Question about Pyle Audio Players & Recorders
I can Record off my Pyle Pro PMX401 but I can't get any output to my speakers.
  • 1 more comment
  • hwcoul Jun 16, 2009
    I opened it up and checked the connections. I did not find any loose or cold solder joints.
    I check all of that. I am able to record out to a tape deck, however it will not accept input from that same tape deck, nor will it drive the speakers attached to the PMX.
    We tried.
    Brigadier General:
  • 8,619 Answers
Hi
First check for loose wires if thats not the issue then you need to open up the unit and check for loose connections/cold solder joints.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 16, 2009
  • Rylee Smith
    Rylee Smith Jun 16, 2009
    Have to tried to clean the unit for dust?? Did you check for any burn capacitors/transistors on that?? Have you checked the wires if they are burned or broken and might need replacement.
    Thanks
    Rylee
  • Rylee Smith
    As you have already checked everything then I believe its time to change the unit as replacing the motherboard might cost you as much the amount in which a new unit can come.
    Thanks
    Rylee
On my pd3000a receiver I have two subwoofer rca jacks but I have a sub volume control so can I still hook up pqa4100 poweramp this is all pyle equipment, please give detailed answer
First, I'm not a Pyle tech. But back in the day I used to be an audio freak (1970's 4 channel all-the-way!)
* I tried to get the exact specs on your receiver but I suspect it's a non-amplified output. RCA jacks almost never have a high level output. (yes, the old 1940-60's used RCA jacks for speaker high level output. But you have a late model receiver.) Most likely you need a separate amp to power the sub woofer (unless it has it's own power amps.) You may still use another audio amplifier if you have a spare (mono or stereo won't mater as you only use one channel) but be aware that low frequency use way more power than normal frequencies (600 to 3KHz) The low end (50 to 300 Hz) will burn out any speaker and amp as the lower the frequency it's like hooking up a car battery directly to the speaker! If you have an old style vinyl record player that's playing a warped record. watch the speaker flap around to the wave of the record. Need to turn on the 50 Hz cancel out button to prevent speaker blowout!
* This link is still for a powered woofer. It looks like the same PD3000 receiver as yours though I can't be sure:
https://www.youtube.com/watch?v=OXEtib5OnGI
* This is an external "Powered" sub woofer (powered amp and additional cross over "filter" to extract just the lower frequencies. The following you tube link is a detailed example of how this type of system works:
https://www.youtube.com/watch?v=ZpSAQDjuWN0
Aloha, ukeboy57
May 11, 2018 | RCA Audio Players & Recorders
It does not power up
Check the fuse first.
Most have one where the power cable goes into the unit, a little plastic cover, you pry it out. Some of them even have a replacement in there.
If not, or it blows again, you have to get inside, and maybe you got a blown supply or regualtors....
Take it to a Tech.
Peace-
Dec 03, 2015 | Pyle Pro Pmx401 4-channel Powered Pa Mixer
Pyle troubleshooting
probably something wrong with speaker
Sep 08, 2014 | Pyle Pro PPHP106A Powered Two-Way PA...
Speaker output not working on my Pyle Pro p3001at amplifier
The question of home repair vs professional depends upon your degree of confidence in your skill level.
Nov 27, 2013 | Pyle Pro P3001at Hybrid Amplifier & AM/FM...
Mac is not recognizing the Pyle Pro PPR 80
Same here! Have you figured it out? Im running 10.6.8
Sep 17, 2013 | Pyle pro Ppr80 Digital Portable Stereo...
How do i connect my av30 speakers to my Toshiba tv? I have tried everything and am unable to get sound from the speakers. I have 2 sets of these speakers and would love to listen to my tv with them. I also...
Connect left and right audio outputs on rear of TV to corresponding inputs on rear of your Pyle receiver. You may have to go to the initial set up procedure on your Toshiba TV to disable internal speakers and direct audio output to the Pyle receiver.
Dec 04, 2017 | Audio Players & Recorders
Would I need a mixer or amplifier with this product: Pyle-Pro Rack Mount 8 Channel Wireless Microphone System with 8 Lavalier/Headsets (PDWM8900)
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Aug 20, 2011 | Pyle PRO 19 RACK MOUNT PRO DJ MIXER SFX
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Pyle pldr106
just buy a convertor and tap into your speaker levels and presto.
Dec 10, 2007 | Pyle PLVW20T 20 in. Car Monitor
50 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Marvin
Marvin
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
