PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Power on password
By tazra3 on Oct 31, 2007
how do i bypass the power on password
Same Problem
Apr 27, 2009
-   HOW TO BREAK POWER OFF CODE FOR COMPAQ-   Guest
Apr 01, 2009
-   I had forget my powr on Password and the system cant get boot. Help Me please
Dawood shah Dir Timargara -   Sunny Gee
Feb 19, 2009
-   I am writing from my friends Laptop. I have an INSPIRON E1505 and I forgot my Administrator Password. I didn't know if there was a password or nyting I could do to get it or get into my administrative user-   Guest
Jan 27, 2009
-   I tried to power on my laptop IBM thinkpad A21m. It boots up and says" error 0271 CHeck Date and Time Settings. It then lead me to another screen with a padlock icon. I haven't used this laptop for 7 months.-   rabuens
Nov 26, 2008
-   I have a hp nc160 that was originally a school laptop, i want to get into bios to overclock it but i need the administartor password. can a nyone help? -   ap33
Solution #1
posted on Oct 31, 2007
Somewhat Helpful)
pauldonp
Rank: Guru
Rating: 88%, 1245 votes
this problem i had on a pc once but i have never done it on a laptop but on the pc i had to take the casing off and their is jumper switches usually about 8 of them on the board it self their should be a bit of paper stuck to the casing on the inside then you will have to find the right jumper switch witch should be numberd then it should have an on and off setting as the password is on push the switch and put it back together this should then bypass the password unless you can get into the setup menu before it ask for password by pressing one of the f keys if not then you will have to take the case off and find these jumper switches thes are really small and if you are not confident taking the unit apart get someone else to do it i think you are going on about the password before it boots up but dont take the case off without been sure you can do it as it can be trick hope this is some help................
Comments:
Oct 31, 2007
- if it id bios password try this site spotmau.com
Was this helpful?
Yes
No
Solution #2
posted on Apr 08, 2008
Somewhat Helpful)
Geekman
Rank: Guru  Computer Hardware  Expert
Rating: 85%, 1691 votes
Have Compaq Evo 620 with power on password.
This is the same problem with IBM Thinkpads.
The Password is stored on an EEPROM and therefore cannot be reset by removing the BIOS/CMOS battery etc.
The EEPROM chip is an ATMEL 93C66 (and is different to the one in the IBM), it is hard to get at, have to dismantle the laptop completly.
Have a look at the www.allservices.com for details on hoe to grack the password, won't be as easy as the IBMs.
Have fun
Chris
chingee@yahoo.com.au
Was this helpful?
Yes
No
Solution #3
posted on May 25, 2009
Somewhat Helpful)
Nimmala
Rank: Apprentice  Computer Hardware  Expert
Rating: 75%, 1 votes
http://www-307.ibm.com/pc/support/site.wss/MIGR-63894.html remove both batteries n turn it on... password should vanish if it is just power-on password.
Was this helpful?
Yes
No
Solution #4
posted on Jan 22, 2009
Somewhat Helpful)
scooterman20
Rating: 75%, 3 votes
hp bios reset pasword this will only work on bios settings not hard drive password for hard drive pasword removal u can only replace the hard drive or find a good hd checking software and data wipe it using full format but this doesnt always work.
to remove bios password is simple you will ned to dismantle the laptop you need to remove the keyboard and power panel and battery. turn over the laptop look for keyboard symbol undo that screw the undo any screws that are in line with the power panel remove this panel if any screw holding down keyboard undo those lift keyboard to one side do not remove completely nor the power panel leave everything connected.How look in the bottom left corner of keyboard recess normal u will see sticker saying rtc with arrow pull that wire plug out. if u can se it pull any that are red or red and black. go make a cup of tea. then come back. with battery out connect the power supply press power button and press F1 or F2 depending on ur setup. It may just come up about changes press f1 to accept the bios screen will open power it down pull powersuplly out press and hold power button for about 5 secounds to ensure all power has gone.re-assemble all wires etc keyboard etc replace battery then power up again it should now be clear of passwords
Was this helpful?
