Question about HP OfficeJet 7410 All-In-One InkJet Printer
Remove and check cartridge--tried it a dozen
Remove and check cartridge--tried it a dozen times, did the driver download and still no luck. what now?
    Guru:
  • 224 Answers
Its not a software issue.try changing the cartridge if you still face the issue go ahead and clean the copper contacts on the cartridge with a cotton swab dipped in water. Then clean the copper contacts inside where the cartridges sit.
If you still face this issue call in to hp at 1800-474-6836 cauz this could be a hardware malfunction with the printer and so ask for an upgrade you will get atleast a 50% discount on it with hardware as well as phone support on the upgrade and then u can extend the warranty of the whole printer by 3 to 4 years.
Try this hope this will help you
Posted on Jun 16, 2009
"The yellow 'Alarm' light will not go off after changing cartridges.
Try removing and reinserting the cart. Or try a new cart. It sounds like it's not recognizing that a new cart has been inserted. It could be a faulty/sticky switch where the cart is detected.
Jun 21, 2012 | Canon Office Equipment & Supplies
Can I remove & clean the print head on an Epson printer?
i've tried to remove it from the sliders and to have it soaked in alcohol for about 10 hours without any luck. It is too much work without any guarantee. I suggest to junk it and get a new one (if possible with heads on the cartridges so they are replaced with each refill)
Mar 09, 2012 | Office Equipment & Supplies
Hp 3180 fax
have you checked to see whether you need updated drivers for the printer.
Worked for me
Jan 12, 2012 | HP Office Equipment & Supplies
When ever i click on to any thing inmessenger it says application not found have tried to re down load at least a dozen times still no good
Hi, it is a bit odd problem. Try with installing "all-in-one" messenger called Trillian. You can download it HERE.
God luck, Kobac
May 23, 2011 | Yahoo Messenger
MFC-490CW Won't print black
We are going to attempt to do a "power purge" to get rid of any clogged ink nozzles. Note, this will probably eat up about half of your ink, but that is the price you must pay in order to attempt to fix this bad boy.
1) Get into maintenance mode. Press these keys: Menu -> Black Start -> Scan x4 (hit it four times). A number pad should come up. If not, do it again.
2) Hit key 7, then key 6.
3) Press the right key until you get to "CLEANING BLACK."
4) Press 3.
5) Press Black Start.
After it purges and gets back to the main maintenance screen, press keys 9 and 9.
Let your printer start back up. If this does not work, try the above steps up to three times. If it does not work then, you need a new print head, which is not a user-replaceable part on this model.
Good luck.
Aug 05, 2009 | Brother MFC 490cw Color Inkjet...
My audio doesent work Ive tryed dozens of times to get the drivers but I cant please help p.s. I have gateway E-2000
darylsg,
I see you have two posts for the Gateway E-2300.
From time to time software does not install when using the software's *.exe file.
There is another way to install driver software when using windows. Create a folder on your desktop & name it sound. Download the driver file named, Soundmax5240.exe, from Gateway's web site into this folder. You'll need to uncompress the *.exe driver file. You may need Winzip to help you to do that.
You can download the trial version for free. Click on the next link for Winzip; (Download version 9.0);
http://download.cnet.com/WinZip/3000-2250_4-10003164.html
Once installed open the folder named sound. Right click on the file name " Soundmax5240.exe " & from the pop-up window find winzip & click Extract to here. (All files will uncompress within the folder).
Sound driver link;
http://support.gateway.com/support/drivers/getFile.asp?id=20099&dscr=SoundMAX%20Integrated%20Digital%20Audio%20DriverVersion:%205.12.01.5240&uid=230675307
Install through windows device manager. (Here's how to do this).
Right click once on My Computer & from the pop-up window click properties. Windows System properties window will open. Click the Hardware tab & than click on the Device Manager button. Look for a yellow pair shaped icon with either a " ! or an ? " in it. You might see unknown PCI device.
Right click once on the explanation point, a window will open & Left click once on “update driver”. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Left click on the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find the “Sound” folder on your desktop. High-light it by left clicking on it once. Than click OK. Windows will search within the folder & install the correct driver software. If this still fails to install than it is more likely the motherboard has a problem with the Intel chipset.
Enter your bios & make sure the Sound is set to Auto.
Mike
Apr 21, 2009 | Intel D845GRG Motherboard
HP psc 2110 all in one: check and remove cartridges (error)
Usually it will give you that note right away and not wait till morning !!??
Try this if you haven't already.
open the lid so the cartridges center. unplug the power.
Take out the cartridges, use a clean cloth with a touch of water to clean the back of the cartridges where all the contacts are and do the same inside the cardridge carriers. Then do it again with some denatured alcohol. Make sure it is all dry then reinstall them making sude you here them click into place.
power in back up and you'll have to run the align cartridge utility if it doesn't do it autoomatically. Then a print test page.
good luck
Fran
Oct 16, 2008 | Office Equipment & Supplies
Unsupported cartridge??????????????
Check to make sure that all of the packing "tape" has been removed correctly on the replacement cartridge and that the cartridge is seated correctly and the circuit contacts make good contact with the contacts within the carriage assembly and that nothing is obstructing it. Possibly a defective cartridge..
Aug 01, 2008 | Dell 924 All-in-One InkJet Printer
G%% color cartridge
You might have a bad cartridge or the contacts that marry to the cartridge to the machine needs to be cleaned.
Hope that helps...
Jun 18, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
"Remove and check cartridge"
Most of the time when the error pops up it is due to problems with either the printer reading the cartridge is in from the contacts or the cartridge contacts are damaged. I should also point out that refilled and remanufactured cartridges are the number one reason for the error but assuming that you are using hp cartridges fresh out of the pack take a look at this link and follow the steps. I would type them out but it even has pictures for easy reference!!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042818&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
Feb 02, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
