Question about Vehicle Parts & Accessories
Security light is flashing and there is no crank
  • 33 Answers
Not much information here, but you may need to have your computer scanned and find out what the trouble code(s) are before continuing.
Posted on Jun 20, 2009
1998 oldsmobile 88 anti-thef system cause no power to fuel pump?
Is the SECURITY light lit on the insturment cluster ? Does the engine spin with key in start position ?
Vehicle Theft Deterrent (VTD) System Check
Attempt to start the vehicle.
NO - The engine cranks and starts.
Refer to Engine Cranks but Does Not Run in Engine Controls.
Note the security indicator while attempting to start the vehicle.
The indicator light is ON and OFF after approximately 5 seconds.
• SECURITY Indicator Always On or Flashing, Engine Does Not Crank
• SECURITY Indicator Always On or Flashing, Engine Starts
* Refer to the appropriate symptom diagnostic table for the applicable abnormal result.
Engine Cranks But Does Not Run !
Feb 18, 2017 | 1998 Oldsmobile 88
2002 Trailblazer security light on, will not crank, replaced steering column
Did you use the original key and lock cylinder? They are coded for the security system.
Dec 31, 2016 | 2002 Chevrolet TrailBlazer
What could keep my coil from firing ? I have the Ignition control signal and 12v. while cranking over engine at the top primary wiring of coil. Can you help me get spark?
Sounds like the security system is causing your problem. Is the "security" light flashing? If it is, turn the key on, leave the key in the ON position for 10 minutes. The light will stop flashing. Now, turn OFF the key, turn it back to ON, and then crank it. It should start. If the security light starts flashing again, go through the process again until it starts. This is resetting the security system after the battery has died, battery has been changed, radio was changed, instrument cluster was removed and replaced, etc. Hope this works for you.
Mar 29, 2016 | 2001 Chevrolet Silverado 1500
2005 chevrolet impala won't crank, security lihgt flashes
possibly has flat battery and the security system has lock in get new battery and try then, you will have to lock and unlock via fob after fitting new battery to reset the security system good luck
Apr 27, 2014 | 2005 Chevrolet Impala
Mazda 6 security light
sounds like key is bad maybe worn out,have you used different key recently
Mar 23, 2014 | 2004 Mazda MPV
Security reset
Depending on the make model and year, did you have a key cut to match the new lock cylinder and the old key chip ?
Jul 06, 2013 | Cars & Trucks
Reset security system
To review - the factory VATS security system will not let the engine crank or start if the wrong key is used or there is a problem with the system.
So if the engine was cranking the security system was not at fault.
You may have to get a used shop manual to get the testing procedures for a no start-stall problem.
Feb 25, 2013 | 1999 Chevrolet Cavalier
Buick security light flashing? How to reset security?
If you have a remote key fob for your locks etc it very much sounds like the battery is dead which will cause the car to"lockdown" so-replace battery. Good luck!
Jul 11, 2012 | 1996 Buick LeSabre
Security light flashes car cranks but won`t start any way to bypass security .
turn key on for 10 minutes until light stops flashing then try to crank car over
May 23, 2009 | 1999 Oldsmobile Alero
Security light flashing
Take the Original Ignition key out to the car. Get in it and turn the key on. Every light should light up like your going to start it. The factory security light will flash. Leave the ignition on until it stops flashing. Should take about 10-15 min to do it. once it does, shut the key off and then turn it over to start the car.
Aug 04, 2008 | 1998 Chevrolet Lumina
Vehicle Parts & Accessories Logo
69 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
