Question about Aiwa PX-E860 Turntable
Plays too fast
I just got this turntable and am having a problem. The RPM is too high to play my records! Whatever the setting is for 30, it must be wrong because "Aqualung" sounds ridiculous. As far as I can tell, I'm not missing any settings.
Thanks,
-J
I had this same problem. You can adjust the speed, although it is a bit of a pain. If you turn the unit over you will see two little holes on the bottom labeled "33" and "45". You will need a small (jewelers) flat head screw driver. If you put the screw driver in the hole you will encounter a rubber cover. Push the screw driver through the rubber and go down a bit further and you will feel a screw. Turning this screw to the left (counter clockwise) makes the speed slower. Turn the screw to the left to make the speed faster.
For a picture you can download the service manual:
www.eserviceinfo.com/downloadsm/24072/Aiwa%20Service_PX-E860.html
You can check the speed visually by downloading a strobe disc (I found one I like at http://www.extremephono.com/free_turntable_strobe_disk.htm). To actually be able to see the strobe you need to do this under a lamp with a single fluorescent light bulb (fluorescent bulbs actually flicker a little bit at the same frequency as the electric supply).
Posted on Apr 02, 2008
  • app_3rp44869
    app_3rp44869 May 07, 2012
    This worked perfect!!! I just played it along with an mp3, adjusting it while it played until it matched up perfectly. Thank you so much!!!!!!
To be fair, Aqualung always sounds ridiculous. I kid, I kid.
The setting of "30" is probably a lever on top, right? If so, and the other setting is "17", you are looking at the record size selecter (it's in cm, so you're looking at LP vs 7").
There is a push button on the left front, says "speed". If the button is raised, it's 33 RPM. If the button is pushed in, it's 45 RPM.
I'm betting Aqualung is a 33 RPM, and you've got it set to 45 RPM.
Posted on Oct 14, 2008
  • 515 Answers
Hmm... there really isn't much to this turntable. It's belt driven, so unless the belt was installed incorrectly, or the belt motor/spindle is damaged, there really isn't anything else to check. So, just make sure your belt is installed correctly, and check to see that the spindle the belt wraps around (this is the motor), that is spins correctly. If it spins too fast, then there is an issue with the motor. You might also want to check your voltage setting for the model. Not sure which country you have this plugged in, but make sure it matches your local voltage (115V or 220V). The switch should either be on the back or bottom of the unit.
NOTE: Not all units have this switch. If your's does not, then make sure you purchased a model compatible to your countrys' power rating.
Posted on Nov 02, 2007
The turntable is going too fast because the singing coming out sounds like the chipmunk's any trouble shooting tips??
You are likely playing a 33 rpm record while the turntable is set to 45 rpm. You need to find the speed control and adjust it to the media you are playing.
Dec 20, 2015 | Audio Players & Recorders
Pitch is off--too slow before, now too fast.
The speed is set by a synchronous motor that drives the turn table. There may be a small adjustable resistor (pot) that will do the trick.
May 31, 2013 | Audio Technica AT-PL50 Turntable
Even though i am playing my record on normal speed, it plays to fast
if your turntable doesn't have a pitch control (like the dj's turntables) if you open it you should find on the board close from the 45-33 rpm switch a variable resistor ( a small electronic part with a sort of disc on top with in the middle of it a place for a flat screw driver and marking like + and - those resistor are made to control the speed and can go bad or just need to be adjusted . First try to adjust it turning the dial really carefully with a small screw driver if nothing happened it could need to be replace.
Feb 03, 2013 | Mutant MIG-MT201 Record Turntable, 33...
Got a panasonic compact audio system model # SG-HM09A the turntable plays the record fast
there should be a small switch on the inside of the turn table that allows you to switch from 45 (what i think your listening to) to the normal speed which i think is 33
Jan 25, 2013 | Panasonic Audio Players & Recorders
Which thickness setting should I use when playing my 33 rpm records on my Denon DP 297 fully automatic turntable? 17 or 30?
hi,
There are only two types of records available like 17 and 30. the size 30 will be as same as the turn table plater's size. 17 will be in half sized of the 30.
OK
Oct 22, 2011 | Denon DP-47F Turntable
Can you still get the px-e860 turntable? The one I have won't make any sound thru the speakers
Judging by my own experiences with hifi gear on eBay there is little on the face of the planet that ever really becomes UNavailable.
Wouldn't an attempt to resolve the issue work, too?
Describe your setup (preamp, amp, whatever) and if it has ever or never worked.
This unit can work through its own preamp with any audio equipment or with old-school gear already having an internal Phono Preamp. There's a switch to select which one.
Apr 08, 2010 | Aiwa PX-E860 Turntable
Plays Records Too Fast
If it is a belt drive model it might be that the belt is out of place and therefore causing the speed to be wrong. This might be due to age or wear of the belt. I would look at that before adjusting.
If it is good and you can't see any mechanical fault causing it. Then look for a preset pot (or two) on either the pc board or on the motor itself. They will adjust the speed. If you find two - one will be for 45 they other 33.
Bear in mind the motor might have gone wrong!
Jul 25, 2009 | Audio Technica AT-PL50 Turntable
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Trouble with sound
Confirm that the stylus you bought is spec'd out for that turntable
Also check all four wires to the cartridge
Mar 13, 2008 | Pioneer PL-990 Turntable
Sony PS-LX250H speed problem
I have a different Sony model (PS-LX-150H) that had a similar problem. I hadn't used it in awhile, and then when I did, I noticed the speed problem.
IF your PS-LX250 is like my PS-LX150, there are small speed adjustment screws accessible from the bottom of the unit. On mine, the two adjustment screws were labeled - one for 33rpm, the other for 45 rpm. Basically I just fiddled a bit with them using a very small precision screw driver until I could verify that I had reached 33 rpm (I used a stopwatch and literally counted the number of rotations/minute after making adjustments.)
Now it sounds right!
Mar 09, 2008 | Sony PS-LX250 Turntable
Aiwa PX-E860 Turntable Logo
1,109 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
