Question about Compaq Presario sr1055cl PC Desktop
Disk drive didnt run
I had the same problem and followed the directions and where it said to uninstall it, i did this and i don't know how to reinstall it. any help??? please
  • 98 Answers
Make the hd. master on the primary, and make your d drive master on the secondary.
Posted on Jun 16, 2009
Bootmgr is missing on my computer and I don't know how to fix it
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 01, 2012 | Computers & Internet
Please help me..i have a aspire one d260 netbook..the problem is bootmgr is missing..it has no cd drive and i dont have a external cd drive to use.. how can i fix it using only a usb flash drive..how can...
You might have to take it to the shop. Lesson learned. Never buy a computer without a CD Drive because one day the system is going to croak.You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
May 29, 2012 | Acer Aspire One D260 Netbook
I honestly do not know what happened to my laptop but I get these message saying BOOTMGR is missing . I don't know what to do ?
Try the steps below.
You will need a operating system disk or a repair disk to fix it. Insert it in the drive then boot from it. You want to get to a dos command prompt (black screen with white lettering) and type the following commands. Press ENTER after each command.
bootrec.exe /fixmbr
Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 10, 2012 | Gateway Computers & Internet
If i want to laod the game it says ; can't validate media, wrong disk, and i bought the legal game. i don't understand what to do. could someone help me?
This is a know problem with this game to fix it follow these steps
Please uninstall the game (via the games uninstaller, not Windows Add/Remove) and then follow the steps below before installing it:
-From the Start menu select Control Panel
-Select System and then select the Hardware tab.
-Click on Device Manager
-Find the secondary drive which you did not use to install and right click to Disable.
-Now you should be able to enter the Product Key with no problems. (once you have registered, feel free to enable your secondary drive.
Jun 09, 2011 | THQ Company of Heroes: Game of The Year...
My acer 3100 is too slow
Following these simple steps will speed up your notebook...
*Eliminate as many unnecessary programs from startup as possible.
*Run a disk cleanup and disk defrag on your system at least twice a month. *Uninstall programs that you don’t use *Unclutter your desktop of shortcuts *Clear the web browser cache
*Add more memory
Jul 13, 2010 | Acer Aspire 3100 Notebook
4G Usb Imation Pen Drive has stopped being picked by any PC
there are two reason for ur problem
a) when windows XP fails to allocate a drive letter to your portable drive(pen drive)
b)some other technical faults in your pendrive
to solve ur problem follow these steps below
Right click on My computer icon->Select manage->Select Computer management->Select Disk Management under the storage section
-> In the right side will show you all of the current drives and partitions on your drive.
If you don’t know which is your pendrive, don’t worry, just find the drive you are looking for in the graphs at the bottom. They are usually named Disk 0, Disk 1, CD-ROM, CD-ROM1, etc.
If you’re looking for a USB flash drive, you’ll see the word “Removable” underneath Disk X -> Now right click on the icon -> Select Change drive letter and paths -> Assign a new Drive letter-> click Ok.
Now your pen drive will be detected in the computer.
there is an another way to solve ur problem
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again, i think this should solve the problem.
May 12, 2010 | Computers & Internet
Used system restore now can not find yahoo messenger, i downloaded in the future . i downloaded yahoo messenger and everything was fine, but i brought my computer back to a time when i didnt have a couple...
Look in the C files first, and if you cannot find it somewhere, then you did not save the file the first time you downloaded it.You must reinstall it with new download.. This time save the file, then go back after it is finished downloading, and run it again,,, this time you click on the run button....
Feb 15, 2010 | Yahoo Messenger
AIPTEK Dv8800 Driver malfunction? Answer
  1. aiptek web site has a driver solution for vista users I had same problem but with Win XP it keep seeing it as a flash drive .... I uninstalled drivers and re-installed them,- same error, then uninstalled again and removed the USB from device manager uninstalled direct X cause it was the newest version, then install everything from scratch without turning the camera on then try again and nothing, finally I turn to the manual and somewhere says "if you need to use it as web cam then press the menu button on the camera and select camara!!! as soon as I did that and additional port found in windows was detected and installed automatically then I got my video and microfono up and running. So easy right, but like always the software CD is missing the manuals too and people do not read. LOL .....
Jan 15, 2010 | Aiptek DV8800 Digital Camera
How do you wipe the compaq presario m2000
I'm not sure if you are wiping it to start over or to sell/give away.
Many newer machines have a Recovery Partition, usually your "D:" drive.
Access the System Recovery partition from the Start-All Programs-System Recovery-System Recovery Menu. Following the prompts will allow you to reformat the computer and reinstall the operating system and all software as it came from the factory. From that point, if you don't want any of the factory junk, you'll need to uninstall it yourself.
If the Recovery partition is missing, (usually a D: drive) , then you'll need to have the original Recovery discs which were created when the computer was new.
If you simply want to wipe it, use a disk wiping tool. Many hard drive wipers, cleaners or shredders can be downloaded at no cost. Visit Downloads.com to search for these programs that are designed to wipe your hard drive. Once you have downloaded a disk wiping program, install it on your computer. Each program will have a unique graphical user interface (GUI) and directions for use. Follow the directions for your selected disk wiping tool and run the program to wipe your hard drive. The program will make sure that all files and data have been completely erased by overwriting the entries multiple times.
disk wiping tool. Many hard drive wipers, cleaners or shredders can be downloaded at no cost. Visit Downloads to search for these programs that are designed to wipe your hard drive. Once you have downloaded a disk wiping program, install it on your computer. Each program will have a unique graphical user interface (GUI) and directions for use. Follow the directions for your selected disk wiping tool and run the program to wipe your hard drive. The program will make sure that all files and data have been completely erased by overwriting the entries multiple times.
Read more: http://pcs.suite101.com/article.cfm/wiping_your_computer_hard_drvie#ixzz0RZDlV3Qr
Sep 19, 2009 | Compaq Presario M2000 Notebook
Compaq Presario sr1055cl  PC Desktop Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
