Question about Whirlpool Duet GHW9150P Front Load Washer
Lights come on,shows amount of time cycle takes but won't start
When you hold the power button in, it doesn't do anything. I don't get an error code or anything. It just doesn'tdo anything, like click to let you know that it will begin the cycle.
    Scholar:
  • 106 Answers
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
rate me
Posted on Jun 16, 2009
Used it yesterday, fine today. Pushed power, fine. Pushed start, why nothing?
Hello. I will take you through some basic troubleshooting. Being plugged in, display working, choices made, does the machine do anything after the start button is pressed? Examples include locking the lid, starting to fill with water, etc. Did you notice any error codes that popped up in the display? If nothing is happening after pressing start, and there aren't any error codes that have been displayed, the problem could be with the control panel. First, unplug the machine for about 5 minutes to reset the main board, then plug it back in. (You might see a spark and hear a "pop" at the outlet due to the amount of current being immediately used by the machine at idle--this is alarmingly normal!) The machine should give a short beep after being plugged in--this tells you that the main board is alive and receiving power. Try to initiate a cycle again. The circuit board for the control panel might be defective if you get the same results. Important: have you had a power outage recently--such as 3-4 weeks prior? They are NOTORIOUS for damaging boards in the electronic washers.
Part numbers:
8564291--USER INTERFACE BOARD
W10104830--MAIN CONTROL BOARD
Link to pictures of the user interface board
8564291 Google Search
Link to pictures of the main control board
W10104830 Google Search
To initiate automatic diagnostic mode, follow this procedure:
press and hold the spin button for 3 seconds, release it for 3 seconds--3 times(yes, do the 1-one thousand, 2-one thousand, 3- one thousand out loud, lol--I do!) All the lights will light up and you will see "88" on the display. If there are any stored error codes, the most recent one will be displayed--Fxx(example: F2--means there is a stuck button on the user interface board) The machine stores the last 4 error codes--keep momentarily pressing the spin button to see any stored codes until the machine displays a C0. Image 3 has the instructions. The first 2 pix show the sequence of the automatic self test and what will be in the display as each of the machine functions is initiated. See the attached pix below. For any displayed error codes, you can do web searches using your model number and the error code to find out what the meaning is. Let me know what you find--to exit the diagnostic mode, simply press the power button. I hope this helps you!
Nov 06, 2015 | Whirlpool WTW6400SW Cabrio Washer
How do I repair a Cabrio washing machine
Press the cancel button all indicator lights/LED should be off
Select any button except Power, Start,Pause/Cancel
e.g. select buttohttp://www.fixya.com/answer/answerpageslideview.aspx?thid=25219265&ctg=130n "Soil Level"
Press "Soil Level" button and hold for 3 seconds
Release "Soil Level" button wait for 3 seconds
Press "Soil Level" button and hold until "88" lights up on the display and all indicator lights turn on
Watch the display flash any error codes will be displayed. e.g. "81" , "F", etc
Take a note of the numbers and letters displayed, press the "Soil Button" and the next set of codes will be shown. Press the soil button a few times noting down all the codes until "88" is displayed.
If the "Soil Button" doesn't work try another button using the same procedure above exluding any of the buttons mentioned above.
Please post the error codes you have noted.
Oct 13, 2014 | Washing Machines
What does E61 service call on my frigidaire affinity mean???
read the whole manual no code e61 ?
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer.
Jun 14, 2014 | Frigidaire Electric Dryer
What does E6 error code mean
here is basic error codes for your dryer (and how to get them out)
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
Jun 04, 2014 | Frigidaire Dryers
WHY DOES MY DRYER KEEP SHUTTING OFF WITH BLINKING LIGHTS
sure is heres how to get the fault codes
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 09, 2014 | Frigidaire Dryers
Frigidaire affinity dryer yes code
heres how to get them :
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 06, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My i pod touch is blank, i've followed the relevant stepr to restore it. after which an error code was given on i-tunes, i followed the steps given for the error but my i pod is still doing...
Try this:
Hold down the middle button (home button), the power button, and the volume DOWN button (make SURE that it's not the up one. It won't do anything, but it won't fix your iPod. Only the Down button will.).
Hold all of these down until the Apple sign shows up. Once the Apple sign shows up, it SHOULD work.
I hope this helps!
Jun 15, 2011 | Apple iPod touch
I changed the a/c filter and have been trying to reset the light which says a/c filter change required but it won't reset. Can't understand why because I press reset as soon as it comes up...
All those lights etc on the right side of your dash
are not tied to anything
You don't have to change anything
or do anything. Oil,Cabin Filter etc
THEY ARE JUST GADGETS
Status does cycle
You press Reset & hold
When it says to hold, you
quickly press & hold Reset again
You can just forget all that
Doesn't do anything
You don't sit in your car &
call it up with the status button
& watch it anyway.
Brake Fluid-every 2 years --Flush/All Vehicles
Spark Plugs -- every 3 years,not over 60,000 miles
Fuel Filter --every 3 years
Air Filter --every 3 years
Cabin Filter --every 3 years
Trans & Power Steering--3 years
not over 30,000 miles--EVER on any vehicle
May 28, 2011 | 2004 Lincoln LS
My xbox360 powers up with a green light from the middle and thats it , it don't work or connect to the controllars (not wirelessly or by the usb port) . and the four circling light don't work .please help
switch the xbox off and if you have any hard drive etc connected to the xbox or usb devices disconnect them , then switch it back on while holding the sync button, the one you press to pair the controllers with , hold that for 30 seconds and then release it, see if it will show up on the tv. If it still wont show anything on the screen , check all cables, borrow one that you know is working to try on it. if that doesnt work try another power supply. The best way to test it though is to take it to a friends and unplug there xbox and use their leads and power supply to see if yours boots up. Another check you can do is hold the sync button in and press the eject button , if an error is happening the ring of lights will change , you need to press eject 4 times, without letting go of the sync button, each time you press it the red lights will come on, code is as follows
Four lights =0
three lights = 3
two lights = 2
one light = 1
so if you get 433
then your secondary error code is 033
reply with what your error code is here
Apr 16, 2011 | Microsoft Xbox 360 Console
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Jan 10, 2008 | Frigidaire AEQ7000ES Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
89 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
