My washing machine is leaking from bottom. - Washing Machines
  • 365 Answers
It is possible the shaft seal on the bottom of the plastic tub has failed, if you can remove the front cover you should be able to pinpoint the area where it is leaking.
It could also be the large hose running from the bottom of the tub to the water pump, may be split from age.
Also check the inlet hose for leaks
Hope this has helped
Posted on Jun 16, 2009
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Washing machine is leaking from the bottom of the machine and leaking after the wash cycle inside. 622797 style no. The machine leaks during the rinse cycle from the bottom.
Washing machine is leaking from the bottom This video will show you how to find the leak on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jun 07, 2011 | KitchenAid Washing Machines
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Leak coming from the bottom of my washing machine
HELLO TOM DID YOU CHECK TO SEE IF YOUR DRAIN VALVE IS LEAKING ?normaly there located at the bottom of the washer inside the back cover.
Apr 01, 2009 | Whirlpool LSN2000LW Washer
Washing machine is leaking from bottom
Take front off and see where leak is coming from. Most common is either a split hose or bad tub seal. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Frigidaire CWS3600AS Top Load Washer
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Kleenmaid top loader Washing Machine Mod KAW 793W leaking
Problem turned out to be a leak from the top, not the bottom and was caused by debris blocking an overflow trap
Aug 03, 2008 | Washing Machines
My washing machine keeps leaking from the bottom
For me there is not enough information. What hose did you replace and when does the machine start to leak ?
Dec 26, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
