Question about Jado 842/701/105 Hatteras Single Lever Monoblock Vessel Faucet with .5" Val
Installation of lever - a guest has pulled it out. How do I re install it
  • 21 Answers
Look for an allen key hole  with a small set screw inside.  you need the right size allen key loosen the set screw then push back on and screw back tight.   let me know if this works.    plumbser
Posted on Jun 21, 2009
My bike was running perfectly fine, until I changed the clutch lever. I got an after market shorty lever, and installed it just as the oem one. Now it will crank, but not shift without dying...?
Hi, Matt my thoughts are the shorty lever pull distance may not be the same as your Oem lever and is confusing your clutch safety switch/sensor for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Installed new clutch lever Now Clutch will not engage
New clutch bike stalls when put in 1st PLS HELP 05 R6
http://www.apriliaforum.com/forums/showthread.php?253387-Help!-Installed-New-Levers-and-Clutch-Won-t-Disengage
Installed new clutch lever now no start
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 30, 2015 | Motorcycles
When loading the disk for installing my 2nd hand lexmark x2250 printer and clicking install, it comes up with an error page?...
You may be logged on your computer using a guest account. A guest account can access the computer but has limited rights and permissions (e.g. downloading applications, computer configuration changes, install software or hardware). Please ask your technician or access the Administrator account to successfully install the printer driver. You may also ask the owner of the Administrator account to grant you additional rights and any permissions to your guest account for future changes.
Jan 12, 2012 | Lexmark X2250 All-In-One InkJet Printer
Diagram for parking brake cables
Removal & Installation
  1. For the 1500HD, relieve the tension from the park brake cable by pulling down on the park brake cable in front of the equalizer then removing the cable from the equalizer bar.
  2. For the 25/35 series Disable the park brake cable automatic adjuster.
  3. Raise and safely support the vehicle.
  4. Remove the tire and the wheel.
  5. Perform the following procedure to remove the cable (2) from the backing plate (4):
    • Compress the spring (3) by pushing toward the lever (1).
    • Depress the locking tabs.
    • Pull the cable housing out of the backing plate (4).
    • Remove the cable (2) through the slot in the backing plate.
      Lever (1), cable (2), spring (3) and backing plate (4)
  6. Remove the park brake cable (2) from the lever (1).
  7. Remove the rotor.
  8. Remove the rear axle shaft.
  9. Remove the park brake shoe return spring (6).
    Park brake shoe assembly 1500HD, 25 and 35 Series
    Click to Enlarge
  10. Remove the park brake shoe anchor springs and pins.
  11. Separate the tips of the shoes from the park brake actuator and remove the park brake shoes and adjuster assembly from the vehicle.
To install:
  1. Clean the debris and the dust from the park brake components using a clean shop cloth.
  2. Install the adjuster assembly to the park brake shoes.
  3. Separate the tips of the shoes and install the park brake shoes to the park brake actuator.
  4. Install the park brake shoe anchor springs and pins.
  5. Install the park brake shoe return spring (6).
  6. Adjust the park brake shoe.
  7. Install the rear axle shaft.
  8. Install the rotor.
  9. Install the park brake cable (2) to the lever (1).
  10. Perform the following procedure to install the cable (2) to the backing plate (4):
    • Compress the spring (3) by pushing towards the lever (1).
    • Route the cable (2) through the slot in the backing plate.
    • Push the cable housing into the backing plate (4) until the locking tabs snap into place.
  11. Install the tire and wheel.
  12. Remove the safety stands.
  13. Lower the vehicle.
  14. Enable the park brake cable automatic adjuster.
  15. For the 1500HD, install the park brake cable to the equalizer by pulling down on the park brake cable in front of the equalizer then installing the cable to the equalizer bar.
  16. Adjust the park brake cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 23; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos'; shinehutt_0.gif
Jan 13, 2011 | 1995 Ford F150 Styleside Regular Cab
Installing new OS
Hi mcniester,
If you need to install Ti Connect software, goto the paragraph (1) below. If you do not need to install Ti Connect software goto the paragraph (2), "Procedure to installing the newest Ti 84 Plus OS 2.35v."
