Question about Brother MFC 7840W Printer
After 3 years of use with no problems, the 7840W printer will not print.
All is well until the printing command is sent to the printer and it is ready to be done. At that time the printer quietly shows the message "printer error" on my computer screen and does nothing.I have done the delete and reinstall printer move - that goes well but still nothing. I have done the disconnect printer from wall outlet and reboot the computer combination - nothing. Help please. I'm a senior citizen so do not presume I have much technical knowledge.
SOURCE:
pagebor
  • 2785 Answers
SOURCE: Check Connection Brother MFC-845CW
plz try with new usb cable
Posted on Jun 30, 2008
SOURCE: "Document Failed to Print" - printer is "receiving data" but nothing ever comes out
Have you tried restoring to a previously known date that all worked well?
Go into System Restore and try there.
Posted on Oct 05, 2008
yooperbud
  • 8637 Answers
SOURCE: Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
xptareq2000
  • 1447 Answers
SOURCE: Just bought a new brother HL-2170W, installed the
it is problem your operating system or driver installation
Posted on Sep 07, 2009
My HL2040 laser printer will print "Print Settings" page but otherwise will not print at all.
Set this printer as the default printer or if there are multiple printers connected or installed specify the printer issue print command
Jun 06, 2015 | Brother HL-2040 Laser Printer
The Brother MFC-7840W printer was installed on a USB connection. The printer worked the previous week albeit not for all applications but at least for the Vista word program. Now it doesn't respond to...
Hi there!
You can check if the usb cable is connected directly & securely from printer to your computer. Once it's verified. The display of your printer should show the date/time.
Since the printer is displaying offline you can open Control Panel, go to Printers folder right click on the printer icon and select 'Use printer online' If you have pending documents right click on the printer icon and click on cancel documents.
Try checking for a duplicate copy of your printer driver or check which printer driver is selected as the default and has the status ready.
Right click on the printer driver that has a Ready status click on printing preferences and click on print a test page.
Hope this helps! Vikroks
Mar 22, 2011 | Brother MFC 7840W Printer
I tried to empty the spool and the job seems to still be stuck...what can I do to cancel the job?
you'll also need to unplug the printer from the power outlet and keep it like that for about 15 minutes. With the spooler empty, this should clear out the memory of the printer and get you back to a fresh start. This happened a lot with HP 1000 lasers, it's the first time I hear another model having the same issue... but the basic problem is the same, the spooler sends a Get Ready command to the printer, then processes the print document and sends it off. If you erase the document before it's sent to print, or the printer doesnt echo with OK to Print, then the spooler sits and waits for the printer to get ready, and the printer for some reason gets stuck with a Get Ready command without responding back. So clearing the spooler and turning off the printer for 15 seconds usually fixes the problem.
If you liked this explanation please vote with a Thumb Up. Thanks.
Jan 18, 2011 | HP PSC 1401 All-In-One Printer
It only prints a 6x1"
Sony printers are masterpeices when it comes to digital printing as they produce wonderful quality images.
If you got a new printer and it does the same thing this indicates that the problem iis emanating from the software with which you use in editing the pictures before sending the print command. Somewhere along the line some adjustment must have been made to the software relating to the alignment of the picture on the printer. Once this adjustment is corrected your printer will print fine.
Printers are devices which prints what command was sent to them and do not have any intelligence to act or edit documents on their own accord.
Hope this solution has been helpful?
Happy new year
Jan 03, 2011 | Sony DPP-FP30 Thermal Photo Printer
How do I cancel an order to make it stop printing and clear it out of the system
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jun 23, 2010 | Zebra 105SL Thermal Label Printer
How do I turn it on
Click on Run
Alternate method,
Click STart
Click RUN
Type
Jun 19, 2010 | Dell 926 All-In-One InkJet Printer
Machine will not print double-sided documents
Try resetting the NVRAM from the diagnostics screen.
Apr 09, 2009 | Xerox Phaser 8560MFP Laser Printer
My printer will not print anyhting I have sent from my computer. I have tried to test print, command prompt to print and still nothing. I also went in to see how many things were waiting to print and there...
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Oct 10, 2008 | Computers & Internet
Brother MFC 7840W Printer Logo
59 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
