Question about Northgate (WALIND240C) PC Desktop
Laptop hello i have a laptop but i dont know how you connect it to the internet and i dont know my network WEP key
  • 98 Answers
The key is your dsl phone number your server sent to you.
Posted on Jun 16, 2009
I recently reformatted my IBM (2003) and re-installed the dwl-520 adapter and for the life of me it is not allowing me to connect to the internet. It is not pulling up all other wireless networks. I...
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Apr 24, 2011 | D-Link Air DWL 520 802.11b (DWL-520)...
The wifi on my nintendo ds lite doesn't work even though i changed the settings to WEP ..i dont know if the wep key i type in on my DS is wrong because when i type in the wep key shown on the netgear...
Welcome to Fixya
First you need to check is if the WEP key that you are entering is the WEP key of your router. Try to connect a laptop to your computer which do not belong to the network. Say, your friends laptop. This laptop will ask for a security key if it's the first time to connect to the network. Enter your security key and see if the laptop can connect to the network. If it did not connect then the problem is your WEP key.
Have a good one!
Mar 28, 2011 | Computers & Internet
I have a 2wire 1000SW router/modem connected by an ethernet cable to a Hewlett Packard media center PC running Windows Vista. The internet Wifi connectivity problem arose after I visited a best Western...
If you check your router you will find a reset button or a little hole in back insert pin in hole and press for 10 seconds your Moden should have reset now you will have to put in your login and password to access modem
Feb 28, 2017 | 2wire Computers & Internet
How to connect new laptop to router
Hello
In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
Click on "Properties."
Select the "Wireless Networks" tab.
Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
Click on "Configure" when you see your network's SSID in the "Available Networks."
Enter your network's SSID and WEP key.
Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
Hope it helps, if so do rate the solution
Good luck
Dec 24, 2010 | Linksys Wireless-G WRT54G Router
I have a D-Link DIR 615 wireless router i am trying to connect my daughters DS to the wifi but it keeps asking me for a WEP KEY???? i dont know the wep key i put the serial number in and the password but...
WEP KEY
WPA KEY
When you will make WEP key then you have to put this key on your pc first for connect to internet. It is very easy steps & your network will make secure.
First check your network option also.
Right click on your network then you see the property then go to security See dropdown menu If you have wep key then follow these steps if you did not see thi.
WPA is same as WEP
(WEP)
You need to sign in your router first.
1.open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1)
http://192.168.0.1/
2. Select "Admin" from the drop-down menu and then enter your password. Leave the password blank by default.
Now you can see your D-LINK webpage where you find your wep key.
Clik setup then wireless setting
Now you see on this page
1. Wireless Security mode then drop-down-menu Set Enable WEP
2. Authentication - Choose Shared Key.
3. WEP Encryption - 64 Bit.
4. Key Type - HEX
5. Default WEP Key - WEP Key 1
6. Now Make a key( You can choose any password but remember only 10 charcters allowed)
7. Now Save setting. then your router gonna boot up make sure let it boot. It connected after 5 minute.
You should write your password in paper first then you will have to add this key into your pc. network.
You can not connect internet because you have to put these Key(password) into your pc first.
Go to your network connection in your pc Choose your network
Or
You see two computer( internet icon) on the desktop
Right click then connect to network then you see so many network & your network ( Which you create).
Right click on your network then you see the property then go to security choose wep key then put the password(KEY).
WPA
1. Wireless Security mode then drop-down-menu - EnableWPA
2. Clipher type -TKIP
3. Passpharse - create own password here( don't put any personal info there)
Save setting
Device restart.
Now check Network status. Its working now.
Follow youtube video
Jun 10, 2010 | Computers & Internet
I dont now
Hello! If your are seeting up your wireless connection between your Nintendo DS and your wireless router, you should enter your security key to have a successful connection. If you don't know your wireless network security, you can contact your Internet Service Provider (ISP) to get it.
Apr 30, 2010 | Nintendo DS Lite Console
New laptop want to connect but forgot key
what you want exactly?password for what? username and password for internet in subscriber? or just WEP for wireless key password?
if you forgot the password for username and password for subscriber....theres an option,i dont know what kind of subscriber do you have in your country...if you forgot the username and passowrd you can ask in the subscriber.
regarding in the WEP password for wireless,it doesnt matter,try this..
type 192.168.1.1 in the internet toolbar
username:admin
password:admin
and you can see the configuration,check the wireless settings for WEP...
Jan 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Need wep to connect laptop from school to home network while at home
YOU SHOULD BE ABLE TO FIND THE WEP KEY IN YOUR INTERNET CONNECTIONS. IF THERE IS NO WEP KEY, JUST CREATE ONE AND YOU SHOULD BE GOOD TO GO. THIS CONNECTION LINK HAS A TAB TO SHOW CHARACTERS IF THE KEY HAS BEEN ENTERED. YOU WILL PROBABLY HAVE TO REMEMBER IT, OR JUST CREATE A NEW CONNECTION WITH A NEW WEP KEY! THAT IS THE EASY WAY! GOOD LUCK.
Oct 30, 2008 | NetGear WG511 802.11g/b Wireless Adapter
Acquring network conections
do you know who set up your router im guessing its not you as you dont have your wep key if you do have it its easy if you dont you need to connect to your router with a cable to get the wep key once done you mat need to set up your ip address on your laptop it should be 192.168.0.2 with a sub mask of 255.255.255.0 and a default gateway of 192.168.0.1 and a primary dns server of 192.168.0.1
any more help just ask
Oct 29, 2007 | NetGear DG834G Router
Northgate (WALIND240C) PC Desktop Logo
Top Northgate Computers & Internet Experts
Lee Eismann
Abhinandan  Patil
Abhinandan Patil
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
