Question about Dell Latitude D600 Notebook
Cdrom want open
I have a dell latiude running redhat linx and i cant seem to get the cdrom to open the light blinks like its going to open but noting happens.I tryed to help it open by prying it a little bit but it still want open. i dont know if is because it dont have the drivers or what???
    Problem Solver:
  • 11 Answers
Cd-roms require a driver but comes with all Operating Systems. The power cable connected by itelf is enough to open it...if you push the button and it won't open, get a new one, takes 20 minutes to buy, 5 days to get and 30 minutes to install. Basically about an hour of time and 30-40 bucks off of tigerdirect.com
Posted on Jun 16, 2009
Have cdrom that doesnt play dvd on all in one
That's because of bad drivers, reinstall the program if you have the programming CD
Nov 16, 2012 | Dell Computers & Internet
When powering up, the CDROM light just blinks every second
Troubleshoot the problem this way. If the clicking noise comes from the CDROM then disconnect the power and ribbon cable from the rear of the CDROM and attempt to boot your PC again. If you think there is a CDROM stuck in the drive (and due to settings that let CDs such as Windows install disks boot from the CD ROM), You can get the CD out with the PC off by getting a large paperclip, and after straigtrning out the wire, you will see a small hole in the front of the CDROM drive usually below the tray that comes out for you to put the CD in. Push the paperclip in firmly, and the tray will pop out, letting you get your CD out. Retry booting after the CD has been removed.
May 15, 2010 | Dell Dimension 3000 PC Desktop
I have a hp special edition L2000. Power is getting to the computer as the LED lights come on and then continuously blink. I can feel the cdrom running in a start and stop pattern, much like the blinking...
try to recover first your data, remove hard disk and make it slave to other station. copy all your files. then you may now reformat using a fresh install of windows xp.
Apr 13, 2010 | HP Special Edition L2000 LiveStrong Mobile...
DELL INSPIRON 1525 not recognizing CDROM Drive
  1. ensure drive is recognized by the BIOS (It should be ID'd by model in BIOS
  2. If drive is seen normally in bios, then try the fixit utility in this link: http://support.microsoft.com/kb/314060
  3. See if you can boot to the drive using your Vista DVD and run a repair my computer from DVD
  4. If none of the above works, replace the drive. If system will boot to DVD, then reinstall Vista
Sep 29, 2009 | Dell Inspiron 1525 Notebook
My Dell Demension 2300 will not power up.
open cpu cabinet then refix RAM.
Reattch all connection to motherbord also check your smps power unit works fine.
may be your smps is gone .
SMPS is aquare box which with you connect power code.
Jul 29, 2009 | Dell Dimension 2300 PC Desktop
Cant get my cd drive to open on my dell inspiron B120 laptop. Light intiates like its going to open but it doenst engage the door
There is a small hole beside cdrom release button - push pin or needle in to it and cdrom opens.
Apr 19, 2009 | Dell Inspiron B120 Notebook
CDRom is not present in Vista 32 - Shows driver not working...
Check "Computer" or My Computer and see if the drive is there. If not, reboot the system and go to the System Setup page (hit F2 on the Dell splash screen). Check if the CDROM drive is present under Drive Configuration. If not, reseat the CDROM drive. Remove it from the computer and just put it back in. If you think this is a software issue, backup all your files to a USB flash drive and do an image restore. Hit F8 several times continuously when you see the Dell Splash Screen then select Repair Your Computer. Login on the System Recovery Page. Choose Dell Factory Image Restore. This will bring your computer back to where it started.
Please rate this if this helps.
Dec 18, 2008 | Dell Inspiron 1521 Notebook
Cd rw/dvd rw now working
If you know how to open your laptop, you can try seeing if the cable to the CDROM is connected properly. On startup, does your computer recognize the drive? If it's not the cable, you need a new cdrom drive.
Jan 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Problem on cd drive
if that case your cdrom drive not see...just simply you just open your pc disconnect the connection of cdrom drive and after you connection again better..i think your connection will loss contack the socket of the cdrom that why that power not to blink...
Dec 17, 2007 | HP Compaq Presario V2000 Notebook
Dell Latitude D600 Notebook Logo
413 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
