Question about iLO 2600 Television
Same Issue I think mine is getting to hot.. I put a fan next to it and the problem dose not return or unplug it for 5 mins and wait for it to cool down. Weird thing is that it only does this on component 1 not number 2 or any of the others, DVI, VGA, AV..etc...
    Problem Solver:
  • 11 Answers
New card. or better cooler.
Posted on Jun 16, 2009
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 05, 2017 | Heating & Cooling
Jenn air refrigerator model jbr2088hes is not cooling fan is blowing and cool air is coming into refrigerator
A compressor can naturally get hot the tech leaving parts on the floor is wrong the real way to tell if the compressor is bad is to unplug the fridge find the thermostat and unplug the two wires that plug into it then make a small jumper wire with two male spades and a two inch peice of wire and plug it in to both of the wires that you unhooked from the thermostat then plug in the fridge and wait 20 min if the fridge gets to normal cold which is 37 degrees or less it's not the compressor it's the thermostat but if it don't get any colder than before it may be the compressor but a new fridge is less that 500 dollars
Mar 12, 2014 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Mine shuts off and blinks red once it gets hot I think....I can put a fan in the back to blow air at it and it will work for a good while. The manual says it is not getting air but there is nothing really...
Clearly, heat is an issue if a fan helps it stay up longer.
After 5 or 6 years there may be an accumulation of dust bunnies inside it.
Unplug it and take the cover off. Blow it out, clean the vent holes and see what happens.
Jan 28, 2011 | Denon AVR-1604 Receiver
Both refrig and freezer won't cool. the compressor has power but doesnt seem to get warm or hot. I think it is suppose to.
unplug the frig, then wait about 20 min.. to let compressor cool down. then plug back in..wait to see or look at compressor..see if you can see or hear it start up...if not..good chance you compressor has failed....
Dec 19, 2010 | Refrigerators
Green light flashes for about a minute, fan does not turn on and there is no picture or sound.
unplug all cords and cables from tv, then unplug tv, wait about 5 min, plug tv back in this resets, the "brain" if samething ....see if your bulb is glowing, or tv is hot to touch...always clean the breather slots or holes so fan can push or pull cool air..most of these tvs have a auto shut off for safety if fan has faulted out.....you might just have a DONE fan unit.
Jun 27, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Running very hot and shutting down
You are running into a CPU overheat issue.
1. can you feel or hear the cooling fan come on at all? If so try and use compressed air can to clean it out.. they get tremendously dirty. You can also try a vacuum hose, but cover nozzle with hand and only hold next to cooling fan outlet and nowehre else with laptop off and unplugged. Dont get near keys or other parts as will damage. Dont use SHOP VAC either.
2. If Cooling fan is NOT Coming on you can try a laptop cooling pad. these are external units by Targus and other companies that have cooling fans to supplement a laptop units cooling fan. You can try this to see if airflow is your problem.
3. If you recently ran encryption software, a new antivirus program, or upgraded to Windows 7 it is possible that your culprit is the unit is not cycling. Meaning the hard drive is continuously being accessed and the CPU is in constant service... this can cause overheating as well.
Jun 02, 2010 | Toshiba Satellite A135-S2276 Notebook
Kitchen Aid #KSCs25INSS01: Outside of Freezer is very hot, jumped down to -15 degrees - will not allow readjustment.
I recently had the same issue of the sides/center becoming hot on my kscs25inss01. The cooling fan would not come on. I kept unplugging and waiting for a while then re-plugging in to get the fan to work for a while (it would run about 12 hours then get hot again, it also takes 7 minutes for fan to come on after plugged in). I also placed a small box fan at the rear vent pulling the air out. I ordered the contoller board and replaced it, now, the fan comes on and it is staying cool.
Replacement:
I removed panel in lower back,
removed inverter box next to compressor,
removed gounding wire on frame,
then removed the controller box - metal box along side of refrigerator
Popped out old board ,
moved the center jumper from old board to new board in same location,
and plugged everything in and sealed it back up in reverse order.
May 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
May 30, 2007 | Danby DWC283BLS Wine Cooler
Televison & Video Logo
29 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
