Question about Sylvania LC320SS8 32 in. LCD Television
I have a sylvania model LD370SC8S 37' i turn it on it comes on but goes to a blinking green light
    New Friend:
I had the same problem, i just separated the wires & taped the parts where the wires came off
Posted on Nov 10, 2012
SOURCE: phillips plasma tv model #42pf5321d/37
4 times
Posted on May 31, 2008
  • 61 Answers
SOURCE: Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Posted on Nov 19, 2008
  • 3 Answers
SOURCE: RED LIGHT BLINKS SEVEN TIMES
The most likely problem are two failed capacitors on the main board in the center of the TV The failed parts are easy to identify as the top of the cap will no longer be flat but will have bulged up. DO NOT attempt to remove the back of the TV unless you know what you are doing.
soldering on a circuit board will be required to fix this problem.
Posted on Aug 10, 2009
dsacco86
  • 1077 Answers
SOURCE: Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Posted on Aug 12, 2009
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
My 32 in. sylvania power light blinks green & doesn't turn on & goes right to the red standby light. Why
Power board is dead,must replaced parts like capacitors puff up or burst open.Or replaced the whole power board.The websites Shopjimmy.com,Ebay.com have reburbish power board part.
Jan 13, 2010 | Sylvania LC370SL8 37 in. LCD Television
SYLAVANIA green light blinks a few times and goes back to red
Funai used lousy wire going from the inverter board to the backlight tubes. Look for any wires that are touching each other. The insulation could have broke down between them and started arching. Get some heatshrink tubing to recover the damaged wires.
Sep 20, 2009 | Sylvania LD370SS8 37 in. LCD Television
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
Stand by
is the dvd part was working ok because that may the problem
May 09, 2008 | Televison & Video
Sylvania LC320SS8 32 in. LCD Television Logo
586 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
