Question about Saeco Royal Professional Espresso Machine
Same problem here
I suspect it’s a leak that’s causing it to short. I am about to pull mine apart to try and isolate. Does anyone have any advice or suggestions before I start?
Thanks
  • mike980866 Jun 16, 2009
    Thanks, I will check that out.
    There is no water under or around the machine. Its a Royal Cappuccino (SUP016R), about 3-4 years old. It still makes a good coffee only shorting when running the descale rinse cycle.
    Thanks again, I have pulled the top off but cannot see any obvious signs of leakage from here. Are there any tricks for taking the left / back casing off? It seems to be stuck on there pretty well.
  • 1,089 Answers
Hi If you are getting a short there are a lot of places that could cause it but I would suspect that you have a leak around your steam boiler hoses. It is located just above the main switch. Do you have any water under the machine? How old is the machine? Is it a Royal Pro?
Posted on Jun 16, 2009
  • bansheracer Jun 16, 2009
    Hi
    On any automatic machine it is always the best idea to set the water hardness to 4. Most people think their water doesn't have much mineral in it but it does have the one that will cause the boilers to leak if they are not descaled enough. I have some parts for the Royal Cap, but not a lot.
    Remember when you remove the top it has to slide forward so that the Cap. part on the left will slide from its hole. Same when reinstalling.
My amp plays two songs then goes into protection mode.
Most likely cause is one of your speakers has shorted out or the wiring to them. try disconnecting them one at a time as this may help isolate the problem.
Oct 15, 2016 | Car Audio & Video
CAFFITALY S20 My pod machine seems to have developed a leak and I need to take it apart. Does anyone know what the trick is ?
The leaks are usually caused by build up of calcium - it can be quite a trick process to open these things - isolate the leak first so you know where it is coming from.
Jul 29, 2016 | Coffee Makers & Espresso Machines
2005 yamaha rhino. My 15 amp headlamp fuse keeps blowing. could a bad headlamp cause this?
Mine would do this, intermittently, and after a couple of years I, while upgrading my lamps, that there was a short to ground (chassis) near the lamp fixture. I'd start looking there.
I would measure resistance of the wire feeding that each lamp to ground, and move that wire around to see if the resistance increases to try to isolate which side, or which lamp is causing the problem. Dont forget that it might be the tail light or marker lights on the side (if you have these)
Aug 13, 2014 | Yamaha 2005 Rhino 660 Auto 4x4
Im working on a 92 superduty. i replaced both alternator and voltage regulator seperately and i am still drawing 3.9 amps from the battery. i have isolated the problem to the solenoid alternator and...
Not sure what you mean with this: "solenoid alternator "
If you installed a rebuilt unit, it may still have one leaking diode of the six which can cause this. Having a single bad diode won't stop the alternator from being able to recharge the battery but if the reverse resistance isn't near infinite, you will have the problem you describe.
Pulling and replugging one fuse after another and watching for a change in the current drawn should help you isolate the circuit still drawing current. If this didn't cause any change, I would have the alternator tested again.
Aug 24, 2011 | 1992 Ford F350
Freezing after warming up...
Some component or part of the amp is heating up and breaking down. You can take the unit apart, and when it fails, spray some freeze spray on suspected components until it works again. That way you can isolate the temperature sensitive failing part.
Jun 30, 2010 | Peavey Pv 2600 Power Amplifier
The car has developed a 'hissing' noise that occurs after ~5-10 minutes of driving; only hear down by the pedals and not very loud, and doesn't/hasn't seemed to affect driving or any of the gauges....
a lot of the air vents are controlled by vacumn, some auto stores sell cheap stethescopes to help isolate the leak, before you pull the whole dash apart. change the air vent settings , may help isolate it as well
Apr 22, 2010 | 2000 Chevrolet Corvette
My dell 2350 shuts off wjen i try n boot it up can anyone help
Hi my name is Roety,
I can help you with your issue ,
First of all you can try entering safe mode by pressing F8 and try restoring the PC to a previous date.
If the PC never boots at all is is either a corrupt windows install or possible hardware issue.
Removing a memory stick and trying the PC with one stick at a time can isolate a bad memory stick.
Pulling the cards and trying the PC with just the motherboard and video card only.
Of course never pull a hardware part while the PC is on.
If all this fails you either have a bad power supply or motherboard.
The motherboard is the most likely suspect.
This all depends on how far it boots up, if you see the text and or windows xp start to load just reinstall windows.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jan 29, 2010 | ASUS A7V8X Motherboard
After getting windows updates, the laptop gets to stage 3 of 3 and keeps resetting itself, I can't load windows because whenever I do it automatically tries to complete the update, resets and repeats! The...
Start your system by pressing F8 during startup;Select "last know good configuration that works",It will most probably solve your problem.
If above thing doesn't work,repeat the same step by selecting "safe boot" and follow the instruction below
To remove Windows updates, there are two ways to do this:
1) Add / Remove Programs: Use the Add / Remove Programs tool in the Control Panel to remove the updates. Open it, and make sure the “Show Updates” box is checked (it’s located in the upper right of the tool). Scan through the list and see if you can find the updates you’ve mentioned below. Remove them if you see them. Reboot and see if you still have the problem. If you don’t find the updates listed here, you’ll have to use the second option below.
2) In your Windows XP Start Menu, go to All Programs, point to Accessories, point to System Tools, and then click System Restore. The System Restore tool will start. Use that to restore your PC to a previous date – you should be able to select to restore to a time before those updates were installed. The tool will allow you to pick from certain times you can restore to. Pick the date and time that’s just before you installed the updates.