1). You can get the latest copy of Ti Connect software by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti Connect software" At this Ti site under "View: Connectivity Software", Click, "the OS link that applies to your computers operating system". Next, click the Download Item, "Ti Connect software for ....OS". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti Connect software for ....OS will be download to you. Click, "OPEN" and the software will start installing. You will have to click "Next" a few times but, it install pretty fast. Once the Ti connect software has successfully installed follow the instructions to the
"Procedure to installing the newest Ti 84 Plus OS 2.35v." below.
2). You can also get the latest copy of Ti84 Plus 2.35v OS and guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.35v. OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system download to you. Click "SAVE" And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed.
Link your computer and calculator with the USB cable or Direct Black Link cable that came with the calculator. Next, drag the Ti 84 Plus OS 2.35v that you copied to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti connect" icon on the desktop. Click, "Continue" and, the new Ti 84 Plus OS 2.35v will begin to install. The Ti Device window may pop up and, click on to the port your Ti 84 Plus is using, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 84 Plus OS 2.35v will be installed.
Jan 06, 2011 | Texas Instruments TI-84 Plus Calculator
How to installing brake shoes on back ?
First you have to compress the parking brake cable spring and attach the parking brake lever.
Clean and lubricate the brake backing plate.
Use silicon Brake Caliper Grease and Dielectric Compound.
Then,
install the rear brake shoes and linings:
1) position the rear brake shoes and linings
2) position the parking brake lever
3) install the brake shoe hold-down spring pins and the brake shoe hold-down springs.
Install the parking brake strut
1. install the parkig brake link spring on the parking brake strut
2. install the parking brake strut
3. Install the brake shoe anchor ping guide plate.
Install the short brake shoe retracting spring
1. Place the brake shoe adjusting lever cable over the anchor pin, with crimped side in
2. Install the short brake shoe retracting spring
Note: Make sure the brake shoe adjusting lever cable is positioned in the cable guide groove
Install the long brake shoe retracting
1. install the cable guide
2. position the brake shoe adjusting lever cable in the cable guide groove
3. install the long brake shoe retracting spring
Note: to prevent incorrect installation, teh socket of each brake adjuster screw is stamped R or L
Assemble the brake adjuster screw assembly.
1. apply silicone brake caliper grease and dielectric compound
2. install the brake adjuster screw into the brake show adjusting screw nut to the end of the threads and then loosen one half turn
3. install the brake shoe adjusting screw socket on the brake shoe adjusting screw nut.
Install the brake adjuster screw assembly
1. Position the brake adjuster screw assembly
2. Install the brake shoe adjusting screw spring
3. Position the brake shoe adjusting lever cable
4. Position the adjusting lever return spring and the brake shoe adjusting lever
5. Hook the brake shoe adjusting lever cable to the brake shoe adjusting lever.
Test the operation of the automatic self-adjuster
1. Pull the brake shoe adjusting lever cable and check that the brake shoe adjusting lever rotates the brake shoe adjuster assembly
2. Release the brake shoe adjusting lever cable and check that the brake shoe adjusting lever advances to the next notch on the brake shoe adjusting screw nut.
Adjust the brakes.
Install the brake drum.
Thats it
Sep 10, 2010 | 1998 Ford Ranger SuperCab
Yahoo msngr not working in guest login
1. you have give all rights to guest so that you can install
2.reinstall msngr
regards
prakash
Mar 18, 2010 | Yahoo Messenger
I can't locate the starter solenoid on my 2000 chevy silverado. Where is it?
(Starter) Solenoid - Removal & Installation
  1. Remove the starter motor.
  2. Reposition the M-terminal stud weather cover.
  3. Clean the epoxy coating from the M-terminal stud.
  4. Loosen the M-terminal stud nut.
  5. Remove the cable from the M-terminal stud.
  6. Remove the solenoid bolts.
  7. Separate the solenoid from the housing and unhook the solenoid plunger from the drive gear lever.
  8. Note that the spring (3) is positioned against the drive gear lever (1) and the drive gear lever is placed inside the solenoid plunger loop (2).
    Fig. Spring (3) is positioned against the drive gear lever (1) and the drive gear lever is placed inside the solenoid plunger loop (2)
  9. Remove the solenoid housing.
  10. If necessary, remove the solenoid plunger and spring.
To install:
  1. If necessary, install the solenoid plunger and spring.
  2. Using Three Bond silicone 1207B, GM P/N 97720043, seal the starter solenoid attachment area.
    WARNING Make sure that the drive gear lever (1) is properly installed into the solenoid plunger (2) loop. Improper installation of the drive gear lever will cause an abnormal or no operation condition of the starter.
