Question about Creative Labs WebCam Live!
Bad image i think i need to clean my webcam
Blurred image
A webcam is first and foremost a camera that uses a lens to gather light reflected by an object. There are a number of reasons why the image captured by the webcam can be blurry, all of which can be remedied.
Supplies from a photography store or hobby shop, along with items that most people already have in their homes, are needed.
The webcam does not need to be disassembled in any way in order to obtain a sharp and clear image.
Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu.
Aim the webcam towards you so that you can see the blurry image presented in the program's video window.
Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp.
Blow off the lens at the front of the webcam with compressed air.
Moisten the end of a cotton swab in photo lens cleaning solution.
Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge.
Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image.
Launch the webcam video program that is on the hard drive.
Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window.
Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field.
Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam.
Aug 01, 2013 | GE EasyCam Webcam
Can youi show me how to fix my webcam so i can get clear view , because i do not know how?
Step 1:
A webcam is first and foremost a camera that uses a lens to gather light reflected by an object. There are a number of reasons why the image captured by the webcam can be blurry, all of which can be remedied. Supplies from a photography store or hobby shop, along with items that most people already have in their homes, are needed. The webcam does not need to be disassembled in any way in order to obtain a sharp and clear image.
Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu. Aim the webcam towards you so that you can see the blurry image presented in the program's video window. Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp. Blow off the lens at the front of the webcam with compressed air. Moisten the end of a cotton swab in photo lens cleaning solution. Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge. Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image. Launch the webcam video program that is on the hard drive. Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window. Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field. Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam.
Feb 12, 2013 | Logitech Webcam
Camera
Step 1:
Feb 07, 2013 | Craig Computers & Internet
Camera out of focus
Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu. Aim the webcam towards you so that you can see the blurry image presented in the program's video window. Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp. Blow off the lens at the front of the webcam with compressed air. Moisten the end of a cotton swab in photo lens cleaning solution. Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge. Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image. Launch the webcam video program that is on the hard drive. Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window. Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field. Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam. Hope this helps.
Jan 25, 2013 | Computers & Internet
Display field burned out
Jan 21, 2013 | Computers & Internet
When taking photo shots, the image is very dark. Have tried using 500 watts bulb; picture image not better
Try looking at the lens of the webcam itself, maybe there is some thin film that needs to be cleaned off. Another solution is to use a program like Adobe Photoshop, or, something similar, to brighten the pics manually. Else it could just be a defective webcam.
Hope this helps. :)
Sep 29, 2010 | Logitech QuickCam Communicate STX Personal...
The view is very bad. What can be the reason?
Check if it has a focus ring on the front. You can go to this free webcam test site and adjust the ring until you are happy with the image quality. Also the article How To Improve Your Webcam Video Quality provides many helpful tips and recommendations on getting the best image quality possible out of your webcam.
May 26, 2010 | Sony PCGA-UVC10 Webcam
My image appears all black
Hi friend,
You need to check your webcam screen .....you need to clean it....then it will work
Nov 23, 2009 | Radio Shack VGA PC Camera Webcam
My webcam works online with messengers, but when I open it to take a picture, the picture is there but when I click the snap image it is a white screen. I think I need update drivers for vista because it...
Hi There,
I need to know the make / model number of your webcam before I can help you.
Please let me have them as soon as you can.
Thank you.
Philip
Nov 30, 2008 | Philips SPC 200NC Webcam
Image flickers
Microsoft KB article 949033 this is a hotfix that work for us..... We had a very bad flicker... tried new driver etc.... this hotfixed worked...
In this scenario, you may experience severe degradation in the video output of both the Webcam and other video-based programs.
May 16, 2008 | Microsoft LifeCam NX-6000 Webcam
Creative Labs WebCam Live! Logo
18 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
