Question about Kenmore Dryers
My dryer is blower cold air and is spinning
My dryer is blower cold air and is spinnig but is not heating I changed the coil valve because that is what the repair man did the last time but it did not do the trick this time please help thanks
    Problem Solver:
  • 11 Answers
Check the whole heating coil see if there is a break in the wire.
Posted on Jun 16, 2009
My dryer does not blow hot and will not shut off and no digital reading will display.
Hello Bryan;
My name is Peter. I am a retired field service appliance technician.
So, here are the probable causes:
1.) The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may be plugged up or not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft. Check the blower hot air discharge manifold for blockage.
2a.) If the dryer won't stop, the gas valve solenoid coils might be defective. Over time these coils will fail, causing the burner to run intermittently. If the dryer is not heating properly it may not stop. Replace the coils as a set.
2.b) The heating element warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element isn't working - which greatly increases the drying time. Check the heating element for continuity.
3.) Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
4.) Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or shorted
5.) If the dryer won't stop, check the high limit thermostat. If defective, the high limit thermostat can turn off the heat prematurely, lengthening the time it takes to dry a full load. This is not common.
6.) The cycling thermostat regulates the temperature of the air in the dryer. If the dryer won't stop, it may be caused by a defective cycling thermostat turning off the heat too early. This is not common.
7.) The thermistor senses the temperature of the air in the dryer and cycles the heat on and off. If the dryer won't stop, the thermistor may be defective. This is not common.
Nov 16, 2014 | Dryers
My whirlpool duet dryer has no heat but turns on and spins with cold air. I cleaned vent and removed toe plate. If it is thermal fuse problem will the igniter glow still? I found a penny lodged on the fuse...
see this causes and fix it. I am supposing the dryer is gas because you are telling the igniter?
God bless you
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Sep 28, 2012 | Dryers
I should like to have a Dutch or English user manual
Obstructed Vent
Your Kenmore dryer must be able to freely circulate air in the dryer in order for it to continuously supply hot air. If air flow is limited from a buildup of lint in the vent and lint tray, the high limit switch temporarily shuts off heat to the dryer. Empty the lint tray on the top of your dryer. Detach the exhaust vent -- the silver tube in the back of your dryer -- and thoroughly clean it out with a lint brush and reattach. Consult your Kenmore dryer manual for instructions on how to inspect and clean your vent hose. Once these components have been freed of lint, the dryer should dry clothes again.
Broken Blower Wheel or Belt
If you have completed a full inspection of your dryer vent system and found no obstructions, your dryer might have a defective blower wheel or belt. A failure of one or both of these components can restrict air flow in your dryer and take your dryer longer to dry clothes. According to Point and Click Appliance Repair, a noise coming from the dryer as the drum spins is usually an indication that the blower wheel is failing and needs to be replaced. Review your Kenmore dryer manual for instructions on how to locate these components on your dryer.
Faulty Thermostat
A broken thermostat can cause your dryer to produce too high or too low heat. Monitor the dryer exhaust temperature with a hand-held thermometer. The temperature should be below 150 degrees Fahrenheit. If the temperature reading is higher, then replace the thermostat. It's no longer able to regulate the temperature inside the dryer, and your dryer is in danger of overheating. If the temperature reading is room temperature and the dryer is running, the thermostat is broken and needs to be replaced.
Damaged Gas Valve Coils
Damaged gas valve coils permit your Kenmore gas dryer to ignite only once before coils must completely cool in order to reignite. This is a common issue among older dryers. If your dryer struggles to turn on or after it shuts off you must wait several minutes before it restarts, then the gas valve coil likely has worn. Confirm the location of the igniter from the manual. It's a cone-shaped tube that is located inside the dryer near the front panel close to the bottom. If the igniter radiates bright orange for 15 seconds without producing a flame, then the gas valve coils have probably failed.
Mar 10, 2011 | Zanussi Dryers
Dryer spins but clothes are still cold and wet. It appears to be a problem with the heating element.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
May 17, 2010 | Maytag Neptune MDE6700A Electric Dryer
Will not heat
Please rate me, Thank you
May 12, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Dryer functioning but air not getting hot. this is a Maytag gas dryer
Things that could stop a gas dryer from heating:
Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up (no continuity) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryer’s air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, cannot be re-set, must be replaced if is open (no continuity between pins).
Thank you for contacting Fixya.com
Aug 18, 2009 | Maytag Dryers
Gas dryer no air no heat but spins
Probably bad gas valve coils.
Change out the flame sensor too.
Mar 05, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer heats but after 10 minutes is cold
you can replace te coils mounted atop the valve itself, somtimes after the heat up they nologer allow the gas valve to come on..paret number 279834 comes as akit with both coils!
Jan 27, 2009 | Whirlpool LGR7648KQ Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
