Question about HP DeskJet D1460 InkJet Printer
HP Deskjet D1460 (Ink level problem)
I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink, it always shows that the level of ink is low.
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
They key to successful refills is to remove air bubbles from cartridges check here the right way
Posted on Nov 23, 2010
  • 199 Answers
Most of us wait until we get bad printing before we address the low ink situation, well beyond the message to purchase a new cartridge. The moisture sensor does not work with dried ink on it. You will have to live with it or buy a new cartridge.
They key to successful refills in general is to refill them before your notice, when they are still about 1/3 full
Posted on Jun 16, 2009
2 Suggested Answers
aicaxz
  • 511 Answers
SOURCE: I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
Posted on May 31, 2009
Sir I have HP Deskjet -D1460 and my black cartridge not printing
In most cases the printer driver software can have errors while being in use or is shut down. First remove the ink cartridges, the B&W . Now to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 17, 2011 | HP DeskJet D1460 InkJet Printer
My HP deskjet d1460 is showing offline after cleaning the print cartridges. How do i rectify the problem?
Possible that the drivers were corrrupted , hence to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Mar 21, 2011 | HP DeskJet D1460 InkJet Printer
I have a HP 1460 printer & I have now no black ink in my printer.can this printer support any duplicate cartaige(local cartaige)?
No, that printer only uses the 21 Black and 22 color cartridges. The best thing to do when you run out of ink is to buy a refill kit and then refill each cartridge at home. This saves lots of money in the long run. Click on the link below to view a refill kit for your HP D1460:
http://cgi.ebay.com/Refill-ink-HP-21-Deskjet-1420-1430-1460-BK-4oz-s-/320621581336?pt=BI_Toner&hash=item4aa6891418
Feb 13, 2011 | HP DeskJet D1460 InkJet Printer
Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
May 28, 2010 | HP Deskjet D4260 Printer
I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
Dec 30, 2009 | HP Office Equipment & Supplies
How to refill hp 818 inkjet cartridge
i have injected 5 ml black ink in my 818 cartridge and inserted in my HP deskjetF2418 printer but it is not working and showing empty signal
Sep 30, 2009 | HP DeskJet F380 All-In-One Printer
May 28, 2009 | HP DeskJet D1460 InkJet Printer
How do i change ink cartridge 21 in hp deskjet D1460 printer
Here is the manual for your printer courtesy of HP:
http://h10032.www1.hp.com/ctg/Manual/c00905267.pdf
On page 47 of the manual it explains how to change out the cartridges.
Let me know if you need more help.
May 23, 2009 | HP DeskJet D1460 InkJet Printer
Refilling ink into hp380 deskjet cartridge ???"HELP"
If your refill kit contans a hypodermic needle you drill a small hole in the top of the cartridge and slowly inject the ink into the cartridges.I find it easier to remove them and do it over the sink as it can be quite messy. You place a piece of tape over the hole after refilling. If you wait too long and remove to much ink from the cartridge,it will not reset and it wil still show it as empty. Their is no way that I know of to reset one that becomes too emply w/o the specilized electronic equiptment.
Mar 31, 2009 | HP DeskJet F380 All-In-One Printer
My printer can't read the new ink level after refilling
The ink level indicator is only an estimate to give you an idea when it's time to buy a new cartridge. You cannot reset the ink level indicator so simply ignore it if you refill your cartridges. See pg 72 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Dec 06, 2008 | HP DeskJet F4280 All In One Printer InkJet
HP DeskJet D1460 InkJet Printer Logo
690 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