If neither of these fix the issue or remove the updates, then the problem is not something I can easily troubleshoot over email. There may be anything from hardware problems to network problems to CPU and process problems. To continue the troubleshooting, you’d be best off showing your PC to a local computer geek.
If removing the Windows updates fixes your problem, then we at least know the cause. If you’re really ambitious, you can reinstall those same updates one at a time to determine which one is causing the problem. At that point you can simply not install it, or keep an eye out for an update to the update!
Dec 24, 2009 | Acer Extensa 390CX Notebook
Washing machine leeks and doesnt complete cycle
When the washing machine starts leaking water all over the floor, you face a tough choice. Either call a service technician to fix the problem or purchase a new machine. Both decisions are expensive. Most service technicians charge $50 to $100 just to walk in the door and diagnose the problem, and labor expenses can quickly accumulate. After receiving the final bill, you may even wish you’d replaced the machine!
TIP: Make sure the water on the floor isn’t the result of a plugged floor drain. It happens!
There are two types of washing machines: belt drive and direct drive.
If you open up the cabinet and don’t find any belts, then you’ve got a direct-drive machine. Repairs are similar for both machines, but generally easier on the direct-drive unit.
The following photos are from a belt-drive washing machine. If you have a direct drive, refer to your owner’s manual or diagrams (see “Buying Parts") for brand-specific details.
First, Replace Leaky Supply Hoses
The first step is to locate the source of the leak. Empty the washing machine, move it away from the wall and start the fill cycle. Look for drips around the water supply hose connection at the back of the machine while it fills with water. Shut off the water and replace any old, heavily corroded or rusted hoses with new ones. If the hoses are in good shape, replace the internal washers only. Special no-burst hoses ($10), regular hoses ($6) and new hose washers ($2 per 10-pack) are available at home centers and hardware stores.
Turn off the water main or shutoff valve and unscrew the supply hoses from the back of the machine with an adjustable pliers. Pry out the old hose washers with a flat-blade screwdriver. Install new gaskets in both hoses and reconnect the supply lines.
Second, Replace Leaky Internal Hoses
If the supply hoses aren’t leaking, open the cabinet and inspect the internal components. Belt-drive machines typically have a rear access panel that unscrews. Access direct-drive machines by removing the two screws on the outside of the control panel and flipping up the lid. Then pry up the cabinet clips and pull off the entire cabinet. With the cabinet open, restart the fill cycle to check for internal leaks. Look for additional clues like rust and calcium deposits. Most often you’ll find the leaks in the spots we show inFigure A.
Hoses tend to leak around a worn-out spring clamp. First try to remove the spring clamp with an adjustable pliers. If you can’t get it, you’ll need a special $15 hose clamp pliers available from your local parts supplier. Replace the old spring clamp with a new worm-drive clamp. If the hose itself is cracked and leaking, remove it and take it to the appliance parts supplier for a replacement.
CAUTION: Unplug the machine before performing any repairs.
Washing machine parts are available at appliance parts distributors. (Look in the Yellow Pages under “Appliance Parts.”) Try to find a parts supplier with a well-informed staff, ideally ex–repair technicians, who can provide diagrams and help diagnose any problems specific to your brand of machine. A great Internet source is www.searspartsdirect.com. Enter your model number to access exploded-view diagrams and a thorough parts list for easy on-line ordering.
You’ll need the brand and model number for proper part identification. Model numbers are usually stamped on a small metal plate located under the tub lid or on the side or back of the machine. Copy down all the plate information and take it along to the parts distributor.
Third, Replace a Leaky Pump
Fourth, Replace Worn-Out Tub Fittings
The most challenging repair is fixing a leaking tub fitting, whether it’s the air dome seal ($5), the center post gasket ($8) or the tub seals ($15 to $20). Before proceeding, make sure that telltale drips are coming from around the tub. The details of this repair vary by brand and model. The details we show are for most Whirlpool and Kenmore belt drives. Study a schematic drawing or consult a parts specialist if your machine is different from what we show.
You’ll need a special $15 spanner wrench to remove the tub and replace the tub fittings on this type of machine. It’s available at your local appliance parts supplier. You can open the top of many machines by releasing the spring catches. However, on others you have to unscrew several screws and lift off the entire cabinet. Look in your owner’s manual or at a parts diagram. (See the manufacturer’s Web site or one of the sites listed in “Buying Parts.”) You’ll have to unscrew the water inlet and the tub snubber before unclipping the ring. Fastening systems for these vary by brand, as do attachment methods for the agitator and inner tub.
There are four tub seals that secure the outer tub to the cabinet, each consisting of a bolt with a rubber and metal washer. Rust often develops around one of the tub seals, causing a tub leak. A new tub seal kit will come with four new bolts and oversized rubber and metal washers that will seal small leaks. But if the tub is completely rusted through around the bolt, it’s time to buy a new washing machine. Replace all four tub seals.
If the leaking occurs only when the machine is agitating, a bad center post gasket (“doughnut”) is the culprit. Remove the outer tub to replace the center post gasket. While you’re at it, replace the air dome seal as well. Reassemble the washing machine and run a test cycle.
Thank you Sir, Have a nice day.
Sep 17, 2009 | Whirlpool Washing Machines
Left hinge broke and no screen.
Its possible that there is a cable loose causing a short, which could have happened when the hinge broke.
This would explain why you are not seeing any display. To test if the display is bad, or if the computer is just not working, you can plug in an external monitor. It will help you to see if you nicked the cable, or if the system board is going.
Jul 23, 2009 | HP Pavilion DV9650US Notebook
Saeco Royal Professional Espresso Machine Logo
99 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
