No take it back and state your not satisfied with the service and threatewn them with the consumer office in the local council who investigate complaints like this ,they have not done it properly or fitted the wrong part without the switch or they havent reconnected the multiplug.This is down to them so dont pay another cent till they sort it and then dont pay as this is down to the garage and someone needs a rocket up the jacksie
In trying to fit a booster seat into my 2004 Honda CR-V, I realized that the CRV has the belt buckle in the middle of the seat. This is a big problem for someone using a child seat in the middle seat as the buckle receptacle is completely covered by the booster seat. I thought about buying an extender but realized it wouldn't completely solve the problem. After much thought I came to the conclusion that the buckle receptacle could be moved to a new location without compromising any safety of the belt. I first pulled the buckle receptacle all the way out and then cut the fabric to enlarge the hole from which it protrudes from the seat. Then I pushed it through the hole and back into the seat with the head pointing towards the window and outer edge of the seat. After flipping the window seat out of the way I was able to peel the fabric away from the bottom edge of the middle seat enough to reach in and retrieve the belt receptacle. It was a little tight but I was able to buckle the belt and use the seat belt to pull the receptacle through this new "hole" and VOLIA the belt receptacle is now in a better position to the side of the middle seat. You can now used a booster or car seat or put a fully grown human in this seat and buckle with ease.
If I had the problem I would look at a junkyard or on line at e-bay for a replacement. You will need to get the buckle and the belt that it is attached to that goes down to the floor down through the crack in the seat. Remember the buckle receiver is made for the certain belt in the front and rear seats. I have often tried to put the wrong belt in a buckle and it would not fit. ( Example: the right belt goes in the right buckle.) Be blessed.
The buckles are placed on the belts and then they are sewn so that you cannot remove the buckles.. You will have to replace belt and buckle as a unit. murf427
1. Measure the waist for the person wearing the belt. You need to add 2 to 3 inches to the size when you buy a man's belt. If the waist size is 34, get a 36 or 37 belt. When you buy a man's belt, you want to make sure that the stem of the buckle fits in the middle hole. 2. Choose the appropriate color, matching the shoes and the belt to get a finished look. The shoes should go with the outfit. If you have a black suit, don't buy a brown belt. 3. Make certain the belt isn't more costly than the shoes. You need good quality in both, but if you pay a huge amount for the belt and wear shabby shoes, you still look bad. Get something that's good quality with a comfortable price. 4. Purchase a leather belt if you want to use it with a suit. Leather belts are dressier. Cloth belts tend to be more informal and go well with khakis and shorts. 5. Select a belt buckle that goes with the outfit. When you buy a man's belt for a formal occasion, you don't want a large belt buckle. Simplicity for formal wear and that big turquoise belt buckle for those jeans and cowboy hat is a rule of thumb. 6. Keep the width down to 1 1/2 inches if you buy a man's belt for formal occasions. Anything wider is strictly for casual wear.
I am sure you can measure the length of bolts you need and the size. Any hardware store should be able to help you. If you get them too long just cut them off with a hack saw. Done those kind of repairs many times.
