Question about HP Compaq nx7400 Notebook
My laptop screen had an odd color to it a few days & is black now
My laptop screen had an odd color to it a few days ago & by the end of that day, the screen was black. When I power on, the screen comes on momentarily, but is off within seconds. I can also hit the button that turns the screen off when the laptop is closed and the screen will come on for a couple of seconds. Just long enough to let me know there is still life in the old girl. What can I do to fix this?
  • HP Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 16, 2009
Printer only won't print in black
My printer did that a few months ago. I tried everything to get it printing black but in the end I had to take the ink cartridge back and return a new one. Some ink cartridges dry out when they are being shipped if not stored in proper conditions.
Mar 14, 2010 | HP Officejet 6500 Wireless All-in-One...
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Dell Inspiron E1505 shows green pixels instead of black
the color pixels are different sections in the screen and the green section might be cracked
Apr 24, 2009 | Dell Inspiron E1505 Notebook
Toshiba laptop screen dicstorted
Loose electrical connection or its loosing its grip to hold your screen. If you can do it on warranty then try. Or have it check by a technician.
Apr 07, 2009 | Computers & Internet
The screen won´t work, please help.
Looks like your screen going to 'kaput' already.....anyway try to reseat the memory modules 1st. If u had the luck..it may works that way.....good luck
Sep 14, 2008 | Dell Latitude D600 Notebook
Color problem
There are three Cathod Ray guns responsible for the millions of colors.All colors are produced by mixing the three basic colors namely Red Green and Blue (RGB) at suitable proportion. If any one of the three guns fail firing then we get improper colors. This can be rectified by
(1) hitting the monitor at the back by keeping it on a pillow the screen facing down - it will reolve the problem if the failure is due to the loosening of the Head due to repeated thermal expansion and contaction.
(2) check the signal cable for loose connection, twisting etc on both ends - at the back of the CPU and Monitor (it is fixed)
TRY YOUR LUCK
ProfSweetlin
danielswweetlin@gmail.com
Jul 15, 2008 | Samtron 76df 17" CRT Monitor
Our Color TV is now Black & White
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
May 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
My LCD has green spots
i have the same problem in black color but its not my screen i belive its only in vista
Apr 20, 2007 | Vizio L32 32 in. LCD HDTV
Texture malfunction?
You said these didn't fix the problems for "very long," so it sounds like something might be overheating. It could be the card, or possibly your monitor. I would download a program to run diagnostics on the card to specifically check the temperature of the card itself. Perhaps the fan/heatsink needs to be refitted or a better cooling solution for the card.
Oct 14, 2006 | ATI RADEON 9800 PRO (256 MB) Graphic Card
HP Compaq nx7400 Notebook Logo
276 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
