Question about Whirlpool GEW9250 Electric Dryer
Trying to locate thermistor whirpool dryer and replace it
  • Whirlpool Master
  • 1,266 Answers
Http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208180470.pdf
Try this web site. Look on page 5, item 42. It is listed as a thermistor. If you can not get to the site, let me know and I'll give you the step to find it on the whirlpool web site.
Posted on Jun 16, 2009
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
My dryer won't heat up whirpool wed5320sq0, please help
Hi phuffma...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Aug 28, 2011 | Whirlpool WED5320SQ Electric Dryer
Whirpool dryer is not heating. Model LGR5620KQ1
Hi tpistone6...
Check your Wiring
Jul 30, 2011 | Whirlpool Dryers
We had a problem with the Whirpool dryer wed5100 last week and it was the thermal fuse was blown so I checked the vents and it was packed with lint and replaced the thermal fuse and it works now but now...
Hi Danny224...
Check your Wiring
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
This is a FREE answer, Please take time to rate me
Jul 01, 2011 | Whirlpool Dryers
F 01 error code whirlpool duet dryer. Can I replace the control panel?
Where is the thermistor on the dryer on whirpool duet or remove control panel
Feb 28, 2011 | Whirlpool Dryers
Whirpool dryer there is no heat
need to know what the model number is.
Aug 28, 2010 | Whirlpool Dryers
Location fuses Whirpool duet dryer
The thermal fuse is located on the blower housing outlet to the left of the thermistor. For electric dryers, the thermal cut-off and high-limit thermostat are located on the heater housing. For gas dryers, the high-limit thermostat and the flame sensor are located on the burner.
Disconnect the dryer from the power outlet and turn-off the gas supply for gas dryers.
Remove the two screws at the bottom of the toe panel securing it to the cabinet. Pull the toe panel down and off the cabinet.
Check the continuity of the thermal fuse with an ohmmeter set to X1. The ohmmeter should read zero ohms. Replace both the thermal fuse (part #3392519) and the thermistor (part #8577274) if the resistance reads open or infinite. Remove the securing screws and install the replacement part.
Do the same with the thermal cut-off. Replace both the thermal cut-off (part #279973) and the high-limit thermostat (part #3391914) if the resistance reads open or infinite. Remove the securing screws and install the replacement part.
The high-limit thermostat is located next to the heater terminal block and next to it is the thermal cut-off.
Slide the toe panel in place up and into the cabinet and secure it with the screws.
Note: Disconnect the wires from the terminals of the component before performing the continuity test.
Feb 22, 2010 | Washing Machines
I have a Whirpool electric dryer model number
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Oct 27, 2009 | Whirlpool Dryers
Just bought a new thermistor for the Whirlpool Duet dryer and ready to install, does it has any polarity; ie. does it matter which wire goes to which side?
Jun 16, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
367 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
