SOURCE: MY HD TV GOT PROBLEMS
replace the convergence ICs you can get replacements at the following link. You need two STK392-560 convergence ICs and a couple 5 amp pico fuses. Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: tv screen will not stop blinking
It sounds definitely like a faulty power connection via the video cable from the inside. If it blinks a while then turns black then shows the picture, it would have to be that it's not screwed on properly, thus taking more time for it to get a full charge and then properly function. If you still have the warranty, any electric repair/retailer shop can fix it for you.
SOURCE: sony big screen tv 57 inch kp57wv600 ghost
"ghost" are not television problem. This happens when a nearby structure "echoes" the signal from the station to your TV, there is nothing wrong with it.
SOURCE: i have a 2000 sony 53 inch projection tv that
It could be an issue with yoru DMD board, which are micromirrors, those are the ones that form the image. discountdashmerchantdotcom
SOURCE: I HAVE A SONY KP-53V90 53 INCH REAR PROJECTION TV
You have a convergence issue, will have to check convergence IC,S or just replace them there are usually two of them mounted on heat sinks they are usually STK'S with a number after. Also must check fuseable resistors supplying +15 and - 15 volt s to the chips. After replacement some convergence alignment may be needed. Good Luck.
Mike
