My printer will not work because it says I need to remove and check color cartridge''. It is in correctly.
Hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..
or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
SOURCE: Remove and Check Color Cartridge message
it must have been a software glitch because it fixed itself
SOURCE: Remove and check color cartridge
I, too, am getting the cartirudge error (mine is for the black side) and I am unable to proceed past that message. I do see the broken tab which aligns the metal spring inside the plastic cartridge holder, so the spring is hanging. I suspect that this is the problem (I think I may have done that when I attempted to put the color cartidge in the wrong side in error?). Anyway, does anyone know where I can find a repair manual for the HP 2610 and where I can get the part to fix this?
THANKS!
Doug
the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
SOURCE: remove and check color cartridge
Sounds like the contacts are dirty. A cotton swab and some rubbing alcohol might help.
SOURCE: can't clear ''remove and check color cartridge''
if you go on the hp website and click on live chat they will help you tho it
