Cold water takes a very long time to fill machine- inlet pipes have been checked and are not blocked. Model MW058U. Serial No LEL5491123. Product 93103.
  • omanu Jun 16, 2009
    The solution confirmed what I expected, have ordered the part. Thanks
  • 3,037 Answers
Your water valve/cold side solenoid has gone bad. You need to replace the valve. You can call the manufacturer for a replacement, get it from an online website, or through the place that you bought it.
After a little searching I found the part online. This should be a direct link to the part, but if you have further questions please let me know. http://www.alliedappliance.com.au/info/A234810002.html
Benjamin
Posted on Jun 16, 2009
My ultima1000, wm 71 says error 10 sometimes and error 11 mid way thru a cycle. The pipes are fine and water is on what could be the problem?
E10 No cold fill detected - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
E11 Not hot fill detected - washing machine does not fill
  • Wiring fault
Apr 11, 2016 | Washing Machines
I have daewoo dwf 200 le and it not taking the water from the pipe outlet what to do to fix the problem
Assuming you have mains water running to the inlet tap and the tap i is open, the most likely cause is inlet hose connector filter is blocked or the inlet valve inside the washer is faulty.
Hopefully you are able to select the wash program and start the wash cycle. Otherwise the problem could not be in the water inlet or elsewhere.
Refer page 21 on this manual and also check the part number and location of the inlet valve.
http://www.daewoo.cl/sta/manuales-tecnicos/DWF-312W%20Manual%20Tecnico.pdf
Aug 17, 2014 | Daewoo Washing Machines
Why Frigidare 22s750 Washing machine doesnt take in Water at all..Everything is connected. But washer not taking in water
Please check the pipe through which water goes in the machine, there could be a blockage or check for any buttons which block water inlet.
Aug 16, 2014 | Washing Machines
Kenmore series 90 plus model # 4217018 water inlet valve
Hi, some users install those horrible quick-connect hose connectors to water pipes, they tend to cut a very small hole, that corrodes over. This will give the exact symptoms you are getting. Also, the flexible inlet hose, if it is kinked/collapsed internally, you can get this. To check this, turn the inlet supply valve OFF, unscrew the flexible inlet pipe from the back of the machine, and hold over a bucket, and turn on the valve. If is trickles, then it has to be either the flexible pipe, or the valve blocked (and NOT the parts inside your machine at all)! Hope This helps, Tony Davis, of LETSFIXIT.
Jul 12, 2012 | Washing Machines
It takes way too long to go through the whole cycle. it says initially that it will only go for 50 minutes, but then takes over 2 hours!
it could b e that you have a themostat problem heater not heating water property hence takes longer, it could also be somthing silly like a crimp in the water inlet pipe restricting flow , faulty inlet selanoid, check to see how long it takes to fill machine , the machine could be genraly blocked watyer pump not evacuating water fast enough blockage in the out let pipe anything that restricts the flow of water in or out can add time to your wash
Jan 18, 2010 | GE WSXH208A Front Load Washer
Front load washer will not fill with cold water and will just stop at the rinse cycle and buzz
Check your inlet pipe on cold water supply, When you dissconnect look inside where pipe fits onto machine you will see a small filter, if it is blocked take it out with great care and clean. always replace it. if your water supply is ok and filter is clear then it will be a faulty water valve. Good luck and feel free to give feed back ok.
John
Sep 03, 2009 | Kenmore Washing Machines
Why is my warm water is cold? The hot is hot and cold is cold but warm is cold.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
Jun 28, 2009 | Admiral AW22 Top Load Washer
My washer works wonderful buy cold water settings do not work even rinse doesn't work hot water works fine
Would say that the cold fill valve is shot
The machine cannot fill with cold water which it uses for setting the temperature on the 60 degree wash.
The cold valve is also used for rinses
Hot water only will give you a wash which is too hot and will cause the colours to run
Can take the pipe off the back of the machine to see if the cold water inlet filter is blocked
Make sure that you turn the fawcet off and also that you have a cloth handy in case there is still some pressure on the hose.
If the filter is blocked take it out and clean it , it just pulls out but be gentle with it it is only plastic.
If the filter is clean you need a new valve
Jun 05, 2009 | Roper RAS8244KQ Top Load Washer
Fisher and Paykel MW058U won't fill
Fault is out of balance switch stuck on i removed and cleaned mine with crc but if still stuck on may need replacing hope this solves your problem
Jun 18, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
