Question about Sony PlayStation 2 (PS2) Console
Problem with ps2
Disk not spinning when loading
  • 1 more comment
  • Anonymous Nov 16, 2008
    The disk wont spin when i put it in and the lens is clean by the way i have the older ps2
  • Anonymous Jan 31, 2009
    when i put the game in the eye moves back and forth but the disk dosnt move at all
  • nirishvivek Feb 01, 2009
    some of the local cds are not supported by ps2 usually but when i press its upper cover slightly it may works
  • 709 Answers
The laser is either dirty or burned out. When the disc does not spin, it usually is becasue the controller does not see any initial data coming from the laser. Clean your laser and see if you get any response. Post a repsonse if you need further assistance.
Posted on Nov 04, 2007
My PS2 tells me "this disk can't be read".
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail and both lens. This is housed in the loading dock assembly(Drive). This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Jul 28, 2009 | Sony PlayStation 2 (PS2) Console
My PS2 won't spin a disc
try both audio and game disks if it will not turn the disks then the motor hub on the ps2 is shot if it will play the audio cd and not play the game then the laser is out of alignment but if you hear it spinning it could also be a burnt out laser as well further information would be required to diagnose this issue further.
Nov 30, 2008 | Sony PlayStation 2 Slimline Console
Slim model - spins disk, but does not read.
if your not lay the console down and run a disk
Jun 24, 2008 | Sony PlayStation 2 (PS2) Console
My ps2 wont work
You have a problem with the DVD ROM'll have to replace that.
Mar 05, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Loading
Get a new one, CD motor has burned out.
Jan 28, 2008 | Sony PlayStation 2 (PS2) Console
Not loading game
the reason it makes the "grinding" noise is because the motor that moves the lens to read the disk is dieing, this generally happens when you have played your ps2 for a long time, this only happens to older consoles.
Nov 01, 2007 | Sony PlayStation 2 (PS2) Console
Disks wont spin on new laser
Did you remove the anti static solder blob (point) on your new laser with a soldering iron and solder wick prior to installing it? The symptons your explaining indicate that point is still intact, If so you will need to carefully remove it first then reinstall the laser and try again.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Sony PlayStation 2 (PS2) Console Logo
81 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
