Question about Toshiba Satellite A135-S4527 Notebook
Display does not function
Power is on and fan is functioning. USB ports have power. CD drive spins. Heat is produced. Monitor is blank. Connect to external monitor is also blank. HD light does not show it being accessed. Caps does not turn on.
  • 700 Answers
Try to clean its memory card or reseat it. You can use clean soft eraser to clean its edge connector. Do this when you first disconnect battery, off, and no other power source is connected to your unit.
This is the first step, then if still nothing check your hard drive and cdrom reseat if needed.
Posted on Jun 16, 2009
Toshiba a305 Screen Blank on Power up.
Yes, the first step would be to use an external monitor. You may have to use the FN key with a function key to tell it to use the external monitor. If the external monitor works, try shining a bright flashlight on the display. If you can see images, then the display itself is probably OK and either the back light or inverter are bad.
If the external does not work and shining a light on the display does not show images, then it could be graphics card or main board.
Does the laptop make any noises? e.g. Can you hear fans, hard drive, does the CD light come on during boot up. If yes, to all the above, then the mainboard seems to be OK and it could be graphics or display. If unsure, you can remove the RAM chips and it should beep upon startup to say there is no memory and this is a good indication that the mainboard is functioning somewhat.
Good luck and post your results for further help and to let me know if you have figured it out.
Aug 21, 2012 | Toshiba Computers & Internet
Blank screen
Did the laptop boot up all the way except the screen is blank? Do you hear fans running and the hard drive spinning, lights on? If you think it booted except the screen is blank try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 23, 2012 | Computers & Internet
How to enable secondary display adapter fujitsu laptop
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
May 18, 2012 | Fujitsu LifeBook Computers & Internet
Blank screen
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this:
When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 14, 2012 | Computers & Internet
All the lights come on when I switch on my HP Pavillion dv9600 but the screen is blank.
DO THIS FIRST - Perform a hard reset If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Actions to take after performing hard reset If no error message is displayed:
If a text error message is displayed, see Troubleshooting Error Messages on a Black Screen During Startup or Boot c02076104.jpg
Black Screen with No Error Messages Connect an external monitor c02076105.gif If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance. Disconnect all peripherals and repeat the hard reset Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset , some devices are often overlooked. c02069237.gif Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.B
b52compters@gmail.com
B52computers
Chris Thrash
Jan 10, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
The LCD screen for the duplicator go blank after power is switched on. The condition persist for a long time without any change/improvement. The unit cannot function.
before remove all the power plugs to all dvd drives and just let the controller plugged to power dose it works the display if yes try to connect one by one the drives and check the controller display till its ok and then may be one of the drive is defective.if still the same try changing the powersupply .
thanks
Dec 14, 2010 | Lite On Dupsonic 52X 1 to 11 CD Duplicator...
Hello! I am trying to solve my pc problems right now. I currently have a mpga478b motherboard. There is no display on the monitor. The hard drive is also not functioning because it doesn't have a red light...
Change the power-supply.
Although it is putting-out the correct voltage to spin a fan,
it could possibly _not_ be putting out the other necessary voltages.
Oct 26, 2010 | Computers & Internet
Newly build computer problems
i bet your power supply isnt powerful enuf for your video card.
Jan 31, 2009 | ASUS M3A78 Pro AMD 780G AM2+/AM2 Phenom...
Blank screen on start up on Acer Extensa 4620
Did you switch displays to the external video? Try hitting the Fn key and whichever function key at the top of the keyboard has a little TV screen icon over it at the same time.
Jan 04, 2009 | Acer Extensa 4620 Notebook
Dead compaq laptop, no boot activity
Larnold..Sounding like you need to check the LCD Power Inverter Circuit board.. this is located inside the screen a long rectangular circuit board that sends power to the screen backlight & Display Panel.. Could also be a Bad Backlight.. Try Booting it.. Hold it up to a light and look closely at the screen.. If you see a faint image but no light, it is the Backlight, if Just Black No Activity then its most likely the Power Inverter, OR a Bad Video Card.. You can test the VIDEO by Connecting the laptop to a Computer Monitor or similar with the laptops VGA Serial port.. then Use your function Key and Switch to 2nd Display.....(one of your F keys.. ).. If it Shows up on another screen, Its a Display problem and not the video card... Hope This Helps alittle.. Cheers
Jun 02, 2008 | HP Compaq Presario V6000T Notebook
Toshiba Satellite A135-S4527 Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
