Question about Water Heaters
Reliant water heater universal elements won't fit
The lower element of a 50 gallon reliant water heater element went bad. The treads on a standard element are two small. Is there a special element for the water heater?
  • 332 Answers
Some water heaters are made to use just there parts, you can contact reliant and and have them send you one,, how old is the unit because most units within the last 5 years are pretty much universal
Posted on Jun 21, 2009
Need a wiring diagram for rheem electric water 50 gallon 2007 model
1) Copy following links for standard wiring that applies to all brands electric water heater: wire colors vary, and do not matter.
You probably have ordinary residential non-simultaneous water heater.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
2) Look at tank label.
Typical label will show number of elements (upper and lower)
And give wattage for each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html#label
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
Notice also total connected watts.
If total connected watts is same as individual upper or lower element watts, then you have ordinary residential non-simultaneous tank.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 07, 2013 | Water Heaters
BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Dec 18, 2012 | Bradford White M240s6ds-1ncww 40 Gallon...
Reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else could...
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
Oct 06, 2012 | Reliance & 40 Gal Electric Mobile Home...
Hello - I have a 6-7 yr old Whirlpool EnergySmart 50 gallon 5500 watt water heater. (Two control boards fried and were replaced free). Symptom now is not enough hot water. No 'error codes' are blinking...
1) Residential water heaters are non-simultaneous. Only one element works at a time.
Upper element comes on until top of tank is heated, and then lower element is switched on until lower part of tank is heated. Lower element keeps tank hot during standby hours
http://waterheatertimer.org/How-it-works.html
2) Typical Whirlpool energy smart has 4500Watt elements. Look at label on side of tank
If both elements were ON, that would draw 9000Watts or 37.5 amps, requiring 50 amp breaker and 8 gauge wire. V x A = Watts.
All dual-element tanks are 240V.
Whirlpool energy smart requires 10 gauge wire and 30 amp breaker so electronics are not starved during operation. If your wire or breaker are undersized, that is suspect for repeated failure.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
3) Typical electric water heater heats 21 gallons per hour. First hour delivery is higher since elements heat water as you use it. Overall however, electric water heater cannot re-heat as fast as gas because gas water heater burner carries more BTU punch per minute than electric element. Gas heats about 41 gallons per minute, with higher first hour delivery.
4) IF YOU HAVE OLDER energy smart and installed newer board, then you could have non-simultaneous operation is reversed so that lower element comes on first.
Read following post at Fixya:
http://www.fixya.com/support/t8263226-our_water_heater_doing
Contact Whirlpool 1-877-817-6750
5) Another potential problem is that you have sediment inside tank and that is reducing efficiency of lower element.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 09, 2011 | Water Heaters
I have a rheem glas standard 30 gallon model # 81sv-30d water heater with upper and lower watages 3500. how do i know what size heating element i need?
Look on label on side of tank.
Wattage of tank will be element wattage. This is true if tank has one or two elements since both elements are never ON at same time.
Simply go to hardware store and buy 3500W element.
Take phone photo to store if needed for identification.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Wattage appears on end of each element.
http://waterheatertimer.org/images/Voltage-printed-on-element-.jpg
Feb 12, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The water want stay hot very long
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Rheem fury series manuals and models
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Age of Rheem
water heater is first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) If cold outside temperatures are not to blame, your water heater may have a bad thermostat or bad lower element.
C) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
D) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
Replace element with same wattage shown on label, and clean out sediment:
This will restore water heater to full 99% efficiency.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you want to test thermostats and all parts before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
geno_3245_183.jpgRheem element
Dec 14, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Installed new upper & lower elements & thermostats, only top htr works
If original problem was caused by sediment burning out lower element, did you clean sediment out of water heater when changing lower element?
Two element water heaters are 240V.
Thermostats cut power on one hot wire, but 240V circuit has 2 hot wires. So lower element has power at all times coming from the red wire.
1) Use ordinary tester or multimeter set to 240V <> test each screw of lower element to bare metal part of water heater. Each screw should show 120V. If there is no power, then upper thermostat is defective, screw on upper thermostat is loose, or red wire between upper and lower parts of water heater is bad.
2) Remove wires from lower element. Use continuity tester or multimeter set to ohms <> test across both screws of element to see if power travels through element <> if element is bad, then continuity tester will not light up and multimeter will show no ohms. Put wires back on element after test.
3) Start with cold water in tank. Turn on water heater & upper element will turn on. Put ear on side of tank to hear if upper element is heating water. Test #3 screw to #2 screw on low left side of thermostat, should read 240V > Test #3 screw to #4 screw on low right side of thermostat, should read 0V.
Put ear on side of tank. When upper element turns off: Test #3 screw to #2 screw on low left side of thermostat, should read 0V > Test #3 screw to #4 screw on low right side of thermostat, should read 240V. If this test shows 0V and 0V, then upper thermostat is bad. If reading is correct, immediately move to next test.
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
4) Turn temp on lower thermostat to 150. Using ordinary tester or multimeter set to 240V <> Test across both screws of lower element. If there is no reading, and you know element is good from step 2, then lower thermostat is bad, or wire is bad between lower element and lower thermostat, or wire is bad between lower thermostat and top part of heater.
5) Test across both lower thermostat screws, should read 240V.If this test is good, it means wires are good. Put jumper wire across both screws of lower thermostat, and test lower element again. If element finally turns on with jumper wire, then lower thermostat is bad.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If wire is bad between upper and lower parts of water heater, and water heater has tight-fitting 2" foam insulation, it usually indicates water heater replacement.
Sep 20, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
New Rheem electric 50 gallon not heating
Check the elements, if you have access to a meter to check them. If they are getting power to elements and you have no hot water.
The elements are not working correctly. I had some elements check out ok till the thermostat's turned on and the elements didn't heat.
Sounds like the elements are bad.
Jun 01, 2010 | Water Heaters
50 gallon electric heater not working after about 5 minutes in the shower the water gets cold and the rest of the house i do have 240 going to water heater thermostats goood element good
Some elements will read with a meter good until they heat up.
Hot water then going to ice cold top element is working and bottom bad. Luke warm water and then goes cold bottom element good and top element bad.
Elements and thermostats are not to exspensive to replace.
If you have power only two thing's left are the thermostat's and the elements.
May 21, 2010 | Water Heaters
Water Heaters Logo
85 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
