Question about Intel Pentum 4 3.2Ghz System (SYP32) PC Desktop
Error codes it gives is either code 4 setupdd.exe not found
Hjukljh
    Problem Solver:
  • 12 Answers
Change ur cd rom drive or disk or both
Posted on Jun 16, 2009
'm installin win xp on my pentium3 with 10gb harddisk n 256 mb ram... it shows setupdd.sys could not be loaded error code 7 durin installation.. i tried change d xp cd 3 times.. still hav same problem
change the cd-rom unit,i know it sounds crazy but try it before you waste anymore blank discs,im a tech and that is one solution that works ,good luck
Feb 27, 2011 | Computers & Internet
Setupdd.sys error code 7
CHANGE MEMORY OTHERWISE CHANGE OS CD
Mar 21, 2010 | ASUS P4B533 Motherboard
Help on reformating pc!!!
Use different CD installer or burn your present WindowsXP to another disc. Your files might have been corrupted due to poor disk surface of your Windows Installer.
Jan 21, 2010 | Acer Aspire T310 PC Desktop
Sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe ...
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
Aug 07, 2009 | Computers & Internet
Pci bus controller
setupdd.sys can be found on your windows xp cd.
Feb 28, 2009 | Dell Dimension 4300 PC Desktop
1999 Honda Civic EX fault codes 1366 and 1399
This code is not documented so the code reader is giving a false reading.
If the car runs OK and check engine light is not on, I would forget about it.
Nov 25, 2008 | 1999 Honda Civic
PROBLEM
here are some link for the error codes hope this helps.
ERROR CODE 7( NTKRNLMP.EXE) .http://support.microsoft.com/kb/812580
ERROR CODE 4 ( SETUPDD.SYS) .http://support.microsoft.com/kb/330181
Sep 18, 2008 | Toshiba Computers & Internet
Help with a toshiba TECRA 8100
Yes, it should run WinXP. The minimum system requirements to run both Windows XP Home and Professional are 233Mhz, 64Mb RAM and 1.5GB hard drive space. I have a Toshiba Tecra 8000 that still runs XP, a little slow, but has run smoothly for 5 years.
The setupdd.sys error is most likely a due to a defective hardware like RAM. Try installing only one ram if you have two to see if either one is defective; it should work for most users.
Sep 09, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
System Code Error 87
Sounds like the application you are running may not be compatible with Windows 98. Probably can't do much as Windows 98 is so old.
Although it may be a missing file, DLL, or driver on your Windows 98 system, hard to tell.
Jan 11, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
186 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
