Question about HP Hewlett Packard LCD Display for Pavilion zv5000, zx5000, Compaq r3000t, r3200
No backlight in my lcd but the whole laptop work properly,
  • 700 Answers
Try to connect external monitor to your laptop then hit the short cut keys(see your manual)to use dual monitor. if you got screen on dual monitor. Try to check your laptop screen if something can still be view from screen, if you have then backlighting circuit is to be check. Practical solution is to bring it to a shop if you are not inclined on fixing it yourself.
Posted on Jun 16, 2009
Toshiba X205-sli4 lcd flickering
The cause here is a bad backlight, It wouldcost less to just have the whole lcd with backlight replaced. You can pickon up for under $100 bucks, www.ebay.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 08, 2012 | Toshiba Satellite X205 Notebook
Laptop LCD screen has a faint image or is very dark and i checked Lcd,Invertor, video cable and its working properly . i don't know what to do pls help me.
Sounds like the backlight has gone. What is the make and model - you may be able to get parts or you may be looking for a salvage one.
Apr 10, 2012 | Computers & Internet
I have a dell 1525 laptop - I replaced the inverter, I replaced LCD the new LCD also had an inverter and I replaced the video card. I still get a faint dark screen. I can hear the music when Winn 7 boots...
Hello, and thanks for using FixYa.
What do you mean you replaced the video card? that is impossible, you would have had to replace the whole mainboard.
Okay you replaced the inverter, I suppose it was a tested and known good condition working inverter? does it work on another machine?
The lcd display, same with inverter? Has it been tested that its backlights work properly?
Then aslong as the small cable between mainboard and inverterboard is connected properly, it should work. But if it does not you have 3 possible causes.
1, Faulty display backlights
2, Faulty inverter board
3, bad cable / inserted wrong or motherboard is not providing the required electricity to the inverterboard.
Oct 16, 2010 | Computers & Internet
My screen keeps going dark. I have replaced the
Its not the inverter, it's your backlight. Hard work to change, sorry, and it might be cheaper/quicker to replace the whole lcd panel at $100 (£65)
Jul 26, 2010 | Acer Aspire 5610-2328 Notebook
I dropped my hp pavillion dv2000 entertainment laptop and now i have a crack on the screen from the side to the top what can i do?
Unless you want to try and find another screen that may have a broken backlight tube so that you can disassemble the screen and recycle the outside pane along with the electronics, then you could go that route. I have disassembled my share of these lcd panels and they are not only difficult to work with but the components are fragile to begin with, the lcd panel is made up of 5 different panels of glass and plastic and have to be placed in the framework in the proper order as well as the electronic board and backlight tube. It is more financialy feasable to simply replace the entire lcd panel. If the laptop was dropped and the panel cracked...there could be other damage that is not apparent but may crop up later, so in that respect it is better off and easier to replace the panel as a whole. I would also replace the lcd inverter while you have it apart....on ebay the lcd panels can be as inexpensive as $75.00 and the inverters are around $15.00. The link below is to the service manual that goes through the steps in performing the repair yourself.
The lcd removal procedure starts on 5.2
http://tim.id.au/laptops/hp/hp%20pavilion%20dv2000.pdf
May 28, 2010 | Computers & Internet
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Toshiba blank screen
Your LCD backlight is not working. You will either need to get it fixed or have the LCD assembly replaced altogether. If your computer is under warranty, Toshiba will perform this repair. Otherwise, take it to a local service shop.
Jun 05, 2008 | Toshiba Satellite A135-S2276 Notebook
Pink screen on the laptop but when iattach an external monitor it works fine
pink screen is usually a sign of the backlight going bad. Does it go from pink to normal after a while? usually that is the ccfl warming up- but it will need to be replaced- either the whole lcd, or just the backlight (ccfl) part of it.
Nov 23, 2007 | Toshiba Satellite A15-S129 Notebook
HP Hewlett Packard  LCD Display for Pavilion zv5000, zx5000, Compaq r3000t, r3200 Logo
249 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
