
These days, everyone offers front loading washers and dryers. The things to know about them, is that unlike the old style top loading washers (and even the very old type of front washers from 20+ years ago) is that they function much differently.
First off, remember that you should only use He (High Efficiency) detergent and that the amount you'll be using is much less as well, so you'll have to change your habit of pouring in too much, as it will cause you problems.
You'll also need to get used to the different noises, or lack of, when the washer is running. Except for the spin cycle, you'll hardly know its running. Now about the spin cycle, most front loading washers go into "turbo" mode and get going very fast, which is great since it leaves the clothes barely damp in most cases when you take them out.
Now for the not so good issues with front loading washers. You'll want to also change your wash day habits by doing starting your laundry washing with the cold water washing first and finishing with your whites or hot water washing as the last load you do. The reason for this is that front loaders tend to retain just a little bit of water in them when they're done, and by doing the hot water loads last, you give the washer the best opportunity to keep any odor forming bacteria the least chance to start with.
Another key thing that none of the front load washer makers tell you to do is, keep the door of the washer open slightly when you're done with your laundry, as the door gaskets will hold some water and that is part of where the moldy smells, that many people experience, comes from. We've found that by doing that little thing, along with an occaisional wiping out of the door bellows gasket, keeps our washer from having any nasty odors.
Some folks recommend using special tablets once a month (Whirl-out), but I have an adversion to doing a "load" without clothes and hot water, and an cleaning tablet - seems to me that kinda of defeats the whole "less energy-less cost" premise of efficient front loaders. So by leaving the door open, we've avoided all that and haven' had the odor problems at all.
OK, by now you're wondering when I'm going to give you something on the Maytags you wanted to know about! Almost any front loading washer will do a great job and provide you with a decent working life. I prefer the GE, Maytag, Whirlpool, Kenmore, etc., but really don't like the LG's. My reasoning is that the LG's seem to have more issues with torn door gaskets and error codes than the others. While the LG's look nice and most folks buy them because they're so darned pretty, they are a disappointment in where it really counts, in my opinion.
So buy any of the American made washer/dryer units mention and you'll be very pleased with them, and by the way, the Maytag 3000 series, do look pretty nice too!
Take time to read your manual with your new appliances and you'll be ahead of most folks and get the best performance out of them for years to come!
Hope you find this Very Helpful and best regards!
Posted on Oct 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: getting f21 error on my front loading 3000 series
F21 is too long to drain:: (more than 4 mins) Check your drain hose outflow into a couple of 5 gal buckets it should flow pretty fast. If not, there is both a suds sensor and the water level pressure switch that can be causing the problem. Since you do not have SUDS showing on your control panel I am assuming the suds sensor is fine. The water pressure switch itself can cause the problem even if you hear audible clicks when testing with an external hose. A clogged drain pump strainer can do the same thing. Lastly... the obvious... is the drain hose kinked???? Good luck and hope this helps.
Posted on Jan 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Rreceiving error code F71, washer willl not work,
USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving.
Just remove the three screws in the back the top will slide off. You will then see the controls and harnesses just check them for loose connections!! The connections are all plug and play type.
Remove the screws and push the top towards the wall and it will pull up.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: F71 CODE ON WHIRLPOOL DUET WASHER-WON'T RESPOND
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Posted on Sep 15, 2010
My whirlpool cabrio washer wtw6200vwo shows f71code and wont spin out clothes
WHIRLPOOL CABRIO WASHER ERROR F71. The Cabrio Washer Error F71 code is the same as the SD code: This error means the main control board detects too much drag on the basket during the spin cycle.Mar 29, 2017
Nov 13, 2017 | Whirlpool Washing Machines
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Maytag 3000 series front load washer has code F29. What does hat mean?
That error is a control board error. You might want to try unplugging the power for 5 minutes to see if it resets. If you using the pause cancel and start sequence don't work then you need to replace the control board.
Oct 04, 2014 | Maytag Washing Machines
Maytag 4000 get a f71 error code
Is this for real! My 2 year old Maytag 4000 series washer that I paid over $600 for needs a new $300 + part to fix it! It's so pathetic how things are made these days.
Jun 08, 2012 | Maytag Washing Machines
There is an error code f70 and there was an error code f71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW9400S Logo
216 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
