Question about IBM Network Printer 12 Laser
Snaps@snaps.com.ar We HAVE A PRINTER 12 IBM THAT TAKES 2 PAPERS LEAVES WHEN FEEDING THE PAPER A4 AT THE SAME TIME. DOES THIS HAVE SOLUTION THERE IS.?
  • 21 Answers
Clean or replace the rollers that pick up paper, they unclick for removal quite easily
Posted on Jul 08, 2009
I'm using half of A4 size paper and when I print my file on it, it takes 20 seconds after feeding the paper. Is there anything I can do to make it faster?
I fixed your capitalisation, punctuation and grammar. Half of an A4 sheet is an A5 sheet and should take half as long to print an A4 sheet. Print speed is dependent on a number of variables;
Density of colour, the more colour or more blocks of black take longer. Yours is monochrome and these are the specs. You should get 12 pages per minute. It may be that your computer is slow and also is low on available RAM memory. This is an old printer and you may think about upgrading. I had one of these 10 years ago.
Benefits
  • 12 ppm mono printing
  • Zero warm-up time from sleep mode
  • First Print Out Time in only 9.3 seconds
  • Up to 2400 x 600dpi print resolution
  • Energy efficient and quiet operation
  • Easy to use All-in-One cartridge
You should get 12 pages per minutes
Sep 16, 2015 | Canon LASER SHOT LBP-2900 Printer
Wont stop paper feeding
Check the Remaining Print Jobs in your PC and Delete ALL OF THEM
Feb 28, 2014 | Brother HL-2240 Monochrome Laser Printer
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
Hello, i have a HP Officejet Pro L7480 which did not cause trouble for 3 years, but now: PROBLEM WITH PAPER FEEDING - when trying to print something, the printer normally "tries" to grasp a...
Hi
If it attempts to feed and expecially when you hear a cricking sound. It means that the paper guide it too tighten that it holds the paper. Try to loose up the paper tray guide. Are you using a paper tray. If not, put small paper or change the correct setting of the paper size setting to auto detect if any.
The try to print again.
Mar 31, 2011 | HP Officejet Pro L7480 All-in-One...
Model AR-C160 \r\n Load 8/12 by 11R Online symbol flashing red
THATS THE PAPER SIZE FOR A4 LEGAL OR FULLSCAPE.SO PL THE LOAD THE PAPER OR CHANGE SETTINGS TO A4 PAPER
Jan 14, 2011 | Sharp AR-160 Copier
Document feed takes more than one page at a time
please follow these steps to solve your problem:
1.Fan the papers before loading them in printer tray.
2. Dont use papers that has lot of wrinkles
3. Dont insert your papers too long into your printer. Just load them with optimal distance.
4. After the papers were loaded, adjust the paper hold knob present on either side of the paper such that it holds the paper firmly on both sides.
Now your printer will take one paper at a time for printing.
I hope this is helpful to you. Please provide your rating and comments for the solution provided.
thanks
Mar 08, 2010 | Office Equipment & Supplies
Printing and picking the papers problem
HI there,
This issue occurs when the setting on the firmware of the machine does not match. Generally we use A4 / Plain paper, whereas the default setting on the firmware of the printer is Any size / Any type.
Hence if the printer is connected via USB, open the HP Toolbox and got to the paper handling section, set
Tray 1 = Any size / Any Type
Tray 2 = A4 / Plain
If the printer is connected via network, access the IP address of the printer and got to the settings tab > paper handling change the setting as shown above.
Let me know the next update.
Rgds,
Nikhil
Sep 10, 2009 | HP LaserJet 1320n Printer
MY ESP 5 PRINTER WILL NOT DETECT THE PAPERS EDGE.
Kodak printers support the following paper sizes: 3½ × 5 in. 4 × 6 in. 4 × 8 in. 4 × 12 in. 5 × 7 in. 6 × 9 in. 8 × 10 in. A4
Make sure that the grey coloured paper alignment is aligned properly to the edge of the paper.
turn your printer off and then turn it on again. put papers and align the paper alignment. try to print,your issue will be resolved.
Apr 04, 2009 | Kodak ESP 5 Printer
IBM Network Printer 12 Laser Logo
102 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
