Question about Refrigerators
Freezer cold/Not Cold in Frig KITCHENAID Model KBLC36MHS01
Hi,  I pulled the damper in tyhe Frig as it is not getting cold. It is in the open position. Checked Evap fan in freezer, it is not working. No sign of significant ice buildup. Ordered new evap fan and installed. Let run four hours after plugging in. Not working. Unplugged, turned off remote on/off switch, plugged in and turned on remote start switch. Still did not come on. Also held door button down when freezer door was open. Still did not come on. Any idea what to do next? I need this thing up asap as our home is being sold. Thanks so much for assistance.
  • 1 more comment
  • trjohnson Oct 31, 2007
    No I have not. Don't have VM.  Where would the defro thermostat be near the heater coils on bottom? Thanks
  • trjohnson Nov 15, 2007
    Update to this issue. I was told that the evap fan in this model did not run through the defrost thermostat but instead directly to the cicuit board in the control panel. Since we had a lightning strike about the same time this thing conked out thought this seemed like a likely suspect. So I waited a week to get the part and installed new board and still no evap fan movement. I really need to figure this out asap please help!!
  • 291 Answers
I couldnt find a diagram of this frig.
Some of the evap. fans run thu the defrost thermost ..u could try by-passing thermost and see if fan comes on...  have you checked with volt meter if there was power at the fan motor?
Posted on Oct 31, 2007
  • 1 more comment
  • Mike Johnson
    Mike Johnson Oct 31, 2007
    be at the top of evap see if i can find a pci
  • Mike Johnson
    couldnt find a pic with your model but this is simular
  • Mike Johnson
    Mike Johnson Nov 15, 2007
    I think you need to spend the 15 bucks to get you a meter and do some volt and ohms check... cant help much if you cant tell what your getting or not getting in volts and ohms at different places... I would still by pass the defrost themostat just to be to make sure thats not the problem
I have a 2013 Samsung frig model rf28hfedbww/aa. The top part is not cooling The freezer is ok
Freezer supplies cold air for the fridge section.. Check fridge gasket for tight seal, operating freezer fan along with proper operation of damper mechanism which directs flow of cold air into the refrigerator.
Sep 04, 2017 | Samsung Refrigerators
Refrigerator freezes
Sounds like might be the Temperature Control Thermostat or some sensor in the circuitry telling the compressor and cooling parts to keep running because it thinks it isn't cold enough. There is probably a circulation fan to blow the cold air through the damper and it may not shut off either, conveying too much cold thermal conduction through ducting and all frig parts, regardless of damper being closed or open. With the temperature set on low, do the compressor and fans ever shut off once cold temperatures are attained? Freezer should be 0 or lower, frig 35-40.
check this video at RepairClinic.comhttp://www.youtube.com/watch?v=5vA8Ksv5kVY&feature=player_embedded
Apr 07, 2013 | Electrolux Refrigerators
The blower in frig is not working, frig is warm freezer is working fine, we have vacuumed all area & unplugged for serveral hours. please tell us what else we can try.
all it does is blow cold air from the freezer into the fridge section,open the freezer door,you should hear the fan blowing,no fan fridge will be warm bad evap fan motor,also send the brand name and model number,some machines have dampers in them if the damper is bad it blocks the cold air from entering the fridge section,send model number and brand name,
Sep 25, 2011 | Refrigerators
Vegetable bin keep freezing food. Model # ED2CHOXKQ05
That can be the result of a couple things. Check to see if you hear the fan running in the freezer side? If not, since cold air falls, the cold air could be migrating from the freezer into the frig bottom section through the air duct hole in the back of the frig behind the crisper drawers. If the fan is running the check the air damper in the top left of the frig section. If the frig side is cold enough you should not feel air blowing through. Air flow is only very slight. You will have to remove some plastic cover or duct piece to see if it is closing. If the air damper seems to be working properly, you may have a refrigeration problem indicated by frost build up on the lower part of the freezer back wall. You may want to call in a pro at that point. Hope this helps point you in the right direction. Good Luck
Mar 12, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Hi we have a GBS22HCPABB fridge and the motor runs, frezzer works but fridge will not get cold just stopped
you have a few possibilities 1. a defrost problem restricting air flow from freezer to ref. 2. a bad freezer fan motor 3. a damper issue not opening to allow air to flow from freezer to frig. most all refrigerators generate the cooling from the freezer to the frig via the freezer fan motor
Mar 06, 2010 | Refrigerators
Estate refrigerator does not cool, but the freezer seems to work fine
open the frig door put youer hand over the vent comeing into the frig there should be cold air blowing with freezer door shut if not then opent the freezer door if you get cold air out of the vent now you have a defrost problem if you still have no cold air the damper door on that vent is not opening it will need to be replaced
Mar 27, 2009 | Estate Refrigerators
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer is cold but the frig side is not???
Hi Gotzd,  If you open the fresh food side (not the freezer), and look to the upper left side you will see a plastic shroud or cover. Behind that cover is a printed circuit board (p.c. board)   and a damper motor. That motor brings cold air from the freezer to the fresh food side. The whole damper assembly may need to be replaced. That also includes the cold controls for both sides of the "fridge".  Home Depot Parts and Accessories has the part available. 800.378.5830. Call, give them your model number, and the description, they will locate the part number for you. This MAY be the solution for you, it was for me. Hope this helps, better yet, Hope you've fixed already.
Steve D.,  Owner Handy Home Repair
Jan 17, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kenmore side by side frig
hi!!! it looks like you have a problem with the damper control mechanism inside your frig section..most all new model have an electronic board.replace that and you should be fine..good luck..
Jan 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
520 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
