Question about Arcam AVR-200 Receiver
Speaker setup should I set up a5.1 or a 7.1 speaker set-up for my Denon 2808 if my couch is against the wall in my room. that would put the side speakers and the back speakers close to each other.thank YouMarc
  • 979 Answers
Need dimensions of the room...accordianman
Posted on Oct 31, 2007
Speaker set up question
I generally only use 2 tower speakers but the extra 2 could be used for rear or surround speakers. Set up your home theatre like a box. Use 2 towers at the front on either side of the TV. Your surround speakers should be in the middle ground (if your couch is in the center of the room, that means to the left and to the right of your couch). Your rear speakers should be similar to your front speakers, just behind you or a little off to the side. These inputs are clearly labelled on the back which is handy. The only thing you're missing is the center speaker, which goes right under the TV. I recommend getting one because this is the speaker that outputs most of the sound for speaking. The 606 has a really handy mic setup program, which I recommend using (it configures the volume for each speaker based on the distance from your seated position). I hope that helps you out!
Dec 19, 2009 | Onkyo TX-SR606 Receiver
Bought new Denon receiver. Hooked up main speakers to speaker A and 3 sets of small speakers (outside, living room and dining room (in wall) to speaker B. I use a splitter for the 3 speakers on B. The...
Speakers have what they call an ohm rating. Your 570 watt receiver is 570 watts at a certain ohm load. I would imagine there might be a level difference between the 3 different speakers on B too. Anyway, if the speaker pairs have all different ohm ratings, or they are not the optimum rating for your 570 watt receiver, you will not get the full wattage rating to the speakers. Hope this helps.
Jun 23, 2009 | Pioneer VSX-454 Receiver
Base too heavy for downstairs neighbors
Try a board with two screws through the front and one at the rear,set on the floor points down and then set your sub on top,this should help,also if you make 2or3 boards your bass should be tighter and not travel so much down to the flat below but will not go away,sorry but the only other thing you can do is buy ear plugs for your neighbours.
Hope this helps.
Apr 19, 2009 | Bose Acoustimass 5 III System
Trying to hook up Zone B stereo speakers in two additional rooms.
The infrared mentioned by the manual is most likely an extension possibility to use the remote control in each room, forget that part.
What you need to do is quite simpel, after connecting all speakers, you should indicate in the setup menu of each zone which speakers are connected and do as follows:
in main room select 5.1 setup, for the other zone select only the left and right front speakers.
Your EXTRA SP indicates the extra speakers for 7.1 setup and when set to zone B it recognises only 1 speaker.
So read carefully the manual how to connect Zone 2 speakers and connect that way, than carefully walk through the setup menu to setup the zone 2 correctly.
Apr 09, 2009 | Yamaha RX-V663 Receiver
AVR 2808 CI remote does not recognize back speakers.
perhaps that's why it was returned...Take it back for a replacement.
Apr 01, 2009 | Denon AVR 2808Ci Receiver
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Zone 2 Setup
Turn Zone 2 off. Speaker selector is made through pressing the dial below the volume dial
Mar 24, 2008 | Denon AVR588 Receiver
How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Aug 12, 2007 | Denon D-M71DVS System
Arcam AVR-200 Receiver Logo
97 people viewed this question
Top Arcam Audio Players & Recorders Experts
Sock Puppet
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