    Fig. Make sure that the drive gear lever (1) is properly installed into the solenoid plunger (2) loop
  3. Install the solenoid, making sure to insert the drive gear lever (1) into the solenoid plunger (2) loop, perform the following:
    1. Pull the gear lever (1) out away from the starter housing and pull the plunger (2) out away from the solenoid.
    2. Tip the solenoid and insert the lever into the loop, push the solenoid against the housing.
  4. Install the solenoid bolts and tighten the bolts to 89 inch lbs. (10 Nm).
  5. Wipe the excess silicone pressed out during the solenoid installation from around the base of the solenoid to make a weather proof seal.
  6. Install the cable to the M-terminal stud between the washers and terminal nut.
  7. Tighten the M-terminal stud nut and tighten the nut to 71 inch lbs. (8 Nm).
  8. Using Three Bond silicone 1207B, GM P/N 97720043, seal the M-terminal stud connection.
  9. Reposition the M-terminal stud weather cover.
  10. Bench test the starter in a free-run condition prior to installation.
  11. Install the starter motor.
To install:
Hope helped with this (remember rated this help) Good luck.
Nov 04, 2009 | 2000 Chevrolet Silverado
My transmission will not go into park. how do i fix that
  1. Install the shift cable end of the shift cable to the transmission shift lever stud ball.
  2. Install the retainer to the shift cable and transmission bracket.
  3. Feed the shift cable through the floor panel.
  4. Lower the vehicle.
  5. Adjustment Procedure
    1. Ensure that the shift cable is not restricted.
    2. Place the shift lever into the NEUTRAL position.
    3. Position the shift cable to assume a natural routing. The shift cable must be free to move 20.0 mm (0.80 inch) axially during the adjustment under adjustment spring loads.
    4. Pull the cable end completely forward and release it. (When the cable is pulled completely forward and released, the adjustment spring will position the cable to its most rearward position.) Notice: Do not pull the shift lever ball stud forward of the transmission shift lever ball stud during installation. Pulling the shift cable end forward of the transmission shift lever ball stud before installing the shift cable end to the transmission shift lever ball stud will result in a poor adjustment.
    5. Connect the end of the shift cable to the transmission shift lever stud ball.
    6. Press the locking tab IN in order to secure the shift cable to the transmission bracket.
Oct 13, 2009 | 1984 AMC American Motors Eagle
Just want to know how to replace brake lever correctly. I just bought this bike, took a safety course, and now I'm riding. I am very new to street riding so I'm extra cautious. However, I accidently broke...
This is a 1999 SV650, right? The brakes are hydraulic. The cable, is it on the left hand? This is a clutch cable. i suppose that makes no difference in the installation, though, so here goes:
There is a bolt with a nut on the bottom of it in the middle of the pivot for the lever. Loosen and remove this bolt and nut and slide or pivot out the old lever. Turning the lever towards the front of the bike, you will be able to release the cable. Using this same technique in reverse, install the new lever and you are all set to ride!
If the lever is on the right, it IS the brake lever and its installation is super-easy. No cable to deal with, just the bolt and nut and you are done.
Have fun, be safe,
matt
Sep 15, 2009 | 1999 Suzuki SV 650
Removal of gear shift knob
There are two types of shift knobs. One that unscrews and one that the lower trim of the shift knob separates from the knob using a trim stick. After separating the lower trim from the knob pull upward to release the knob from the shift lever. If a new shifter assembly is being installed, unscrew the original shift knob or separate the lower trim from the knob and pull up to remove the knob from the shift lever. Screw the knob onto the new shifter assembly's lever no more than 14 turns or install the lower trim onto the shift lever then push the knob onto the shift lever and install the lower trim piece onto the shift knob.
Jul 02, 2008 | 2007 Dodge Magnum SRT8 Wagon
Jado 842/701/105 Hatteras Single Lever Monoblock Vessel Faucet with .5" Val Logo
170 people viewed this question
Top Jado Plumbing Experts
loft404
loft404
Level 1 Expert
ccpanel
Level 1 Expert
Are you a Jado Plumbing Expert? Answer questions, earn points and help others
