Question about Konica Minolta PagePro 1350W Laser Printer
Printer cannot detect genuine toner cartridge
  • 210 Answers
Clean the sensor that reads the toner cartridge.
Posted on Aug 26, 2009
  • 4 Answers
SOURCE: illegal toner
The HL2700CN is a Tally machine rebadged by a number of manufacturers.  Each has it's own unique 'plug' on the back left side of the cartridge as you look at it in the machine.  Check that the plug is the right shape and if necessary fit the one from your empty 'brother' cartridge.
I have only ever had the 'illegal toner' message when I put in a Lexmark cartridge by mistake - swapping plugs solved it.
'Brother' machines seem to run at a different temperature than other Tally clones - so there may be a deeper problem with the toner that you used.  In my case it simply failed to fuse to the paper and I had to get another cartridge.  Check for deposits on the OPC belt and fuser rollers.
Posted on May 09, 2008
IB4G2008
  • 3587 Answers
SOURCE: Cannon IP1880 Cannot detect Cartridge
hmmm..well..you may find that new drivers help a bit.
get them here
Posted on Mar 20, 2008
  • 214 Answers
SOURCE: Toner Not Installed - After replace black
pleas clean toner chip reader, remove pc drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it. if the new BK toner is not original, it will say only not genuine toner but will print.
Posted on Jul 01, 2008
  • 52 Answers
SOURCE: "Can't Detect Genuine Toner Cartridge"
minolta printers work on "chips" if the chip atached to the cartridge is not original minolta you better change it.
Posted on Jun 18, 2009
rulds2008
  • 3866 Answers
SOURCE: New Samsung toner cart reads LOW
This is due to a sensor that reads the actual cartridge is defective not the actual cartridge or the cartridge is one that was refilled and thus not put back togeather the way it should have been. So its ether or a refilled cartridge or a bad sensor. Both req. repair in some sort.
Thanks for your free question, your free answer was delivered please do rate or leave some feedback.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 22, 2010
My cartridge is full of toner but the printer says it needs to be replaced, how do i reset the cartridge?
You can't. The toner levels are calculated and approximated. Make sure you use genuine Kyocera toner and replace it.
Sep 27, 2013 | Kyocera 1T05JK0US0 Model TK-152K Black...
I've refilled Kyocera FS- 1135 mfp then not genuine toner had detected.. but the toner i used is kyocera compatible toner and its working to other kyocera machines.. Is it because of the IC chips or what?...
Kyocera compatible does not mean Kyocera genuine. Not using genuine toner can invalidate your warranty. If that doesn't bother you then the printer detecting a non-genuine cartridge is not an issue.
Sep 02, 2013 | Kyocera FS Office Equipment & Supplies
Hp laser jet 1018 giving error that front door is open or toner cartridge is missing
If you are using a non genuine HP cartridge, it is very likely it is defective and can not read the chip on the cartridge. Replace the toner with a Genuine HP cartridge.
Jan 12, 2011 | HP LaserJet 1020 Printer
I have samsung ml 2010 printer. i always get the message install toner cartridge. but it has a lot of toner it. ihad open it and saw a lot of toner
there is a problem with the detection of toner, could be:
  • the toner cartridge not set in the printer correctly
  • the toner cartridge is faulty (replacing the cartridge may fix)
  • a part in the printer is faulty and is not detecting the toner, or toner cartridge
I'm not exactly familiar with where the toner is detected but you could use an 'air brush' to clean the printer, as perhaps the part that contacts with the cartridge is dirty. You could give the toner cartridge a little side-to-side shake as this may even out the toner and activate the part that detects the toner.
Oct 30, 2010 | Samsung ML 2010 Laser Printer
Recently had a low toner message for black. Next time I went to use a fault appeared - incoreect cartridge. I replaced black toner with genuine Lexmark cartridge - message still appears. Have turned...
Nice job on trying different ways to resolve the problem - turning off/on the printer, removing power source, reseating the cartridges and even changing the cartridge with a genuine Lexmark cartridge. You pretty much did the necessary. Genuine Lexmark cartridges shouldn't cause you that much trouble. I strongly suggest you contact Lexmark technical support to further investigate the problem.
Sep 01, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hi, there is a toner cartridge inserted on my prin...
Either toner cartridge faulty or printer detected non-genuine toner cartridge.
May 21, 2010 | Canon LASER SHOT LBP-2900 Printer
I have two HP 2600N printers that print Yellow onto the whole page. Replaced Toner and it wont and worked for a short time and then got worse with the yellow on the page. One of the units says yellow toner...
Generally this is a toner cartridge issue. Are you using genuine toner cartridges or generic remanufactured? I have attended alot of repairs on this model when clients use generic cartridges. Usually a genuine cartridge fixes the problem.
Jul 13, 2009 | HP Color LaserJet 2600n Printer
HP CLJ 3550n
Are you using genuine hp cartridges?
Jan 07, 2008 | Office Equipment & Supplies
Oct 28, 2007 | Konica Minolta PagePro 1350W Laser Printer
False Toner message
Are you using genuine HP toners? If not HP puts a chip on there cartridges that tells the machine it is a new cartridge. Some generic toners do not replace this chip therefor giving you this false message.
Jun 21, 2007 | HP LaserJet 4600dn Color Printer
Konica Minolta PagePro 1350W Laser Printer Logo
332 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
