Question about GE GSS25SGMBS Side by Side Refrigerator
Where (specifically) is the defrost timer located on my GE GSS22JEMD (Side by Side) Refrigerator? How Do I check to see if my thermostat is working or not? Please help.
  • GE Master
  • 4,655 Answers
The timer is controlled inside the control board on rear of your refrigerator. Four possibilities are the defrost element, defrost thermostat, Temperature CLIP EVAP THERMISTOR or the control board is defective. Let me know if you would like me to help you on this, Thanks, Sea Breeze
Posted on Jun 16, 2009
  • John Tripp
    John Tripp Jun 16, 2009
    If you turn the refrigerator thermostat to its lowest setting and the compressor shut of until the temp goes to that setting to come on is one way to check it. Those messages are also sent to the control board part number WR55X10656
    Photo at this link below
    http://servicepartstec.blogspot.com/
How to replace defrost timer
There is not a defrost timer on a model PSC23NGN. If your model is the=> PSC23NGN and the refrigerator is not defrosting the problem is most likely the Defrost Heater and Defrost Thermostat that need replaced. The heater is item location 230 and the defrost thermostat is item location 240 in this photo=> HERE
The part numbers for the Defrost Heater are WR51X10055 Defrost Heater Assembly The part number for the Defrost Thermostat WR50X10028 Defrost Thermostat
I am here if you have questions, Thanks John Tripp
Appliance 911
Contact me here.
Jul 06, 2014 | GE PSC23NGN Side by Side Refrigerator
Freezer is not deforsting
If your model you listed is a TFX27PRBWW it will have a defrost timer located in the fresh food compartment and behind the controls. It's location is 257 in this photo HERE I would like you to turn the timer clockwise slowly until youi hear the compressor and fans stop. This should put the refrigerator into defrost if the defrost heater is still working. Did you hear any crackling or sizzle when place into defrost this way? Wait up to 35 minutes for the timer to come out of defrost and it should restart the refrigerator compressor and fans. If it does not come on automatically then simply turn the timer slowly clockwise again until they do restart. If you need to turn timer again to start refrigerator you will need to replace the timer=> WR9X489 Defrost Timer
If the defrost timer is not the problem then we move to the freezer side, remove the rear panel of freezer and defrost the frost covering the evaporator as in this photo HERE The model TFX27PRBWW takes a=> WR51X10055 Defrost Heater Assembly
and the defrost thermostat=> WR50X122 Defrost Thermostat
The defrost heater is location 230 and the defrost thermostat is location 24 in this photo HERE Instructions in testing these parts are located on the parts pages I listed above. Please let me know if the model number is different than the one above your post so I may help you better, Thanks Sea Breeze
Feb 01, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
The defrost timer where is it located in a ge refrigerator
HI would need to know model, but if it has a timer and its a top mount it will be located in the panel by the thermostat inside the refrigerator, if its a side by side its in the same place right inside the panel by the thermostat control. If its newer than 2001 it will not have a timer.
Sean
Mar 25, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Defroster not working
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Jan 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
DEFROST CYCLE IN FREEZER NOT WORKING PROPERLY BUILD UP OF ICE ON THE OUTSIDE/INSIDE OF ICE DESPENSER
1. Check defrost timer. 2. Check defrost thermostat. 3. Check defrost heater. One of this are more than one may be defective replace.
First, locate the defrost timer which may hiddenbehind corners of the fridge at the back bottom, in some models located in theceiling of the fresh food section or behind the cold control cover. Once youlocate the defrost timer, slowly turn the screw in the middle of the defrosttimer with straight screwdriver until the fridge shuts off. Now it's indefrost. If the defrost heater(s) starts, replace the defrost timer and defrostthermostat. If the heater(s) does not start, unplug wire cord to check ohm testfor continuity of heater. If continuity is there, plug cord wire which givespower 120volts (check specification) to heater. If heater no starts, bypassdefrost thermostat by join the 2 wires in the defrost thermostat. If the heaternow comes on, replace the defrost timer and defrost thermostat. If the heateritself is bad, replace it. Thanks and hope helpful
Jan 29, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cold
Your problem could be a defrost component issue (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
Apr 13, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ge frig does not freeze on freezer side
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side is freezing in the back of freezer, I have to defrost once a month. How do I check what parts I need and how to fix it
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge has power. But the temperature control has no power. I have a G.E. side by side. model # gss25tgpa
Check the defrost timer. It may be stuck in the defrost position which would give you no power to the temperature control. Locate the timer and rotate the clutch head screw clockwise and you should hear a click after which the compressor will start and there will be power to the thermostat.
May 24, 2008 | GE Refrigerators
GE GSS25SGMBS Side by Side Refrigerator Logo
353 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
