Question about Ulead Videostudio 8 for PC
I installed the easycapcapture video adapter. but when i plug the usb adapter, tells me that the driver could not be found
  • 93 Answers
Yes. You will either need a driver CD or you will need to download the driver.
Posted on Jun 16, 2009
How can i connect my D-LINK 3.75G HSUPA USB Adapter to my windows 7
The USB Adapter is plug and play. This means Windows will automatically detect it and start installing the drivers for it. If Windows is unable to install the drivers you might have to install the ones from the CD if one was provided along with the USB Adapter.
Please note that according to the specifications I found the D-LINK 3.75G HSUPA is only compatible with USB 2.0. This means that if you plug it into a USB 3.0 port it won't be detected by your computer and the USB Adapter will not work.
Jan 13, 2014 | D-Link DWM-156 3.75G HSUPA USB Adaptor
Sm-usb 007 device unplugged
hi, the 64 bit driver may be the issue , somehow it's not correctly installed or using a 32bit driver, remove step back on system restore so there's no trace of the installed driver, or un-install however there may be some entries in the registry left behind... okay reboot.... just plug in the device. Does Win7 install a driver ?? I had a issue with similar hardware in Win 8 however it did solve it and it's working now..
Goodluck
Rob.
www.gewizpc.co.uk
Jan 08, 2014 | DekCell EasyCap USB 20 Video Capture...
Won't detect usb from cd instalation
Have you read the instructions.
Have you disconnected usb while installing disc,this is important.Wait till the installation tells you to plug in the usb adapter,then the driver will detect the adapter at the port because it is now searching for it.Good Luck.
Aug 10, 2010 | NetGear : WPN311 Wireless PCI Adapter...
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
I recently purchased this. (http://www.newegg.com/Product/Product.aspx?Item=N82E16833127272) and a copy of Windows 7 64-bit OEM. So, I go to install the utility and drivers and after the point where it...
Did you try these drivers for DWA-125?
ftp://ftp.dlink.com/Wireless/dwa125/Drivers/dwa125_drivers_120.zip
If your model is DWA-125 RevA2 then you need these drivers for it.
ftp://ftp.dlink.com/Wireless/dwa125_revA2/Drivers/dwa125_revA2_drivers_130.zip
Uninstall all the previous drivers/ apps related to your adapter. Download the appropriate drivers above. Unzip/ extract the file. But don't run any installer yet.
Plug in your adapter first cancel the windows new hardware found pop up if it come up. If windows says no drivers found thats ok. If windows finds the drivers and installs it right then great if not then lets move on.
Open device manager. Click on the adapter and click upgrade driver and select find drivers manually. Point it to the folder you unzipped all the files too. And windows should install the drivers this time.
Let us know how it goes..
Apr 02, 2010 | D-Link DWA-125 Wireless 150 USB Adapter...
Drivers won't install
Two possibilites here
1. the driver CD is corrupt , though belkin is a plug n play adapter, there is no need to install the cd
2. Since you getting an excalmation suggests , windows recoganises the new hardware but fails to install.
The best option is either change the manufacturer of the adapter or reinstall windows , it should fix your problem
Apr 05, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
EasyCap in Windows Vista
you will need ulead 10 on vista or download amcap free that works well on vista
Nov 10, 2007 | Ulead Videostudio 8 for PC
CAN NOT FIND SOFTWARE TO INSTALL HARDWARE
here, read this - you should use an ethernet cable to install the router - it is alot easier but here is the manual that will tell you exactly what to do - http://www.buffalo-technology.com/support/getfile/?WBMR-G54+Manual.pdf
Sep 19, 2007 | Buffalo Technology Buffalo AirStation...
Failed to install
Belkin drivers are a bit of a pain, uninstall the drivers again and remove the usb adapter, and follow exactly as per instructions, normally driver first, but ignore the pop up about the driver not being a signed windows if it does, just click install anyway. toward the end of the installation you should be prompted to connect the usb adapter, the hardware should be found and then the installation should complete. If driver installed ok but the adapter cant find the the driver plug it into a different usb port and again the found hardware should pop up then install driver popup should show and you should select install automatically.
Sep 10, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Ulead Videostudio 8 for PC Logo
268 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
