-   yeah, i have the sony np-f750 and it does the same thing. It's very frustrating.-   Guest
Jan 26, 2009
-   same thing
-   Guest
Jan 17, 2009
-   I am afraid I have exactly the same problem. I have hardly ever used the camera. I have told I might as well throw it away.-   helloodvdm1
Oct 18, 2008
-   My Casio 750i does exactly the same.-   radubradu
Aug 15, 2008
-   I'm having the same problem with my ZR200. I put the tape in and close it down but then it pops it back up. If I take the tape out it works perfectly. I close the door and then the machine pulls the tape compartment in so I am able to close the main door.
I am 100% sure it is not a tape problem because its the ONLY tapes I buy and I have used it several times.-   Guest
I Had The Same Issue And Fixed It :o) I Have A Sony Handycam CCD F-730A 8mm. I put the tape in and close it but it would not load the tape down. It just pop back out. If I took the tape out, it works perfectly and would loaded the tape doc down and close.
1st: I unscrewed and removed the door to the tape. Where the tape can be seen. 2 screws hold it down. Without the tape inside. I Saw a Clear Small Plastic in the inside of the camera where the tape sits on each side. On Both Sides, Left and Right are clear plastic like sensors. They look Like Glass and are small.
2nd: I Cleaned them both with a Q-tip and rubbing alcohol. It Worked. The tape loaded and worked nicely.
It was strange. If i touched one of the small glass like sensors. the mechanism the loede the tape would not work. When The Glass sensor was blocked by the tape or just by my finger in front of it, it would not load. Very strange.
is JVC model# gz-ms130bus a good choice and will it take good still pictures, what is the resolution...
(More)
is JVC model# gz-ms130bus a good choice and will it take good still pictures, what is the resolution or megapixel
I had a Sony DCR-TRV460 Digital8 Camera stolen and I need to replace it to be able to play my many 8...
(More)
I had a Sony DCR-TRV460 Digital8 Camera stolen and I need to replace it to be able to play my many 8 mm.Hi-8 and Digital8 tapes. What do you suggest?
i have a vivitar dvr 550 model no.s/n:9cyvivdbcaoo707 i have lost all the instructions on how to use...
(More)
I HAVE A VIVITAR DVR 550 MODEL NO.S/N:9CYVIVDBCAOO707 I HAVE LOST ALL THE INSTRUCTIONS ON HOW TO USE IT...CAN YOU HELP?
