Question about Alpine CDA-7894 CD Player
Factory speakers on 95 camaro wont work.
I have a 95 camaro and in my car i have an Alpine CDA-7892 cd player in my car with an 800 watt amp with 2 15 inch subs plugged up to it and suddenly the other day my factory speakers went out. so now i cant even hear words when i listen to music its jus bass. but occasionally my factory speakers will work for about 10 mins. when i first crank my car. i was wondering if you could tell me what might cause that?
  • 32 Answers
Loose wires a short behind ur reciever when ya put it in
Posted on Jun 17, 2009
How do i turn on an alpine cda 792
Press the Source button.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjehfyp5JfbAhWq3YMKHUVRCRcQFggpMAA&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F5%2F58a5b847-40d6-4050-b9f6-665dcac29113.pdf&usg=AOvVaw0bgzRI_YgcM9HHxL6fTHFp
May 21, 2018 | Alpine Car Audio & Video
Poor reception with Alpine cda 7892
I found the manual at Alpine.com.http://vault.alpine-usa.com/products/documents/OM_CDA-7892.PDF
Apr 15, 2012 | Alpine CDA-7892 CD Player
How can I get my ipod to work on the Alpine CDA-7892?
Ai-NET/RCA Interface cable (KCA-121B)
Converts the changer port to RCAs... then an RCA to female 3.5mm female adapter.
Or an FM Modulator.
Thanks for using FixYa - a 4 thumbs rating is appreciated for answering your FREE question.
Dec 26, 2009 | Alpine CDA-7892 CD Player
I would like know whether a sony xplod subwoofer can be connected to my alpine car audio system! xplod sub woofer is 1100 watts.
Deffinitely but wired directly would be pointless, the Alpine's internal amp is way to weak to get the best out of the sub. You need an amp, minimum 300w and bridge the outputs to give all the power to sub preferably switched to low-pass (most amps will have a high / low pass switch)
Dec 07, 2009 | Alpine CDA-7892 CD Player
Need wiring diagram for cda-7892
Hi and welcome to FixYa.
Below is the wiring diagram for an Alpine CDA-7892.
It was captured from the user's manual available here.
Good luck and thank you for asking FixYa.
Nov 10, 2009 | Alpine CDA-7892 CD Player
Hold is on and nothing will will work how do i turn off hold on a alpine cda-7892 cd player
Try resetting it. Also if it won't reset using the reset button found behind the faceplate. Take off the negative battery cable under the hood this should reset everthing. Then replace it. If it is old and the motor is having trouble kicking the cd out then stick a used no good cd in on top of the other cd and use it to apply pressure to the cd in the player then pull it out after pressing eject
May 31, 2009 | Car Audio & Video
CDA7892
hmmmmmmmmmm try alpine support. Audio Products Technical Support
(Alpine Electronics of America, Inc.)
(800) TECH-101 (1-800-832-4101) they should definitely help you out. thats definitely a problem with the decks with the slide out fronts.
Jun 12, 2008 | Alpine CDA-7892 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Alpine cda-7892 Head unit overheating
Certainly, the output IC might need to be replaced, also check to see if there is a factory amp somewhere in the car. Additionally, double-checking the wiring is a must. How long does it take for the unit to heat up?
Mar 28, 2006 | Alpine CDA-7892 CD Player
Alpine CDA-7894 CD Player Logo
187 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
