Question about JVC SR-VS30 Mini DV/S-VHS VCR
My VCR doesn't record from my Digital TV. It did before.
Everything was running great until 6/12/09 transition. Now my VCR
won't record. I can see movies but it won't RECORD and I do alot of
recording due to my busy schedule. Why is this happening?? I tried
for 3 days and can't understand why it doesn't record.
  • 199 Answers
Your VCR does not have a digital tuner. If using an antenna or basic cable, you must decode the digital signal through the D/A converter first, then send the signal via the RF cable (Screw -on ) or Audio/Video RCA to the VCR. You will have to manually press record. My guess is that you were used to programming and leaving it. So, if you are/were using your VCR as a tuner to schedule recordings, it is no longer a valid option. If you have a cable or satellite box with a DVR, this is the way to go. I am not sure if anyone offers a VCR with a digital tuner. Google and discover. Unfortunately all those hours (years in some cases) we spent learning how to program our VCRs is now in vain.
Posted on Jun 16, 2009
I have a hdtv with digital channels. I also have a vcr that can record shows. The thing is i have everything set up correctly. How do i record the shows on tv to my vcr?
A VCR will not record HDTV signals. You can only record normal digital signals. If you wish to record HDTV channels you should look at Blue Ray Recorders.
Sep 28, 2013 | Televison & Video
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
Comcast Digital Conversion box (cable TV)
You will have to split the signal before it goes into the digital box. The digital box is not allowing the analog signal to go to your vcr so you will only be able to record what you are watching on the cable box (on channel 4). If you split it, you will get all your analog channels back on your VCR (the way it was before the box was added).
Jun 29, 2009 | Allegro DVD/VCR ABV511
My VCR not recording after the switch to digital tv signal
The answer to this question can get a little complicated. Lets tackle it in two parts. First the last part; the part about picking up channels as decimals. With analog TV transmission, it took the full television broadcast channel to transmit one standard definition TV program. The newer digital transmission system uses some advanced video compression and audio compression technology to reduce the data needed to transmit the pictures and sound which allows the same bandwidth to deliver either High Definition Television programming or MULTIPLE channels of Standard Definition programs. So in your example above, you use to watch one channel of programming on TV channel 4, but now the TV station can broadcast multiple channels of programming on channel 4, sot they delineate the programs with a decimal point. So 4.1 it the first program on TV channel 4, 4.2 it the second program on TV channel 4..... Well, I hope you get the idea.
Now for the hard part of your question. I believe that before the transition, even with your new digital TV, you were still enjoying the analog broadcasts from your stations. Your VCR picked them up and recorded them and your digital TV could tune them in and you watched as you had always done in the past. After the transition you noticed that your VCR could not record anymore and your digital TV had discovered the digital channels that replace the analog channels. To remedy this situation, your VCR will need the aid of a DTV converter box to tune channels, and you may have to reconfigure the way your TV and VCR are connected. The best resource that I can give your for the reconnecting is the website http://www.fcc.gov/cgb/consumerfacts/converterbox_vcr.html. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Scroll down to the Normal 0 false false false MicrosoftInternetExplorer4 section about “Set-up #2: Watch One Channel while Recording a Different Channel”.
Hope this helps
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
Sound problems with recording to vcr using converter box
If your TV has no scart connection, no HDMI connection, then to be honest I would get a new set. There are plenty of good second hand models around, which will be better than your old set and come with a digital tuner built in.
As for the VCR, that should have a scart socket and so should the converter box. Once connected via the scart socket you should be be able to record the shows easily. If the converter box comes with a volume control, you might need to set that up to get it right. If the VCR has two scart sockets use the second one to connect the box. Use the first to connect to the TV for viewing your recordings only.
If it has only one scart, then look around on Amazon for one of these scart switching boxers.
Mar 19, 2017 | Insignia Digital-to-Analog Converter for...
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
Getting my VCR to record from the TV with a converter box hookup
Hook up antenna to converter box then from that out to the vcr's input (red,white, yellow connections are better than coaxial).
Jan 20, 2009 | Insignia Digital-to-Analog Converter for...
VCR with intermittant audio and video problems
you have to connect VCR output cable to your TV input, thats all, it will be in series, if u want to record any program then on your TV and on record switch of your VCR.
Dec 30, 2008 | Sony SLV-N55 VHS VCR
VCR won't record
Check to make sure the cables on the VCR are hooked up correctly. If the in and out are reversed, this might cause your problem. Hopefully it's as simple as that. if not leave a comment and I'll get back to you.
Oct 03, 2008 | Quasar VHQ400 VHS VCR
JVC DCD Recorder hookup to digital TV
Yep, this recorder is NTSC analog. Sad, too - it was only manufactured in 2006 - they knew about the digital transition then. There is a possible workaround, but it depends on your TV - if your TV has a red, white AND (most importantly) yellow OUT/OUTPUT, then you can hook it to the AV IN on the back of the JVC and record from TV that way. Note: most TV's (even new ones) do not have the yellow video/monitor OUT, even if they have red and white audio OUT's.
-Tha Mp3 Doctor
Sep 03, 2008 | JVC DR-MV7 DVD Recorder/VCR
JVC SR-VS30 Mini DV/S-VHS VCR Logo
596 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