Yes
No
Solution #5
posted on Jan 13, 2009
Somewhat Helpful)
Samanic
Easiest Fix, well not easiest if you dont want to open up the laptop or desktop. . .but if it has a boot password and you forgot it (boot password meaning - password you enter for you computer to start booting / POST . . this wont help if you need a password for an encryption software like Guardian Edge to start booting up your computer) But anyways, if you forgot your password to boot up your laptop or to make changes in the BIOS then all you have to do is open up the computer and look for the CMOS battery (it looks like a watch battery so its easy to find) Take out the CMOS battery for about 30 Seconds and then put it back in. . .It should clear out the password.
Was this helpful?
Yes
No
Solution #6
posted on Jan 05, 2009
Not Rated)
quique55
Rating: 0%, 0 votes
I do not have the pass word or do I need it.
Was this helpful?
Yes
No
Solution #7
posted on Dec 12, 2008
Not Rated)
infi
Rating: 88%, 2 votes
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
How to choose a ebook reader.Comparison of performances between different models
Answer
I Can't turn on my Dell Latitude D810 laptop. When I push the power button, the power light comes on... (More)
Answer
cannot get device manager to come upsoi can disablesmc wireless card so i can use a usb wireless
Answer
the power cord jack is broken out of both my toshiba laptops how can i repair them
17 Other Users Have The Same Problem - Continued
Comment by chrisbriscoe, posted on Oct 04, 2008
i have a hp nc6220
it has suddenly started asking for a password on boot up
i suspect my 9 year old has been interfering but i can not get my pc to accept any password help ..... pls
Comment by xpersion, posted on Sep 10, 2008
hallo
i have same problem i forgot my bios password
can u help me i want format it
Comment by talk2obsilvi, posted on Sep 06, 2008
i forget my dell inspiron e1505 laptop administrators password and i can't access my window
Comment by Guest, posted on Aug 31, 2008
My IBM Thinkpad T22 has a power-on password, after 5 years using it and now its asking me for a password which i don't even know. Please help me fix this problem as all my years of work and study its in the laptop.
Regard
MK
Comment by alexdude93, posted on Jul 20, 2008
my computer starts normal..but then says type password. it is not the usual windows sign in. it is a box and if you press enter with wrong password, the computer shuts off.
Comment by mrplopez1972, posted on Jun 25, 2008
I have a T41 Lenovo Laptop here with a Startup Password enabled. I do not know the password, and I am unable to contact the prior owner (I repair laptops for a company). How can I disable this password? I appreciate your help!!
Comment by dncip, posted on Jun 24, 2008
my laptop says 1720-smart hard drive detects imminent failure (failing Attr:01)
back up the contents of the hard drive and run HDD self test in F10 setup
then it asks for a power on pass word.
what do I do?
Comment by grantjm1, posted on Jun 11, 2008
My toshiba Satelite A55-s306 will not boot pass the CMOS startup screen. How do I reset the password.
Comment by gava, posted on Jun 02, 2008
each time i power on my laptop it will request for a power on password that i cannot remember. please help me fix this problem.
Comment by ciscot, posted on May 27, 2008
i have desabled the cmos but it doesn;t help either to remove the bios password so what can i do wit hthe IBM T21 BIOS PASSWORD
Comment by savecrj, posted on Mar 30, 2008
Satellite M35X-S311 lost password
Comment by Guest, posted on Feb 07, 2008
I have a Toshiba Tecra A1 laptop , and am attempting to find the bios reset switch so that I can reset the password or enter the computer. I took my computer to a repair center but it will cost me over a $100.00 to reset. they told me it was a resetting of the switch that was required. I am a senior and in no position to pay this amount.If any one can instruct me as to how I can do this, I would be very greatful .
Thankyou Norm
normbrius@3web.com
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
